Old 04-25-2015, 02:41 PM   #29
raven1231
Originally Posted by AceHeader-MT View Post
Hey Raven, you're 1/2 correct.
Yes, we aim for 200+ HP on a true dyno pull.
If we didn't care how it drove our cars wouldn't be so fast
Was directed towards op sir not you at all lol
AceHeader-MT (04-26-2015)
Old 04-25-2015, 04:55 PM   #30
FRS Justin
Drives: 2013 Asphalt FRS
PPE is my choice, made over 200hp with header and delicious tune stg 2 e85
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
raven1231 (04-25-2015)
Old 04-26-2015, 09:15 PM   #31
jonbonazza
An UEL header will ultimately make a bit less power, but it will be "more fun" on the street as the power is shifted down the power band and the torque dip is eliminated. The PTuning and Tomei EL headers are fantastic, but they aren't as fun to drive on the street unless you rev out every shift and the torque dip will still be there at least to some degree. If this is primiarly a DD, I strongly suggest a UEL header.
jonbonazza is offline   Reply With Quote
The Following User Says Thank You to jonbonazza For This Useful Post:
shu5892001 (04-26-2015)
Old 04-26-2015, 10:53 PM   #32
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I wanted to go EL primarily for the sound
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
Old 04-28-2015, 12:08 AM   #33
Turdinator
Señor Member
Turdinator's Avatar
I see this opinion on the forums a lot. Fun on the street is very subjective. I personally enjoy working through the gears and would rather downshift into the powerband than chug along at a low rpm.
1974 TA22 Celica
2013 86 GT
Old 04-28-2015, 12:16 AM   #34
jonbonazza
Uel is most fun around 3-5k rpm. I dont think youll be downshifting to anywhere higher than that. And you def wont be chugging.
Old 01-13-2018, 10:56 PM   #35
Chriswongbrz
Drives: 2015 brz
I wonder how is clubsport compared to ace?
Chriswongbrz is offline   Reply With Quote
Old 01-14-2018, 02:26 AM   #36
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
You mean the Club Sport Headers made by ACE compared to the ACE Type A Headers?
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
Old 01-14-2018, 04:13 AM   #37
churchx
churchx's Avatar
Drives: 2014 GT86
Chriswongbrz: CS400 primary purpose was better clearance for RHD twins. Performance relative to Type A/350 is a bit lower/optimisation moved even at lower rpms for ClubSport. Also it was at some point made using "Type B" quicker slip-on robo welds, resulting in cheaper product (but IIRC Ace solved problems with manufacturing speed of A welding, so not sure B-ness in lower cost (but less handwork/a bit heavier headers) still holds true).
If you have normal LHD car, header to get from Ace is A/350. If RHD, CS400, or if you track a lot, A/250.
Old 01-22-2018, 09:16 PM   #38
Chriswongbrz
Drives: 2015 brz
Yes
Old 01-22-2018, 10:36 PM   #39
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
From the grave....
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Pa inspection and Catless Header b1gb2olo Engine, Exhaust, Transmission 6 12-09-2015 02:15 PM
Top Speed Pro-1 Catless Header GA_Dave Engine, Exhaust, Transmission 6 07-27-2014 09:56 AM
no cel after catless header install vestal52 Engine, Exhaust, Transmission 14 05-22-2014 02:21 AM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
