#169 | |
Drives: Toyota GT86
You will need the last link stating: Off-The-Shelf (OTS) Maps for naturally aspirated configurations
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#170 | |
Drives: FT86
tune files are hex or bin and in different directorys you need the tunes in directory that matches last letter of your tune calid, oft will only let you load compatable tune files. |
#171 |
Drives: Subaru BRZ Limited
Lots of great info in the forums, I've been reading everything I can and it has my head spinning. I ordered my OFT on Monday afternoon and had a shipping confirmation in less than 3 hours, how about that turn around time!
Going to be running the Stage 1 93oct tune, I can't wait to open up the box tomorrow when it gets here! |
#172 |
Drives: GT86
Hello people) I want to ask about my afr. Tell me please afr "11.25" its normal?
http://datazap.me/u/nexusatm/140015a...log=0&data=1-5 This data of 3 gear launch, adv multiplier "1". Thanks) |
#173 | |
Drives: FT86
Have a read on the Basic log your tune post link below |
#174 |
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#175 |
APEXHNTR
Drives: 10 Series FR-S #1867
This may or may not be the best place to ask, but has anyone had any issue with the math not lining up for the Launch Control?
I've had it set at 3000 [7600-3000=4600] and that is right. I'm trying to set my launch control to 4000 (autox launch for minimal burnout when dropping the clutch) but if I set the delta at 3600, the launch control goes to 3600rpm, at which point the math doesnt work. I've tried in 100 RPM intervals and heres what I came up with: Redline - Delta = Actual RPM at rev limit [what rev limit SHOULD be] 7600 - 3600 = 3600rpm [4000] 7600 - 3500 = 3900rpm [4100] 7600 - 3400 = 4200rpm [4200] 7600 - 3200 = 4400rpm [4400] @steve99 @Shiv@Openflash
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#176 | |
Drives: FT86
make sure your Flat Foot Shifting is disabled ie delta=0 if your not using it. Or make sure the delta is like 2000 so its not clashing with launch control setting when clutch depressed. not sure what the reference is for Max rpm maybe its fuel cut so check the fuel cut is set to 7600, it may have been left at stock value . otherwise might be coding error |
#177 |
Drives: GT86
how to change launch controll
can someone please tell me how to change launch controll to 4.5krevs?
#178 |
Flashed my ECU for the first time on Friday and I'm noticing the dead pedal, should I reflash and follow the suggested steps or what is the best approach to correcting this now that I've been driving for a couple days
#179 | |
Drives: '22 BRZ
Change the numbers to suit your needs, it would be 3100 in your case. Just keep driving. Mine takes about two weeks for the bad pedal response to go away fully. The ECU is doing some sort of TQ requested vs actual TQ learning. I noticed that the throttle pedal angle is dead on as it always is but the normal immediate response from the throttle pedal is dulled quite a bit until it gradually learns that I'm requesting more torque than it can deliver from 1% throttle angle. |
#180 | |
#181 | |
Drives: '22 BRZ
#182 | |
Drives: 2014 Argento FRS
When this happened to me I just re-flashed the tune I wanted and followed these steps : Turn ignition fully off after a flash or reset Turn ignition fully ON, do not start car, do not touch throttle, leave for 20 sec this will allow ECU to perform its diagnostics and calibrations on cam position and throttle position sensors Turn off ignition Turn on ignition leave for 20 sec then start car do not touch throttle Let car idle for at least a minute and wait till it settles at the normal idle of about 750 RPM, again do not touch throttle. After normal idle is achieved then drive car. after I followed above, it seems to have helped a lot. Not sure if this was just me thinking it helped or if it actually worked so YMMV. Sent from my iPhone using Tapatalk |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
