Old 04-23-2015, 03:14 PM   #239
ghost911
Drives: 2012 wrx
Originally Posted by Sojhinn View Post
If you follow my instructions above the head units runs your speakers.
As for volume for the speakers... Set a volume that's too high to listen to normally then back off the nexus 7s volume. Or use a remote or an app for the head unit (Sony and jvc) to control the volume through the nexus 7.
My head unit has Bluetooth and it switches to my phone when receiving calls or starting calls.
Recently I installed new speakers, a sub and an amp. These are all connected through the head unit and would work as they normally do.
Remember you still need a head unit with above method but it just needs to have whatever features you want. I would lean towards a sony unit right now.
Ill be getting this tablet
[ame="http://www.amazon.com/dp/B00DVFLJKQ/ref=cm_sw_r_awd_8taovb1BA07ZC"]Amazon.com: Nexus 7 from Google (7-Inch, 32 GB, Black) by ASUS (2013) Tablet: Computers & Accessories[/ame]
Is there a cable i can use to charge and use tether from my phone by usb usb to the tablet? Cause wifi on my phone isnt unlimited
So calls wont come through the headunit at all the mic wont work? With the timur newer rom software?
ghost911 is offline   Reply With Quote
Old 04-23-2015, 03:16 PM   #240
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Get a otg y cable connected to a hub
Installed Mods:
Old 04-23-2015, 03:53 PM   #241
ghost911
Drives: 2012 wrx
Awesomeness.so this would work perfect or anything usb hub. Dont j need 3.0usb for tether to work perfect?
http://m.ebay.com/itm/like/171396761...3D819578019127
. So hopefully last questions.. So the new 2013 will work with timurs software when i donate 27$ correct?
Also what are the negatives having this set up? Should i use a power 150w converter and use the charger it comes with or use use the cig usb way to charge it
Old 04-23-2015, 04:17 PM   #242
Sojhinn
Sojhinn's Avatar
I use a USB port on my headunit to charge the nexus 7. As for the USB hub... Any Hub will work fine.
And yes timurs new software will work with a 2013 nexus 7.
Installed Mods:
Old 04-23-2015, 10:19 PM   #243
ghost911
Drives: 2012 wrx
awesome.. you been perfect help... didn't think the usb could charge it that well.. so I just buy a hub plug that into the single din HU and plug in the tablet into the hub wooo......
Do have a question though. installing a back up camera. I don't see how that would work unless I have an app and connect Bluetooth with the tablet...
And using a Mic through the tablet instead of phone..
Old 04-23-2015, 10:21 PM   #244
Sojhinn
Sojhinn's Avatar
Another Nexus 7 install: Clean and Easy
No you connect the hub to the nexus 7. The otg y cable is needed to use timurs rom, one end connects to the hub and then the other end of the otg y cable is connected to the head unit.
As for the back up can you need an easycap device that connects to the hub. With all of these devices you need to power the hub somehow.
Installed Mods:
Old 04-23-2015, 10:43 PM   #245
ghost911
Drives: 2012 wrx
sounds good...
will the tablet be able to read a dvd that is put into the single din player plugged in wit the usb ? cause if not then im just gunna rule out that option for the stereo
Old 04-23-2015, 10:45 PM   #246
Sojhinn
Sojhinn's Avatar
sounds good...
Nope doesn't work that way.
Installed Mods:
Old 04-23-2015, 11:07 PM   #247
ghost911
Drives: 2012 wrx
didn't think so haha... so there for cant I find a shorter hu that's not so deep?
like this one actually
http://www.sonicelectronix.com/item_...FZSEfgodB7AAOg
Old 04-23-2015, 11:08 PM   #248
Sojhinn
Sojhinn's Avatar
Pretty much any single din unit will work
Installed Mods:
Old 04-23-2015, 11:28 PM   #249
ghost911
Drives: 2012 wrx
the usbs are 1 amp thought. I read that 1amp is not enough it has to be 2amp or more... am I wrong?
Old 04-23-2015, 11:29 PM   #250
Sojhinn
Sojhinn's Avatar
1.2 is the max amperage for the nexus 2013. I use a 1 amp and its fine
Installed Mods:
Old 05-10-2015, 08:41 PM   #251
alex345
FRS610
alex345's Avatar
Drives: Scion- Frs
Send a message via MSN to alex345
@Sojhinn Hows the nexus holding up? might do this on my free time, also how are thos corners does it look oem?:p thanks bro!
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick#
alex345 is offline   Reply With Quote
Old 05-10-2015, 08:53 PM   #252
Sojhinn
Sojhinn's Avatar
Nexus is running great. I switched to the 2013 recently. I like it more but just barely. I recommend the setup as I have had no issues. As for the corners: one side looks perfect the other side you have to look closely to see the gap. If I were to redo the gluing of the double din kit I believe I could make it flush.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
bumppinKota (05-11-2015)
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Nexus 7 in FR-S/BRZ DjDATZ Electronics | Audio | NAV | Infotainment 4 06-09-2013 08:10 PM
Nexus 7 Car Audio DIY thejevans Electronics | Audio | NAV | Infotainment 32 05-10-2013 03:55 PM
How easy/difficult is it to keep WRB "clean"? ayau Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 32 06-17-2012 10:17 PM
