Old 04-09-2015, 08:50 PM   #267
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by AZP Installs View Post
Not any brembos actually. Most of the brembo equipped Subarus are 5x114 (except the 2004 STi) so if you just bought rotors for a brembo equipped car they won't bolt onto your hubs.
-mike
Thanks. Yeah I should have been more specific. Some rotors like the DBA one's come dual drilled, but otherwise yes you'll need to get it drilled for 5x100.
Fizz is offline   Reply With Quote
Old 04-14-2015, 07:32 AM   #268
mister.bond
Drives: BRZ Subaru
So, i have lots of news and i am a little bit confused now about the Swap
i try to find out all informations about the REAL BRZ tS Brembo Brake Set
LINK : https://www.japanparts.com/parts/detail/45055
but its very hard to get as STI Company is more than a book with seven seals
So, i try to give you all info´s they gave me the last days
sorry for my english, i´am from Germany and its hard to write for me....
So, first i can say that i have a full 2011 WRX STI Caliper Set here in my room :-)
but the more i read and infos i get the i do not know what to do for the Swap to my BRZ as i want it as clean without cutting or flex or bending anything from the parts like Dustshields.......
I found out that There are new tS Brembo Brake Parts availible
1. There is a specially TIE BAR availible that is needed for the Front Caliper Installation on both sides !
see the PIC :
and the Link to that stuff :
https://www.japanparts.com/parts/detail/31544
Do we need it ???
2. The Dusthields / Backplates for Front and Rear are also ready for Order
Link : https://www.japanparts.com/parts/detail/36467
can i use them ???
3 : for the REAR there is also a Parking-brake Set for BRZ tS availible
Link : https://www.japanparts.com/parts/list.php?pv=japanparts14-forTS0410-&dl=&cm=&md_sm=&pm=&adt=1
here are pics from Front and Rear for tS Brembo Brake Set
so, my question is :
can i install those things with the WRX STI 2011 Calipers ???
i think the Front Dustshields are a really good option for the complete look without cutting the old Dustshields ( i do not like to flex or cutting on new BRZ )
but what about the REAR Backplate ? can i use the tS Rear Backplate with my old Parking brake inside ??? or do i need the new Parking brake from
tS also ???
and when i also install the NEW tS Handbrake , what Discs do we need then ????
i hope for help
cheers , Thomas
mister.bond is offline   Reply With Quote
Old 04-14-2015, 11:32 AM   #269
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
That bar isn't neccesary, but if you do install it make sure you get the correct longer bolts. Actually I believe they first used it in the 05 model STi but removed it the next year. Or something like that.
Old 04-14-2015, 04:19 PM   #270
mister.bond
Drives: BRZ Subaru
thank you very much for help
can someone please give me that Partnumber from the TIE BARS please ???
i think they are normal Subaru Part
Old 04-14-2015, 07:27 PM   #271
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
They were only on the 05 IIRC, not needed really they were put in as an anti-oscillation item but then they realized they didn't need them.
-mike
AZP Installs is offline   Reply With Quote
Old 04-15-2015, 05:51 AM   #272
mister.bond
Drives: BRZ Subaru
Please, can soeone please give me Subaru Partnumber of that
Old 04-15-2015, 07:26 AM   #273
AZP Installs
The real question is why do you want it? I'm not even sure it will work on the reverse mounting we have on the BRZs.
If you REALLY need the part number, call your dealer and tell them you have a 2005 STi and I'm sure they can provide it for you.
-mike
Old 04-17-2015, 06:40 AM   #274
mister.bond
Drives: BRZ Subaru
i want to use it , cause the REAL BRZ tS use it , too.
so it cannot be wrong i think so..........
Old 06-03-2015, 03:13 AM   #275
fooyc
fooyc's Avatar
Drives: GT86-JDM
for the front & rear rotors, u guys can just buy the match size for STI brembo. most aftermarket now all hv dual PCD (100 or 114.3), both r PnP into 86/brz.
fooyc is offline   Reply With Quote
Old 06-03-2015, 06:29 AM   #276
AZP Installs
Is the rear parking brake drum correct on those? We haven't done one in a while but on some setups the parking brake doesn't work well.
-mike
Old 07-22-2015, 05:18 AM   #277
fooyc
fooyc's Avatar
Drives: GT86-JDM
for me yes. cos the rear rotor was a spare rotor for my JDM ver 8 STI.
note: both my 86 & STI are JDM import.
cos the wrx rear drum is smaller then the STI rear drum.
Old 10-21-2015, 04:31 PM   #278
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
So I completed this brembo conversion over the summer using brand new 2013 calipers, Hawk HPS pads and DBA 4000 rotors. I also successfully flipped the bleeders so that the pistons run in the proper orientation.
I now have exceedingly squeaky brakes coming to a stop at low speeds ESPECIALLY when I have the wheel turned. Having done my research, brembos seem to squeal naturally... or do they? Some said yes, some said no, some said hawk pads squeal, some said they didn't, some said grease the pistons; regardless I would like to know if anyone is experiencing this annoying squeal and if there is a solution. Thanks!
kuczynskika is offline   Reply With Quote
The Following User Says Thank You to kuczynskika For This Useful Post:
chaoskaze (10-21-2015)
Old 10-21-2015, 05:26 PM   #279
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I have always had squeaky brakes when using Hawk pads. Over 3 different Cars.
Old 10-21-2015, 05:28 PM   #280
kuczynskika
Right? Then others say Hawks are super quiet...
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 12:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 05:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
