Old 04-13-2015, 09:29 AM   #8569
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by TM View Post
Does the procede controller only tap into the ESC system or does it tap into other wires in the car as well? How easy would it be to uninstall the ESC kit with the procede controller tapped into the car?
It taps into a couple of wires in the car. (Crank position sensor and DBW throttle blade sensor) you could keep the procede in and remove the esc and no one would be the wiser.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
Fareast auto part (04-14-2015), Gums (04-13-2015), TM (04-15-2015)
Old 04-13-2015, 09:43 AM   #8570
Sojhinn
Sojhinn's Avatar
Originally Posted by DAEMANO View Post
I cant see your pics, but the fuse does stick out a bit more than the others. You'll know its in all the way when it wont go in any further and if the ESC turns on when the car is turned on.
Installed Mods:
The Following 4 Users Say Thank You to Sojhinn For This Useful Post:
Fareast auto part (04-14-2015), Robftss (04-13-2015), SimplePortal (04-13-2015), SOAZ (04-13-2015)
Old 04-13-2015, 10:14 AM   #8571
Robftss
Drives: VW
Originally Posted by SimplePortal View Post
So I'm started on installing the kit I just received. I'm not sure if I got the alignment correct for the ESC. It looks off center and pointing a bit down. It felt like the silicon tube provided for the throttle body was a little bit short or maybe I installed it wrong.
Also is the fuse suppose to stick out higher than the others, am I not suppose to be able to put the fuse box cover back on?
Here is the pic on the install instructions, there is a gap (adjustable) between the two silicone couplers.
Name:  comp anglittle.JPG
Robftss is offline   Reply With Quote
The Following 3 Users Say Thank You to Robftss For This Useful Post:
Fareast auto part (04-14-2015), raven1231 (04-13-2015), SimplePortal (04-13-2015)
Old 04-13-2015, 06:35 PM   #8572
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Originally Posted by tyrantcf View Post
I do believe some of the credit for selling you on it is mine though
You and Granite Road, haha. When I bought the car I partly had the mindset of "I need more power because the forums say so!" but after actually driving it on challenging roads I've come to the conclusion that I just need some more oomph when it comes to coming off the line, passing at speed, and on ramps / out of turns.
I thought I'd have to get that via JRSC, but after our chats and reading through the thread I realized I can get it for about the same price as the JRSC install would've cost me, let alone the whole setup
Now will the Procede controller add to the cost of the full setup? I'm assuming so but I want to have an idea of how much to save up for when my spot on the list comes up.
Old 04-13-2015, 07:41 PM   #8573
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile
Hi guys,
Procede ESC Controllers are NOW AVAILABLE
Limited quantity. All orders will ship out by the end of this week.
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
07jazzrs5gt86 (04-13-2015), DAEMANO (04-13-2015), Fareast auto part (04-14-2015), Gums (04-13-2015), KoolBRZ (04-14-2015), raven1231 (04-13-2015), VR46 (04-13-2015), WRB5titch (04-13-2015), zc06_kisstherain (04-13-2015)
Old 04-13-2015, 07:42 PM   #8574
DAEMANO
Time Traveller
Originally Posted by Shiv@Openflash View Post
Hi guys,
Cheers,
Shiv
Ordering
Old 04-13-2015, 07:45 PM   #8575
WRB5titch
Drives: WRBrz
Hi guys,
Cheers,
Shiv
ORDEREDDDD
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
The Following User Says Thank You to WRB5titch For This Useful Post:
Old 04-13-2015, 09:06 PM   #8576
Sojhinn
Sojhinn's Avatar
Hey shiv I'll just take 10% for those two. 😁
Installed Mods:
DAEMANO (04-13-2015), raven1231 (04-13-2015), WRB5titch (04-14-2015)
Old 04-13-2015, 09:34 PM   #8577
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Hi guys,
Cheers,
Shiv
Ordered!
VR46 is offline   Reply With Quote
The Following User Says Thank You to VR46 For This Useful Post:
Old 04-13-2015, 10:14 PM   #8578
PantsDants
Drives: Scion FR-S A/T, Whiteout
(Ordered.)
PantsDants is offline   Reply With Quote
The Following User Says Thank You to PantsDants For This Useful Post:
Old 04-13-2015, 10:21 PM   #8579
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I want to order!!! oh wait! i dont even have ESC yet! sigh sigh
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
Old 04-13-2015, 10:47 PM   #8580
07jazzrs5gt86
Drives: Firestorm 86
Hi guys,
Cheers,
Shiv
Have a few questions
What are the preset ESC activation set to?
If there's an update to the procede software how would I be able to do that?
Also how can I reconfigure the preset values?
Thanks
07jazzrs5gt86 is offline   Reply With Quote
Old 04-14-2015, 01:45 AM   #8581
Shiv@Openflash
Drives: 2013 FRS
Thanks
Good questions.
Much like the OFT, the Procede can be connected to a laptop and programmed/updated using Procede Programming software. When our first firmware update is ready to go live, I'll be posting it up along with the user software.
The programming software will allow you to download the existing map in the Procoded, modify it, or even upload a completely new map of the user's creation.
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
07jazzrs5gt86 (04-14-2015), Blu-by-U (04-14-2015), DAEMANO (04-14-2015), Fareast auto part (04-14-2015), Gums (04-14-2015), Thobjo (04-14-2015), WRB5titch (04-14-2015)
Old 04-14-2015, 09:11 AM   #8582
Account Attempt No. 4
Account Attempt No. 4's Avatar
Drives: 2013 WRB BRZ Limited
Friggin exchange rate USD to CAD.
Shiv open up shop in Canada lol. Calgary Specifically.
Originally Posted by Calum View Post
No it's not. - Yes it is. - It'll make 400 whp. - No, it'll only make 200 whp and break down all the time. - Oil temperatures!! - This will never happen. - But the other kit. - Turbo is better. - No, supercharger is better. - Rotrex sucks. - You suck. - Perrin said. - But Visconti said.
Account Attempt No. 4 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
