Old 04-22-2015, 04:43 PM   #15
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by murdoc View Post
I feel like if the RPM gap was always the same, shifting from third to second at 10 MPH would take you from ~800 RPM to around 2700 RPM, since doing it at 60 MPH will increase RPM by about 2000.
You are right, I am wrong.
I was picturing the engine RPM vs drivshaft RPM graph having all of hte lines parallel.
However all 6 gear plots have y-intercepts of zero, so the lines are not parallel.
So transitioning from one gear to another when low in the RPM range is a smaller jump than doing it at high RPM.
Sorry bout that.
The Following 2 Users Say Thank You to stugray For This Useful Post:
fika84 (04-23-2015), murdoc (04-22-2015)
Old 04-22-2015, 05:00 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by krayzie View Post
Why don't you just double clutch downshift from 3 to 2?
Originally Posted by Jfheisenberg View Post
Yeah, im not very familiar with double clutch and i haven't try the hill and toe method yet.
Because double clutching is a method used in trucks (and sometimes cars) without synchros.
If you have a modern transmission with a synchro, there would be zero need to double clutch unless you are doing it wrong or hesitate too much between shifts.
-alex
Old 04-22-2015, 06:11 PM   #17
ryoma
ryoma's Avatar
I found it hard to rev match in this car when I first got it. I think it's due to the DBW and I feel that the pedal response is sluggish. I definitely notice a little dead zone area when I push the pedal down about 1 cm. Maybe I was spoiled by my old MR2 that uses a throttle cable. loved the response with an actual cable instead of this new electronic crap. that and the clutch pedal is one of the things I still haven't gotten real used to in this car yet.
Old 04-22-2015, 09:43 PM   #18
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
-alex
This is correct there is no need to double clutch due to synchros (triple cone synchros too for the first 3 gears in this car) but it's just another skill to have, very useful when the gearbox tends to hesitate 2nd gear in very cold winter mornings.
Yes DBW and dare I say electric steering also, no matter how good they get just can't replicate the responsiveness and feel of old skool cable throttle and hydraulic power steering.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Ultramaroon (04-22-2015)
Old 04-22-2015, 10:03 PM   #19
JS + BRZ
Drives: 2010 MS3
Clutch in, Blip the throttle, Downshift.
This doesn't work for 2nd gear??
No need for double clutching.
Old 04-22-2015, 10:37 PM   #20
D_Thissen
D_Thissen's Avatar
I think going in to 2nd needs a slightly bigger blip then the other gears. I'll have to see when I drive it.
Old 04-22-2015, 10:51 PM   #21
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I have a question to ask on a related topic.
When peformance driving, is there a general RPM which, once you drop below, you downshift so as to remain on power? IE, Revs drop below 4.5k you downshift. Drop below 5k. Etc.
I ask because I put myself in a dangerous situation, both mechanically and mortally, by under revving on a downshift when going around a corner.
The situation: Navigating a diminishing radius corner, third gear but decelerating gradually as the corner got tighter. Next their comes a pretty sharp kink--I was going around 50-55, can't be sure. Revs at/around five. I go for it, initiating a quick heel/toe which I didn't match properly. Think I needed to hit near 6.5 or so, which I didn't. Don't know how much I missed by, but the rears locked as I was turning in (still on the sweeping part) and as a result my rear kicked out alarmingly quick. Thankfully I caught it. Dangerous situation I put myself in; my nose was angled directly toward the ditch. Desolate road so there were no oncoming cars ( I could see through corner.)
Anyways, haven't driven that hard since then, which was a couple weeks ago, nor have I returned to that road.
