Old 04-23-2015, 08:41 PM   #1
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Blown head gasket??
So the other night I was driving my car and when in boost the coolant shot all over my passenger side windshield. This is what I found when I pulled over. The next day the engine was getting hot out of nowhere. One of my fans does not work but I feel like that wouldn't have an effect if my coolant is boiling at 210 degrees. I'm afraid that boost got passed the head gasket and pressurized the coolant. Has anyone experienced anything like this?
texasbound972 is offline   Reply With Quote
Old 04-24-2015, 12:08 AM   #2
Turdinator
Señor Member
Turdinator's Avatar
Is there oil in the coolant or water in your oil? Check under the radiator cap and the dipstick. Typically it creates a sludge that kinda looks like mayonnaise. Otherwise check coolant hoses for leaks.
Don't open the radiator cap after driving the car unless you know what you are doing.
P.S. I am at work so can't see you photos so my suggestions are only general head gasket symptoms.
1974 TA22 Celica
2013 86 GT
Old 04-24-2015, 12:41 AM   #3
Yeah, that's oil in the coolant. Take a pic of your dipstick. #nohomo
texasbound972 (04-24-2015), TM (05-16-2015), wparsons (04-24-2015)
Old 04-24-2015, 04:39 AM   #4
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Grab a combustion leak test kit, follow instructions. That definitely looks like oil in the coolant.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
The Following User Says Thank You to #maverick# For This Useful Post:
Astroboy (05-08-2015)
Old 04-24-2015, 05:12 AM   #5
CSG Mike
CSG Mike's Avatar
You have oil in your coolant.
Old 04-24-2015, 09:27 AM   #6
stevesnj
stevesnj's Avatar
I thought the coolant in these cars is blue not green?
My 2016 Build thread
Old 04-24-2015, 10:54 AM   #7
texasbound972
USMC
Didn't have access to the oem coolant at the time. No coolant on the dipstick.
The Following User Says Thank You to texasbound972 For This Useful Post:
Ultramaroon (04-24-2015)
Old 04-24-2015, 10:58 AM   #8
stevesnj
stevesnj's Avatar
Were you running the green in there before it had this issue?
Old 04-24-2015, 12:26 PM   #9
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
green wont make a difference. I have been running green/water ever since we put my built motor in. as long as the system is flushed well first. including the heater core.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Astroboy (05-08-2015), Ultramaroon (04-24-2015)
Old 04-24-2015, 03:32 PM   #10
texasbound972
USMC
Nope.
Old 04-24-2015, 03:35 PM   #11
Dipstik-sportech
Dipstik-sportech's Avatar
Yup u popped a head gasket
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
Old 04-25-2015, 01:07 AM   #12
FRS Justin
Drives: 2013 Asphalt FRS
What he said
FRS Justin is offline   Reply With Quote
Old 05-08-2015, 04:02 PM   #13
Astroboy
Astroboy's Avatar
Drives: None
Sorry about your problems. Damn I hope I don't encounter any issues with my turbo frs
Astroboy is offline   Reply With Quote
Old 05-08-2015, 04:22 PM   #14
stugray
Drives: 2013 GBS BRZ Limited
Just do a compression test, it only takes a couple minutes ON MOST CARS - DOH!
A shop can do a coolant pressure leak test.
Then you listen at the crankcase vent for the sound of air escaping.
Not sure if you need to drain some coolant first.
You probably wouldnt be able to hear it is it was just pushing water through the leak.
Definitely stop driving it!
Head gasket install Andreas83 Engine, Exhaust, Transmission 1 09-07-2016 10:09 PM
Disappearing Coolant + White Smoke = Head Gasket Replacement BlueBoy Engine, Exhaust, Transmission 45 10-25-2015 01:26 PM
Blown engine! known head problems? Dmitri Issues | Warranty | Recalls / TSB 72 08-23-2014 04:51 AM
is my head gasket blown? BrianBlueBRZ Other Vehicles & General Automotive Discussions 4 07-22-2014 10:45 PM
Main Head Unit Blown Out mervingee BRZ First-Gen (2012+) — General Topics 7 06-17-2014 02:16 AM
