Old 06-12-2013, 09:49 PM   #1
twoodcc
Drives: BRZ Limited 6M
rev matching
ok i grew up on small 4 cylinder engines - all with manual transmissions. however, i was never taught to rev match. i was always taught to change gears early (below 3k rpm) to save on gas.
all i do to change gears is - let off gas, push in clutch, change gear, as i'm letting out clutch, i push on the gas, sometime hold the clutch in the sweet spot for half a sec, and then let all the way out.
i'm usually very smooth with changing gears at low rpms. however with sometimes lately i'm not as smooth, especially at higher rpms. i'm not over 1,000 miles yet in my brz, so i haven't pushed it yet. what should i be doing?
thanks in advance
twoodcc is offline   Reply With Quote
Old 06-12-2013, 09:51 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Search for heel and toe technique
86_ZN6 is offline   Reply With Quote
Old 06-13-2013, 12:32 AM   #3
Dalers08
Drives: 2001 Audi A4
First off, rev-matching is only used on downshifts not upshifts.
Second, "sometimes hold the clutch in the sweet spot for a half a second", you shouldn't need to do this, that's just slipping that clutch. Just smooth motions off the clutch and on the gas.
Third, the whole point of rev-matching is when you downshift you want to match the RPMs the engine is going to be at, therefore saving some clutch life and just a smoother ride... and bonus cool points!
Lets say you are going to downshift 4th to 3rd:
You're at 4th gear at 2500rpms, a turn is approaching...
Clutch in, shift knob to 3rd gear, "blip throttle" to what the RPM's WILL be at when you engage third, probably around 3300-3500rpms, let clutch out. It should be quick and smooth and you should feel nothing in the motion of the car, no engine braking. The longer you take to blip the throttle the less smooth you will be. It's not hard to get the hang of it.
Now heel-toeing is when it gets fun! It is the same thing as a rev-match but lets just say that you are in the same situation but that corner is approaching quickly and you want to be a badass, you heel-toe that bitch!
Brake with the LEFT side of your RIGHT foot, clutch in (keep braking), rev-match the gas with the RIGHT side of your RIGHT foot (keep braking), clutch out, right pedal down!
All of this just takes practice, learn to rev-match first, then heel-toe that sumbitch!
I hope this all made sense...
EDIT: Some people are more comfortable with the 50/50 style (left side of right foot on brake, right side on gas), some people like the traditional heel on brake, toe on gas. It's up to you to see what you like.
Dalers08 is offline   Reply With Quote
The Following 7 Users Say Thank You to Dalers08 For This Useful Post:
br_z1Lch (10-04-2013), Jolaessss (10-08-2013), onefitz (10-02-2013), Psilox (03-07-2017), Techfl3x (06-14-2013), twoodcc (06-13-2013), Winjr (10-12-2013)
Old 06-13-2013, 12:39 AM   #4
sho220
sho220's Avatar
Drives: FR-S MT & FJ Cruiser
For those people with upside down feet...
Some will fall in love with life and drink it from a fountain
That is pouring like an avalanche comin' down the mountain
sho220 is offline   Reply With Quote
The Following 3 Users Say Thank You to sho220 For This Useful Post:
DAEMANO (10-05-2013), Ganthrithor (10-01-2013), NCItaly (10-03-2013)
Old 06-13-2013, 12:44 AM   #5
Dalers08
And broken/double jointed ankles! Never understood how people do it.
Old 06-13-2013, 12:49 AM   #6
sho220
sho220's Avatar
I just use the left side of my foot for the brake and the right side to blip the throttle. My ankles don't cooperate when I try the normal heel/toe method...
Old 06-13-2013, 12:54 AM   #7
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
ok i grew up on small 4 cylinder engines - all with manual transmissions. however, i was never taught to rev match....
Rev match = clutch + throttle to make RPM go up + downshift one gear and release
You can practice this on the highway when you are in 6th gear going 60mph. Keeping your eyes on the RPM needle(and the road), try going from 6th gear to 5th gear and clutch in + press the throttle and then release clutch.
If the needle drops that means you need to give it less gas, but if the needle went up, that means you need to give it more gas. If you fail, go back to 60mph and try again, it should be smooth as butter when you let go of the clutch. I did this for two days and now I'm pro at every gear and RPM and any speed, takes time to learn, so goodluck my friend.
LeeMaster is offline   Reply With Quote
The Following 3 Users Say Thank You to LeeMaster For This Useful Post:
chanomatik (10-02-2013), Marcoscrdo (11-04-2013), twoodcc (06-13-2013)
Old 06-13-2013, 12:55 AM   #8
KKaWing
KKaWing's Avatar
Drives: Nissan Versa
[ame="https://www.youtube.com/watch?v=VxGtx9xXhlM"]Heel and Toe Braking - Shifting Technique Tutorial: Hooked On Driving - YouTube[/ame]
KKaWing is offline   Reply With Quote
The Following 2 Users Say Thank You to KKaWing For This Useful Post:
Namuna (01-21-2014), OAKOS Automotive (01-28-2014)
Old 06-13-2013, 10:09 PM   #9
twoodcc
thanks everyone for the replies. i plan on practicing this weekend.
What about double clutching?
Old 06-13-2013, 10:58 PM   #10
ZDan
ZDan's Avatar
Drives: '23 BRZ
Synchro box, no need. I didn't have to double-clutch the gearbox in my 1971 240Z, you surely shouldn't have to in a 2013 BRZ...
Old 06-13-2013, 11:05 PM   #11
LeeMaster
Red wine
Dont worry about it, you will never need to do it in this car
Old 06-13-2013, 11:16 PM   #12
KKaWing
KKaWing's Avatar
You don't need do this for the car. That said, it is kind of like heel-toe, but the steps are more separated. The purpose of this is to make the speed of the different parts match so you could shift into gear, if they don't match, it'll *cruunnnchhhh*. This "matching" is now done by the synchro, so it is basically an "out of date" technique... unless you drive trucks or have a broken synchro(s).
What you actually do is pretty similar. You clutch in, shift to neutral and let out the clutch, then rev-match (blip throttle, heel-toe, w/e). After that you clutch in and shift into gear. "Heel-toe" skips the clutch out in neutral part and goes straight to the gear you want.
Have fun, be safe.
The Following User Says Thank You to KKaWing For This Useful Post:
twoodcc (06-14-2013)
Old 06-14-2013, 04:42 PM   #13
twoodcc
thanks everyone for the clarification!
Old 06-14-2013, 04:48 PM   #14
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
My first car had fucked up synchros, it was a 90 celica.
I've been double clutching and rev matching all my cars ever since. The 86 is a joy to do it in, I barely use my brakes in town lol. They're great techniques to master...it's just how much you want to put effort into it.
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
frsvr4 (10-04-2013)
Matching car seat Yruyur Scion FR-S / Toyota 86 GT86 General Forum 13 05-05-2013 10:26 AM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 06:48 PM
Color matching? the Red Devil Scion FR-S / Toyota 86 GT86 General Forum 7 09-14-2012 01:01 PM
Matching shocks with springs Ben_G Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-22-2012 10:32 PM
Color Matching Headlights? i2ex FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 06-23-2012 09:01 PM
