Old 04-27-2015, 12:08 AM   #1
sam69
Drives: GT 86
Rockford Fosgates 6.5" Fit ?
Was about to buy some Rockford Fosgate Fanatic X FNX-2614's 6.5" for my 86 then had the thought that they might not fit the front doors due to depth or some thing like that and did a search but no luck.
Does anyone know whether they do or not
Thanks
sam69 is offline   Reply With Quote
Old 04-27-2015, 11:01 AM   #2
Jigglybus
Drives: fR-S
The mounting depth of the FNX-2614's are only 2-9/16 inches, so they'll fit no problem (with about 4 inches to spare). You'll need some sort of adapter for the hole however, like you would with any other 6.5 inch.
Jigglybus is offline   Reply With Quote
Old 04-27-2015, 04:06 PM   #3
fika84
fika84's Avatar
I have these in my car. And I had to get [ame="http://www.amazon.com/gp/product/B000NWCIEG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1"]this[/ame] adapter and [ame="http://www.amazon.com/gp/product/B0002BBP7Y/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1"]this[/ame] wiring adapter. The wiring adapter actually had the wrong size ends on it, but I had some fittings at home to replace them with to get them to work. Of course you can just cut the factory harness if you want as well..
fika84 is offline   Reply With Quote
Old 04-27-2015, 10:12 PM   #4
sam69
Drives: GT 86
Originally Posted by fika84 View Post
I have these in my car. And I had to get this adapter and this wiring adapter. The wiring adapter actually had the wrong size ends on it, but I had some fittings at home to replace them with to get them to work. Of course you can just cut the factory harness if you want as well..
Just wondering have you got them hooked up to the oem head unit and how's the sound quality ?
Old 04-28-2015, 09:09 AM   #5
fika84
fika84's Avatar
Since the door speakers in the US are running bass only (through a lo-pass filter) off the amp in the back, when I originally put them in it wasn't that much of an improvement. But I have since disconnected the rear speakers and am sending them a full range signal from those. Next up is to get an AVIC line Pioneer deck to use them properly.
The speakers themselves were referred to me by a friend who makes a living installing home audio and has been in the car audio world for a long time as well. I have no doubt they will serve their purpose of being a great mid range speaker.
Old 05-18-2015, 09:59 PM   #6
sam69
Drives: GT 86
The speakers have arrived and as I have the GT model I believe it doesn't have an amp so was wondering if I can just install the door speakers atm without worrying about the crossovers.
Will put some Dynomat in the doors as I believe this to be a good thing to do while I'm at it .
How big a piece would one need to put behind the speaker .
Old 05-19-2015, 12:15 PM   #7
fika84
fika84's Avatar
Should be good to go! You won't hurt anything by putting them in.
Old 05-19-2015, 11:09 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
If you aren't planning to go crazy later, two of the convenient 12 inch square pieces per door is plenty for the outer skin. One directly behind the speaker and the other halfway to the other end of the door will absorb most vibration. Don't forget to put some on the biggest flat areas of the door card, as well as the panel everything mounts to.
This reminds me that I need to do my wife's Pathfinder. When she uses the handsfree, you can hear the conversation from outside: the outer skin acts like a bigass passive radiator.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Rockford Fosgate P300-10 powered sub review robwbright Electronics | Audio | NAV | Infotainment 20 09-13-2015 02:14 PM
(DELETE) FS: Rockford Fosgate PBR300X1 amp NEW in box migueralliart Audio/Visual, Electronics, Infotainment, NAV 1 03-02-2014 12:26 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Rockford Fosgate 500W Amp finch1750 Audio/Visual, Electronics, Infotainment, NAV 2 03-26-2013 10:16 AM
Rockford fosgate pbr300x4 and minidsp unit JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 02-10-2013 02:28 AM