So you downshift when you dip below what RPMs when performance driving? I'd like to find out if there is a sweet spot most people adhere to.
ajaxthebetter is offline   Reply With Quote
Old 04-22-2015, 10:59 PM   #22
Crestwood1001
Drives: 2013 BRZ Limited (GBS)
For whatever reason when you blip the throttle going from third to second the rpm's don't rise as fast as going to other gears. Next time watch your tach as you downshift through gears and you will see the difference. Iv had good luck just giving it a split second more on the throttle going into second
Crestwood1001 is offline   Reply With Quote
Old 04-22-2015, 11:02 PM   #23
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
If I'm not on the track I'll let the revs drop pretty low. I'd probably try to stay above at least 4k in hard street driving, that way you're not in the torque dip.
The Following User Says Thank You to DocWalt For This Useful Post:
ajaxthebetter (04-22-2015)
Old 04-22-2015, 11:19 PM   #24
Vroomin86
Drives: 2015 Fire
Blip twice that's what I do works every time
Vroomin86 is offline   Reply With Quote
The Following User Says Thank You to Vroomin86 For This Useful Post:
ARTBRZ (04-23-2015)
Old 04-22-2015, 11:25 PM   #25
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Why not just give it a bit more throttle?
Old 04-23-2015, 12:04 AM   #26
SR5
SR5's Avatar
Drives: Raven
Post Electronic Drive By Wire
Originally Posted by ARTBRZ View Post
This is my first manual so I have a simple question that I haven't been able to find through search. So I've been able to rev match well going to 5th, 4th and 3rd well but not to 2nd gear. I'd say I blip it about 700 rpm to get a smooth downshift without lunging forward in the other gears. I've tried a few times rev matching to second and it's a horrible feeling. I want to get a reference how much to blip because I feel that I'm going to wear down my clutch or mess up something before I figure it out.
So how much do you guys blip the throttle when going to 2nd gear (with or without A/C on)?
good observation for this being your first manual car. 2nd gear is a bit more difficult to downshift to.
First off, the stock Electronic Drive-by-Wire doesn't make it any easier.
It's a bit miss leading as far as throttle, speed, & gear.
My DC2 (cable throttle) felt easier to downshift into 2nd, using the same amount of throttle in any gear.
Secondly, 2.188 gear ratio and 4.100 final is fairly short when you compare it to other gears.
So, you have to give it more throttle than if you were downshifting from 4th-to-3rd.
just as an example downshifting from 3rd-to-2nd:
while in 3rd gear at 25mph give it to about 3100rpm then shift. It should go right in! However, notice it feels like you have to give it more throttle than if you were downshifting from 4th-to-3rd.
something smelly, and you still have crickets..
SR5 is offline   Reply With Quote
The Following User Says Thank You to SR5 For This Useful Post:
ARTBRZ (04-23-2015)
Old 04-23-2015, 01:03 AM   #27
Vroomin86
Drives: 2015 Fire
I find it more controllable and smoother shifts when I blip once, it climbs a few hundred rpms which puts the second blip already on a head start in higher rpm, then again I also tend to mostly engage 2nd on the coming down of the second blip when downshifting. If I was driving through a very spirited course or track I'd probably just give it a bit more throttle like you mentioned.
I am referring more to daily driving for blipping twice.
Old 04-23-2015, 03:30 AM   #28
humdizzle
Drives: 2018 GT3 / 2015 M3
like everyone else said. clutch in -> blip throttle -> throw it into lower gear -> let clutch out. eventually you will get good at it and do it one fluid motion.
however with hard driving you will want to heel-toe. same as above except you are using your toes to brake and your heel to blip throttle
practice, practice, practice... thats the only way you will get good. I found the BRZ to be very easy to heel-toe.
2018 GT3 6MT
2021 M2 Comp DCT
Past: 458 Italia, R35 GTR, E36/E46/F80 M3, 335i, Scion FRS
humdizzle is offline   Reply With Quote
AT not rev matching? Bergen23 Issues | Warranty | Recalls / TSB 25 12-17-2015 07:35 PM
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 02:09 PM
Matching With the Beasts fang_gt86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 06-06-2014 12:33 PM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 01:03 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 05:48 PM
