#6301 |
Y u do dis?
Low end torque was the deciding factor in my purchase (as well as $$) since i'm drag racing, shooting for 12s on a tire.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
#6302 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#6303 |
Drives: 2013 Subaru BRZ Automatic
Can I use 69mm or 70mm pulley with none-intercooler kit and 91 octane? Thanks.
Subaru BRZ Automatic, World Rally Blue , Innovate Supercharger, AVO Stage 1 Turbo kit, 4.556 FinalDrive, STI Big Break, DeliciousTuning
#6304 | |
Drives: 86
Before I upgrade to intercooled, I would feel the diffrence in performance of the car after few minutes of driving because of heat soak.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
| The Following User Says Thank You to 8686 For This Useful Post: | luckykevin (04-29-2015) |
#6305 |
Drives: 2017 Camaro 1SS
No, you need to be intercooled
| The Following User Says Thank You to brianhj For This Useful Post: | luckykevin (04-29-2015) |
#6306 | ||
Drives: bmw
trying to figure out if i should be going with this kit or the cosworth now (seems no e85 tunes on it yet either to compare)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#6307 |
Drives: 86
Unfortunately I dont have any track time with my car but from what read and hear from other owners, it still heat soak but not as bad as non intercooled.
#6308 |
Drives: 2014 WRB BRZ
I've got a couple of questions about the blower oil level.
1. I'm going to a HPDE track day this weekend at TWS, is there a recommended oil level for extended driving at WOT? 2. How do you check the oil level, when the car is on flat level ground, or do you jack up the rear and make the blower level? I checked with a bubble level when sitting in my garage, and the blower is not level unless jacked up. Thanks in advance. |
#6309 | |
Drives: 2020 DGM BRZ Limited
| The Following User Says Thank You to mikalem For This Useful Post: | CarzCarzCarz (04-28-2015) |
#6310 |
Just the tip
The only thing I keep track of on the track is oil temp and pressures, which are good. I don't have any logging data for the supercharger or horsepower loss because of heat.
#6311 | |
Drives: GT 86
Just check the oil level on flat ground as that was how Sprintex checked mine for me when I was there once. |
#6312 | |
AutoX-10/10ths every run
Page 36. You need to jack the rear of the car up so the blower is level before you check the oil.
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | CarzCarzCarz (04-29-2015), Chrisbrz14 (04-28-2015) |
#6313 |
Drives: Subaru BRZ with Delicious Innovate
http://www.ft86club.com/forums/showp...postcount=4595
thats a good way to get the oil to the correct level... you can't really see the oil on the bare metal dip stick.. i have a black dip stick that i use as well that shows the oil a lot better. as far as track days.. the intercooler does a pretty good job at keeping up.. it will "Heat soak" until it gets to an equilibrium temperature. and then it will stay there. It doesn't run off to some insane temperature.. the ecu has no idea what the temp of the water is or how hot the charge air is post cooler so power won't change too much... its a little noticeable but you will see a larger fluctuation with AIT than with the cooler circuit getting warm.. I would invest in a tablet or phone and run torque pro $5 and a cheap obdII adapter $12.. its an easy way to keep an eye on the critical things like oil temp, coolant temp, fuel trims ect. Ive spent 40 minutes on track going as hard as I could and the car never skipped a beat..
| The Following 2 Users Say Thank You to calispec For This Useful Post: | CarzCarzCarz (04-29-2015), CK_Bladesmith (04-29-2015) |
#6314 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
| The Following 2 Users Say Thank You to Xero-Limit For This Useful Post: | Dream20b (04-29-2015), luckykevin (04-29-2015) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
