Old 04-08-2015, 06:35 PM   #15
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by D K View Post
Gallery plug has no effect on the cooler.
It ties in to the main baring feed.
lot of engines dont uave this so they have to use a sandwich adapter and tie in at the filter.
You sure make it sound like it is simple.
However I will repeat myself:
Has anyone located it on a oil system diagram?
Unless one can point out the path of the oil in relation to this particular galley plug, then it is just speculation.
My race engine (different 4 cyl boxer) has about 10 different galley plugs and MOST of them would do absolutely zero in helping the engine in a failure.
Even if all you care about is pre-oiling (and not saving the engine in a failure), then it STILL matters where you feed the system.
Pick the wrong side of a restriction or a VVT valve that may or may-not be open, and the accusump might be useless.
You might be 100% correct, but a picture is worth a thousand words.
I have a complete diagram of my race engine oil flow.
Does anyone have one for this engine?
Old 04-08-2015, 08:33 PM   #16
sam69
Drives: GT 86
I have tapped into this plug for my oil pressure as it is after the oil filter .
Its the one directly under the TB wires and I got this pic from a quick google
sam69 is offline   Reply With Quote
Old 04-09-2015, 05:15 AM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
Nothing to see here.
Old 04-09-2015, 05:50 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by LS1M View Post
I mean, holy cow, it's all over the map - 125 cold to 15 PSI warm idle?!
Why do you think this is unusual?
Old 04-09-2015, 01:37 PM   #19
LS1M
Drives: 2015 BRZ
Compared to other cars I've had, mostly domestic V8's. The accusump project us on hold until I get an oil pressure gauge so I can see how the oil pressure behaves myself. It may all just be a matter of a higher precharge and rpm switch to prevent losing the oil at idle.
LS1M is offline   Reply With Quote
Old 04-09-2015, 03:29 PM   #20
stugray
I wish that accusump would make an electric valve that has an adjustable setpoint.
Old 04-13-2015, 12:56 PM   #21
D K
Stig's dark passenger
Do alittle more research man.
Its all out there
D K is offline   Reply With Quote
Old 04-13-2015, 01:29 PM   #22
stugray
Its all out there
Please just post a link.
Old 04-13-2015, 02:47 PM   #23
D K
www.google.com
http://www.accusump.com/accusump_tech.html#Howdoes
http://auto.howstuffworks.com/engine...ion-system.htm
Old 04-13-2015, 03:20 PM   #24
stugray
Thank you very much for teaching me how to google.
Now I guess you need to teach me how to read since I still connot find any mention of an accusump with an " electric valve that has an adjustable setpoint."
Old 04-13-2015, 03:25 PM   #25
D K
Read around in the product tech, it will explain how their valves work
Old 04-13-2015, 03:50 PM   #26
fika84
fika84's Avatar
In @stugray defense, what he is looking for isn't in that tech article about how the valves work. They do have 2 different kinds of electric valves, but not to do what he wants. He wants a way to SET the point (pressure) at which the valves open.. these all have preset values and no where does it say that you can adjust that preset value.
fika84 is offline   Reply With Quote
Old 04-13-2015, 03:56 PM   #27
stugray
I HAVE read their tech documentation. I have BEEN reading their information and been using their products for years.
I see no mention of an adjustable pressure sensing valve, but since you are so sure that there is one, you must just be witholding information for the fun of it.
There is the 24-270 ACCUSUMP ELECTRIC VALVE - No pressure sensing feature (ON or OFF)
24-271 20-25 PSI sensing
24-271K (upgrade) 20-25 PSI
24-273 35-40 PSI sensing
24-273K (upgrade) 35-40 PSI
24-275 55-60 PSI sensing
24-275K (upgrade) 55-60 PSI
It's easy, just post the link to this information that I am so dense as to not be able to find....
Old 04-14-2015, 01:43 PM   #28
D K
I never said there is a valve you can manually set.
They have different valves set at different pressures as you yourself have listed.
pick a pressure that would be ideal for you.
See if there is a valve that corresponds to that pressure.
D
LCA install WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-16-2014 05:47 AM
Which mod to install first .... ?? humfrz Scion FR-S / Toyota 86 GT86 General Forum 9 11-09-2013 09:07 PM
MTX install Deadspool Electronics | Audio | NAV | Infotainment 1 06-27-2013 07:21 AM
Where to install amp in FRS? mit_peid Electronics | Audio | NAV | Infotainment 10 03-24-2013 01:01 PM
Need help with HID install ortizwyld Cosmetic Modification (Interior/Exterior/Lighting) 4 02-21-2013 11:12 PM
