#15 | |
Drives: 2013 GBS BRZ Limited
However I will repeat myself: Unless one can point out the path of the oil in relation to this particular galley plug, then it is just speculation. My race engine (different 4 cyl boxer) has about 10 different galley plugs and MOST of them would do absolutely zero in helping the engine in a failure. Even if all you care about is pre-oiling (and not saving the engine in a failure), then it STILL matters where you feed the system. Pick the wrong side of a restriction or a VVT valve that may or may-not be open, and the accusump might be useless. You might be 100% correct, but a picture is worth a thousand words. I have a complete diagram of my race engine oil flow. Does anyone have one for this engine? |
#16 |
Drives: GT 86
I have tapped into this plug for my oil pressure as it is after the oil filter .
Its the one directly under the TB wires and I got this pic from a quick google |
#17 |
That Guy
Drives: 2013 asphalt FRS MT
Nothing to see here.
#18 |
Because compromise ®
Drives: Red Herring
Why do you think this is unusual?
#19 |
Drives: 2015 BRZ
Compared to other cars I've had, mostly domestic V8's. The accusump project us on hold until I get an oil pressure gauge so I can see how the oil pressure behaves myself. It may all just be a matter of a higher precharge and rpm switch to prevent losing the oil at idle.
#20 | |
I wish that accusump would make an electric valve that has an adjustable setpoint. |
#21 |
Stig's dark passenger
#22 |
#23 |
#24 | |
Now I guess you need to teach me how to read since I still connot find any mention of an accusump with an " electric valve that has an adjustable setpoint." |
#25 |
Read around in the product tech, it will explain how their valves work
#26 | |
#27 | |
I see no mention of an adjustable pressure sensing valve, but since you are so sure that there is one, you must just be witholding information for the fun of it. There is the 24-270 ACCUSUMP ELECTRIC VALVE - No pressure sensing feature (ON or OFF) 24-271 20-25 PSI sensing 24-271K (upgrade) 20-25 PSI 24-273 35-40 PSI sensing 24-273K (upgrade) 35-40 PSI 24-275 55-60 PSI sensing 24-275K (upgrade) 55-60 PSI It's easy, just post the link to this information that I am so dense as to not be able to find.... |
#28 | |
I never said there is a valve you can manually set.
They have different valves set at different pressures as you yourself have listed. pick a pressure that would be ideal for you. See if there is a valve that corresponds to that pressure. D Quote:
| LCA install | WallsAndFoundations | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 12-16-2014 05:47 AM |
| Which mod to install first .... ?? | humfrz | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 11-09-2013 09:07 PM |
| MTX install | Deadspool | Electronics | Audio | NAV | Infotainment | 1 | 06-27-2013 07:21 AM |
| Where to install amp in FRS? | mit_peid | Electronics | Audio | NAV | Infotainment | 10 | 03-24-2013 01:01 PM |
| Need help with HID install | ortizwyld | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 02-21-2013 11:12 PM |
