#141 | |
Drives: 23 BRZ
Winmax W4's, stock rotors/calipers, stainless steel braided lines. The Winmax guy that was at the track measured the temps after I pulled off the track, 290 up front and 220 in the rear I believe. |
| The Following User Says Thank You to rb6freak For This Useful Post: | Hicklinc (01-30-2018) |
#142 |
Drives: 23 BRZ
Finally finished the strut tower braces that clear the 4" PTuning turbo intake pipe.
![]() Got my header and turbo pipes back from ceramic coating. Two coats. ![]() Can't wait to get the car back together and fire it up!
#143 |
Just a dude
Drives: Scion FR-S 2013
Wow those pieces look sweet.
![]() Side note and forgive me if you have mentioned. Being you're in Cali are you running any additives or just straight 91 for most part. The Ptuning kit is very very nice just not sure with my crap gas also 91 makes this the kit to go with. I see you use 101 for race days but not certain of your thoughts of the kits power and driveability on 91?
| The Following User Says Thank You to OICU812 For This Useful Post: | rb6freak (11-15-2014) |
#144 | |
Drives: 23 BRZ
I use 100 for track days to maintain the power. I raise the boost at this octane as well. If 100 is not available I'll use a can of Torco which seems to help, but certainly not anywhere as good as pure 100. I'm considering water/meth in the near future as it will be cheaper in the long run, rather than refilling 100 at the track every time which is $10.00 USD a gallon. Race gas cost adds up quick. |
#145 |
Drives: 23 BRZ
Last couple photos before it goes on the car.
#147 |
Drives: 23 BRZ
I'm not really sure. Maybe +20 whp on a mustang dyno. Not really concerned about making a lot more power. Consistency, reliability, heat management are my focus :-)
I will have dyno numbers though, once the tune is redialled. |
| The Following User Says Thank You to rb6freak For This Useful Post: | Bramick (11-21-2014) |
#148 |
Drives: 23 BRZ
PTuning header installed and it sounds better than I imagined in the higher rev range. Can't comment on power yet as I'm still re-tuning. Only a couple more mods coming in until I call my build complete. More track videos to come soon. Also will be getting another dyno chart once my re-tune is complete.
Exhaust sounds with the PTuning header now on. [ame]http://youtu.be/A5w54dudo24[/ame] 6000 Mile Check-In [ame]http://youtu.be/pIz60Kb--cM[/ame] |
#149 | |
Drives: 2013 BRZ Limited M/T
Any brake set thoughts yet?
ps. I just ordered the same Rota wheel setup, but will be going with Michelin Pilot Super Sport tires as my car is a daily driver. Quote:
#150 | |
Drives: 23 BRZ
I've since switched to Toyo R888 tires and I enjoy them much more than the Yokohama A048 tires. As for brakes my Winmax W4 pads just ran out at my last track event so I have already purchased the AP Racing Spring kit. As for pads, either the RC6 or the 999's depending on availability before Laguna Seca in May. I'm still rocking the PTuning red stainless lines and Torque RT700 fluid. For daily driving street pads are just fine. If you track then definitely upgrade at least the compound, lines and fluid. |
#151 | |
Drives: 13' Scion FR-S Firestorm MT
| The Following User Says Thank You to jchudson13 For This Useful Post: | rb6freak (04-15-2015) |
#152 |
Drives: 2010 MS3
Lovely set up man.. do you ever go up to the canyon!? Would love to get a ride!
| The Following User Says Thank You to JS + BRZ For This Useful Post: | rb6freak (04-15-2015) |
#153 |
Should change thread title to "Just Another (Sexy as fuck Ptuning turbo) build
#154 |
Drives: 23 BRZ
I've been to GMR once with the crew but I haven't received an invite since then. I would be up for going again, keep me in the loop.
| AVO turbo kit for BRZ - initial build thread | AVOturboworld | Forced Induction | 3109 | 12-01-2019 03:55 PM |
| My trip to FBM - FBM Premium Turbo Kit build | brzaapi | Forced Induction | 170 | 11-12-2013 06:04 PM |
| 400hp build and other turbo questions. | Ludacrits | Forced Induction | 22 | 10-26-2013 09:01 AM |
| Just wanted to show off my turbo build | sw20kosh | Forced Induction | 5 | 04-01-2013 03:16 PM |
| Turbo engine build, and parts | No Limit Motorsport | Forced Induction | 30 | 12-11-2012 07:32 PM |
