Old 04-13-2015, 05:11 PM   #29
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Showed this to our tuner.
Seems you may have resolved the issue, but if it persists, he suggested checking for boost leaks.
If you never did a boost leak check after the turbo kit installation, this would be good to do regardless.
Cheers.
WORKS is offline   Reply With Quote
Old 04-13-2015, 05:22 PM   #30
Synack
Boosted
Synack's Avatar
Drives: Sideways
Cheers.
Yeah I did a boost leak check last week before I even ordered any parts. The majority of my searchable area was post-MAF but there isn't that much distance between the MAF and TB. I sprayed some electrical cleaner in several areas to check for bubbles or to see if the motor sputtered or changed at all. Everything was good.
My car has been much better since replacing the factory AFR O2 (upstream).
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
WORKS (04-13-2015)
Old 04-13-2015, 06:08 PM   #31
AgentFT86
Drives: 2015 Scion FR-S
Used to have two Evos, I'd jump on the socalevo forums and do a search for your problems. It sounds like a boost leak or o2 sensor?
AgentFT86 is offline   Reply With Quote
Old 04-13-2015, 06:15 PM   #32
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
New afr range?
Old 04-13-2015, 08:24 PM   #33
Synack
Boosted
Synack's Avatar
Drives: Sideways
My problem is solved. It was the O2 sensor (AFR specifically), replaced it last Friday.
Old 04-13-2015, 08:27 PM   #34
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by cdrazic93 View Post
New afr range?
Idle - Fluctuates between high 13's and high 14's
Partial throttle - 13's
WOT - 12's, super high 11's rarely.
Pretty sure my tuner gave me a rich tune because they might've been afraid to go leaner, this was back when the car first came out so nobody really knew the limits of the FA20 yet.
Old 04-15-2015, 03:05 PM   #35
Synack
Boosted
Synack's Avatar
Drives: Sideways
And WERE BACK!
5 days later after the stock O2 replacement fixed everything, my car is going full 10:1 at WOT only now. Partial throttle is perfect. Idle is rich, 11-13, 14.7 sometimes.
Suggestions?
Old 04-15-2015, 05:11 PM   #36
Synack
Boosted
Synack's Avatar
Drives: Sideways
A couple people mentioned vaccuum lines could've disconnected.
Supposedly @Sportsguy83 knows a bit about that.
Old 04-15-2015, 06:40 PM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I know more about it then him, but that would be obvious if it were the issue. Just install your Flex Fuel setup and go get a proper tune.
Old 04-15-2015, 07:02 PM   #38
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'm not getting anything extra tuned or installed until I find out this issue. It's not the tune that is the problem because I wouldn't have noticed things being worse and different.
I have the android Torque app running and I just noticed a few things:
  • AFR goes full rich in only lower gears after gas fillup. Just went on the highway and everything was 13's and 14's. Before my fillup all gears were getting straight 10's for AFR on boost.
  • I just filled up the gas tank after it being low and now my "EGR system" reads complete where before the gas fillup it read incomplete.
I don't know what this means but it might be EGR related. Or something in the fuel system isn't operating correctly.
On an additional note, does anyone know what the fuel rails should be seeing for pressure? I seemed to be seeing ~550-1000PSI when viewing in Torque.
Old 04-17-2015, 01:30 PM   #39
aagun
Drives: 86
Fuel rail should 450psi to 650psi at idles and up to 2000psi or 2800psi at wot
aagun is offline   Reply With Quote
Old 04-17-2015, 01:35 PM   #40
aagun
Drives: 86
Now ckeck ur long term and short term . Is should both at 0% and max for long term is 8% . Write the numbers . Drive the car . And log the both . Then if u have tach steam . Go to test injectors. And disconnect the direct injector . The fuel regulater will stop for 5 sec . The long term willl change . Log it
Old 04-17-2015, 01:36 PM   #41
aagun
Drives: 86
Where are u from .. Worm weather ?
Di u have poping . While idle
Go rich cozed by air leakage after maf . Up to afr sensor. . . Or injectors failure by leaking fuel or reduce fuel rate .
Old 04-17-2015, 01:43 PM   #42
Koa
not true, STFT and even LTFTs will vary above and below 0% if the system is operating as normal to account for variances in fuel quality and atmospheric conditions above what the car was tuned for
all your other advice is sound
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 02:55 AM
So what would you say is too Lean? Too Rich ? Opinions Pls. BC-Boy Software Tuning 27 05-29-2014 11:05 PM
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 07:59 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-26-2013 12:42 AM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 12:36 PM
