Old 04-22-2015, 11:19 PM   #15
chas3wba0
chas3wba0's Avatar
Drives: Yes
Just make sure to not use an analog tire pressure gauge, or else the 1.5 psi variance will cause you to spin out and hit a curb
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
DarkSunrise (04-23-2015)
Old 04-22-2015, 11:35 PM   #16
Amaya
Amaya's Avatar
Drives: 2015 Scion FR-S 6MT
It's just a minor difference in feel, not "omg, I can't control the car anymore".
And the pressure gauge doesn't need to be perfectly accurate it just needs enough precision. If you check one tire twice and it read the same both times it's precise enough.
Edit: and it's not just my FRS, I have noticed it in any car that I drive regularly.
Amaya is offline   Reply With Quote
Old 04-23-2015, 09:07 AM   #17
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by babydriver View Post
Maybe the problem is that you don't have any curves in Oklahoma, only corners. We don't have that problem west of Austin.
Seriously, dude, I've checked it several times because I thought it might be my imagination at first. I have a precision racing air gauge used to compare the tires; it is accurate to within 1/10 lb. The first time it was a three pound difference between the left and right front tires and I thought there was a problem with the steering. It was the pressure; I equalized the tires and the problem went away. On two other occasions, I have noticed a small amount of unpredictability in the car's rear end (as it enters oversteer) when the rear tire inflations are not the same. A one pound difference makes a small but noticeable difference in the behavior of the rear end.
I don't really give a shit whether you believe me or not, and there really isn't any point in debating something when you're not willing to accept its possibility in the first place. So I guess we're done.
Ahh, so now we've gone from 1psi to 3psi.
Keep up the street racing, just make sure not to spill your Monster.
Old 04-23-2015, 09:21 AM   #18
babydriver
Hit the road and I'm gone
babydriver's Avatar
This:
Variance is +/-0.1 psi
Anyway, as long as the pressure gauge is consistent with itself to within 0.1 psi, it doesn't matter if it agrees with a barometer precisely or not. I simply need to find the pressure that works best for the tires and the car and keep it there.
Slip, slidin' away.
Old 04-23-2015, 09:40 AM   #19
DarkSunrise
DarkSunrise's Avatar
Was anyone else reminded of this classic thread from Jalopnik?
http://jalopnik.com/how-not-to-expla...s-b-1677523538
Video of the dude crashing because his right tire was 1.5 psi higher than his left:
http://jalopnik.com/this-asshat-bmw-...fk9g,pexi6me2k
2022 BRZ Build
2013 FR-S Build
Old 04-23-2015, 09:48 AM   #20
mrk1
Drives: Sterling BRZ Ltd
yeah that was pretty funny, just admit you messed up dont dig a big hole for yourself.
Back on topic of tire pressure I can't say I can pick out which tire is down a hair but I certainly notice the change after a track session.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 04-23-2015, 03:38 PM   #21
chas3wba0
chas3wba0's Avatar
Drives: Yes
Yea, I can't believe nobody got my reference... nubZ
Old 04-23-2015, 08:13 PM   #22
Gunman
Drives: 2019 Mazda Miata RF
This:
Attachment 107757
Are you using a tire pyrometer to take temps across the tire, or basing this simply on driver "feel"?
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 11:27 PM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 11:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 01:46 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 11:49 AM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 06:47 AM
