Old 04-16-2015, 04:38 PM   #1
mrk1
Drives: Sterling BRZ Ltd
My BRZ is Alive!! Upgraded Final Drive
My car has woken up, it now drives like it looks.
I just finished my 4.44 final drive install. My car is currently just about stock so 4.44 is a mild choice but still woke the car up nicely. It doesn't feel like a econo car anymore.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 8 Users Say Thank You to mrk1 For This Useful Post:
aagun (04-18-2015), DustinS (04-18-2015), DylanJZA (05-03-2023), jcw99 (01-20-2017), Koa (04-16-2015), new2subaru (12-28-2015), niceguy21 (04-17-2015), RazBRZ (04-18-2015)
Old 04-16-2015, 04:49 PM   #2
swarb
Vids or pics on how it looks so I can see how it drives.
Where did you get the parts from?
Old 04-16-2015, 05:04 PM   #3
mrk1
I don't know how to capture it on camera without doing a before and after video. The car is just more eager to go and quick through the gears. With a stock motor is still not exactly fast but its way more fun to drive. I only did a 4.44 because I have a turbo going back on but this upgrade gave the car the push it needed to feel like the sports car it should be.
I got the gear set from MFactory, rebuild kit from Weir, and some seals and shims from the dealer.
I see people spending so much money on different exhausts and intakes chasing 2 more hp. Honestly if you are staying NA go with a 4.56 or 4.67 and it will be money way way better spent.
The Build Thread
The Following 14 Users Say Thank You to mrk1 For This Useful Post:
86 South Africa (12-28-2015), airjonny (11-08-2015), Ammunition (12-28-2015), calmtigers (04-16-2015), DustinS (04-18-2015), DylanJZA (05-03-2023), GotBRZ1691 (04-17-2015), jcw99 (08-01-2016), Koa (04-16-2015), Lonewolf (04-16-2015), raven1231 (04-16-2015), SkAsphalt (04-16-2015), swarb (04-17-2015), Teseo (04-16-2015)
Old 04-16-2015, 05:07 PM   #4
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
invisible drive shaft mod!
jkjk I really wanna drive a car with different final drive to decide if I wanna do it!
The Following 4 Users Say Thank You to continuecrushing For This Useful Post:
alexand3r (04-16-2015), hmong337 (04-16-2015), raven1231 (04-16-2015), TouchMyHonda (02-11-2016)
Old 04-16-2015, 05:25 PM   #5
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
This, but I'd have to drive the car for about a week or so to see if the gains are worth the drawbacks.
Bobblehead is offline   Reply With Quote
Old 04-16-2015, 05:27 PM   #6
raven1231
+3 I had been on the fence about this for awhile
Old 04-16-2015, 05:27 PM   #7
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I have the automatic and went with 4.88s. Best mod I have done to the car.
1 second off my 0 to 60 time
1.5 seconds off my 30 mph to 70 mph time.
Lunatic is offline   Reply With Quote
The Following 8 Users Say Thank You to Lunatic For This Useful Post:
continuecrushing (04-16-2015), MGPAX (06-24-2016), mrk1 (04-16-2015), new2subaru (12-28-2015), raven1231 (04-16-2015), Teseo (04-16-2015), Thunderleg (04-17-2015), TouchMyHonda (02-11-2016)
Old 04-16-2015, 06:52 PM   #8
stevesnj
stevesnj's Avatar
Much more reliable and less expensive than any FI. Very simple and will work great with taller wheels and tires. Milage could suffer. Depends on the tire height and how you are on the skinny pedal.
My 2016 Build thread
Old 04-16-2015, 06:54 PM   #9
mrk1
I think the gas mileage offset is over exaggerated, yes going real high will have an effect but your right foot makes more of a difference then anything.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
jcw99 (08-01-2016)
Old 04-16-2015, 08:23 PM   #10
kch
Senior Misanthrope
kch's Avatar
What are your RPMs at highway speeds? That's my major concern - I don't want to be screaming at 5k going 80.
Old 04-16-2015, 08:42 PM   #11
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its a slight upgrade from the stock (4.1?) So 6th crusing rpms at 80 mph wouldnt be much off what it is stock. I'll let someone else do the calcualtions.
Old 04-16-2015, 08:59 PM   #12
mrk1
80mph with be like 3700 with a 4.56 final drive, stock is just under 3500, so my 4.44 should be around 3600. Not at all what I would call screaming.
The Build Thread
Old 04-16-2015, 09:01 PM   #13
swarb
^really? that is not bad at all. Can you reconfirm? Why did you go 4.44 instead of 4.56? I thought it was closer to 500-600 rpm difference.
Old 04-16-2015, 09:06 PM   #14
mrk1
I have charts from Cusco but cant load them up in a legible size. I went with 4.44 because I have a turbo going on so don't need to go as high.
The Build Thread
4.8 final drive drift86 Engine, Exhaust, Transmission 29 11-28-2022 12:49 PM
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Final Drive 4.67 Bongertz Engine, Exhaust, Transmission 33 09-02-2015 03:11 PM
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE Transmission and Driveline 0 01-09-2015 08:09 AM
3.3 Final drive? Manji Engine, Exhaust, Transmission 18 01-01-2015 02:51 PM
