#71 | |
Turning is for Nerds
Drives: 35 characters is not enough
#72 | |
Drives: Subaru BRZ, Toyota MR2 Turbo
Thread size on the pan is: 1/2" NPT. |
#73 | |
Drives: Scion FRS 10 Series AVO Turbo
Pitman, I received the Oil Pan a few weeks ago and installed it on the FRS. Their was one spot on the Pan where I had to contact @racerx1715 as it touched with the AVO Header. I still have the Oil Pan on the car and still driving it at this point. Jeff stated he was going to look into that.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
| The Following 2 Users Say Thank You to DesertFrs For This Useful Post: | Jeff@Racer X Fab (05-20-2014), Pitman (05-18-2014) |
#74 |
Edit: I learned if you raise the motor it will tilt the engine forward enough to where there is room between the front crossmember and the pan to get a socket on the back three bolts. So you don't have to take out any motor mounts, just take off the nuts holding them to the crossmember.
Also don't take the drain plug out after you put the pan on the car, because by the time you do oil will have collected there and drip on you... Last edited by xwd; 06-16-2014 at 06:47 PM. |
| The Following User Says Thank You to xwd For This Useful Post: | Jeff@Racer X Fab (06-17-2014) |
#75 |
Drives: ft86
does it fit on nameless header?
#76 |
We have confirmed fitment on the following headers/turbo kits:
OEM header no heat shield P&L header JDL header JDL turbo kit AVO turbo kit (Rev 2 oil pan) We have had 2 customers that used the Nameless header but have not had confirmation on fitment. |
#77 |
Drives: 128i
Do you have any customers that have confirmed fitment with the OpenFlash Header?
| The Following User Says Thank You to normancw For This Useful Post: | DAEMANO (02-03-2015) |
#78 |
#79 |
Drives: '92 GS-R, '02 RSX-S, '14 BRZ
Racer X Pan does not fit with FA20 club turbo manifold. It hits on the right side. If you smash in the tube it works though lol.
JDL clears like a champ.
PTE 5758, Turbosmart, JDL, Perrin, Tein, Rays Gramlights, Sumitomo, Raceseng, Beatrush, Buddy Club, Valenti, DSS, Act, Cartboy, Mtec, APR, Beatsonic, FA20CLUB, Radium, JPM Coachworks, VIS, Recaro, IAG, Cleib, Nameless, Zele
Coming soon: Garage Vary, Cleib, Cravenspeed, VEI |
| The Following User Says Thank You to 1BadFA20 For This Useful Post: | Jeff@Racer X Fab (04-17-2015) |
#80 |
JHerbert Racing
Drives: 2013 Scion FRS
Any confirmation that this clears a Openflash Header?
#81 |
Drives: GBS BRZ Harrop SC/PTuning Header
Came from the MR2 community where we all loved your products. I have PTuning headers and would like to be a part of testing the clearance.
| The Following User Says Thank You to Trefoil For This Useful Post: | RJasonKlein (04-16-2015) |
#82 |
Drives: 2013 Scion FR-S 10 Series
Yes, please report back your results - I have the PTUNING header and would like to know if the Racer X Fabrication oil pan clears our header.
#83 |
No, we have not had any customers use the oil pan with the Openflash header. If you would like to try test fitting the pan send a PM or email to info@racerxfabrication.com
Thanks!! Same, we have not had a test fit with the PTuning header feel free to PM or email if interested. |
| The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post: | Trefoil (04-19-2015) |
| Racer X Fabrication air intake design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 45 | 08-01-2019 12:29 PM |
| Racer X Fabrication suspension parts, and development | Jeff@Racer X Fab | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 134 | 09-01-2016 05:02 AM |
| Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! | Jeff@Racer X Fab | Groupbuys | 74 | 06-23-2014 09:08 AM |
| Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! | Jeff@Racer X Fab | Brakes, Suspension, Chassis | 25 | 01-24-2014 11:42 AM |
| Racer X Fabrication, New vendor intro | Jeff@Racer X Fab | Announcements, Contests, Giveaways | 0 | 03-12-2013 11:50 AM |
