Old 04-28-2015, 12:27 AM   #6301
Dream20b
Y u do dis?
Low end torque was the deciding factor in my purchase (as well as $$) since i'm drag racing, shooting for 12s on a tire.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 04-28-2015, 04:04 AM   #6302
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by sickmint79 View Post
e85, headers, stage 2, 70mm pulley -
what kind of whp numbers are you getting?
anyone tracking with comments? feel on track? video?
on one hand it seems to sound good to get another supercharger that grows more up top, or a turbo, with in theory more power in the 5-7k rpm range where you should be on track; although it seems like the above mentioned combo will actually deliver quite a bit of power in this range as well. would love to hear someone with more experience chime in !
Visit my build thread and you'll see videos and other stuff. I don't have e85 however. I'm at 250whp ish. With e85 you'll get closer to 280whp ish. Top end is a little less powerful than a turbo, but you also don't need to shift down as much as you have more torque down low. Also best sound in my opinion, which my videos will show.
Old 04-28-2015, 05:41 AM   #6303
luckykevin
luckykevin's Avatar
Drives: 2013 Subaru BRZ Automatic
Can I use 69mm or 70mm pulley with none-intercooler kit and 91 octane? Thanks.
Subaru BRZ Automatic, World Rally Blue , Innovate Supercharger, AVO Stage 1 Turbo kit, 4.556 FinalDrive, STI Big Break, DeliciousTuning
luckykevin is offline   Reply With Quote
Old 04-28-2015, 06:03 AM   #6304
8686
8686's Avatar
Drives: 86
I dont think so. It will create a lot heat that the engine would not like.
Before I upgrade to intercooled, I would feel the diffrence in performance of the car after few minutes of driving because of heat soak.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
The Following User Says Thank You to 8686 For This Useful Post:
luckykevin (04-29-2015)
Old 04-28-2015, 08:21 AM   #6305
brianhj
Drives: 2017 Camaro 1SS
No, you need to be intercooled
brianhj is offline   Reply With Quote
The Following User Says Thank You to brianhj For This Useful Post:
Old 04-28-2015, 10:48 AM   #6306
sickmint79
Drives: bmw
do you have any on track data too?
does the intercooled kit keep cool on track or does it soak partway through?
trying to figure out if i should be going with this kit or the cosworth now (seems no e85 tunes on it yet either to compare)
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 04-28-2015, 10:56 AM   #6307
8686
8686's Avatar
Drives: 86
Unfortunately I dont have any track time with my car but from what read and hear from other owners, it still heat soak but not as bad as non intercooled.
Old 04-28-2015, 12:33 PM   #6308
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
I've got a couple of questions about the blower oil level.
1. I'm going to a HPDE track day this weekend at TWS, is there a recommended oil level for extended driving at WOT?
2. How do you check the oil level, when the car is on flat level ground, or do you jack up the rear and make the blower level? I checked with a bubble level when sitting in my garage, and the blower is not level unless jacked up.
Thanks in advance.
CarzCarzCarz is offline   Reply With Quote
Old 04-28-2015, 01:41 PM   #6309
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Thanks in advance.
Need to level off the blower to check the oil level - would assume making sure you are to the line on the dipstick when cold.
mikalem is offline   Reply With Quote
The Following User Says Thank You to mikalem For This Useful Post:
CarzCarzCarz (04-28-2015)
Old 04-28-2015, 10:16 PM   #6310
stockysnail
Just the tip
The only thing I keep track of on the track is oil temp and pressures, which are good. I don't have any logging data for the supercharger or horsepower loss because of heat.
Old 04-28-2015, 10:27 PM   #6311
sam69
Drives: GT 86
Thanks in advance.
Just check the oil level on flat ground as that was how Sprintex checked mine for me when I was there once.
sam69 is offline   Reply With Quote
Old 04-28-2015, 11:13 PM   #6312
whataboutbob
AutoX-10/10ths every run
Thanks in advance.
http://www.innovatemotorsports.com/s...T86_Manual.pdf
Page 36. You need to jack the rear of the car up so the blower is level before you check the oil.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
CarzCarzCarz (04-29-2015), Chrisbrz14 (04-28-2015)
Old 04-28-2015, 11:50 PM   #6313
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
http://www.ft86club.com/forums/showp...postcount=4595
thats a good way to get the oil to the correct level... you can't really see the oil on the bare metal dip stick.. i have a black dip stick that i use as well that shows the oil a lot better.
as far as track days.. the intercooler does a pretty good job at keeping up.. it will "Heat soak" until it gets to an equilibrium temperature. and then it will stay there. It doesn't run off to some insane temperature.. the ecu has no idea what the temp of the water is or how hot the charge air is post cooler so power won't change too much... its a little noticeable but you will see a larger fluctuation with AIT than with the cooler circuit getting warm..
I would invest in a tablet or phone and run torque pro $5 and a cheap obdII adapter $12.. its an easy way to keep an eye on the critical things like oil temp, coolant temp, fuel trims ect.
Ive spent 40 minutes on track going as hard as I could and the car never skipped a beat..
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following 2 Users Say Thank You to calispec For This Useful Post:
CarzCarzCarz (04-29-2015), CK_Bladesmith (04-29-2015)
Old 04-29-2015, 12:12 AM   #6314
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
no
Xero-Limit is offline   Reply With Quote
The Following 2 Users Say Thank You to Xero-Limit For This Useful Post:
Dream20b (04-29-2015), luckykevin (04-29-2015)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
