Old 01-14-2015, 09:13 PM   #295
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by chanomatik View Post
I'm still waiting to have my rear calipers put on... I'll let you know how it goes whenever they're mounted. Project Mu performance pads in the rear, I believe, and StopTech street pads up front. They're supposed to get the balance back to stock status, according to the person that bought the entire kit before selling it to me.
This is exactly how I run mine. No issues with brake bias, very similar to stock feel as far as I can tell. Note that this is street use only, so I have no idea how it will perform on track.
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
chanomatik (01-15-2015), noogin (01-15-2015)
Old 01-16-2015, 11:23 PM   #296
noogin
Good to know Fizz, thanks! StopTech street performance pads in the front and project mu hc+800 or club racer in the rear?
noogin is offline   Reply With Quote
Old 01-16-2015, 11:39 PM   #297
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Would you even need to run staggered pads on the street ??
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 01-17-2015, 01:39 AM   #298
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
In my opinion yes because with same pads all round (with front and rear brembo) I found front bias a little too strong for my liking. Using a slightly grippier rear pad improved the bias better.
By the way I'm using stoptech street performance front, with project mu b-spec rears.
The Following User Says Thank You to Fizz For This Useful Post:
noogin (01-17-2015)
Old 02-13-2015, 01:31 PM   #299
deliroast
Drives: 2014 SSM BRZ
using hps front pads and project mu clubsport on stock rears. Feels so much better than the matched set I started with. Just a little noisy
M3 > BRZ
deliroast is offline   Reply With Quote
Old 04-09-2015, 06:42 PM   #300
protpibe
protpibe's Avatar
Is anyone running 17's with STI Brembos? I need to invest in some track wheels, but I'm trying to figure out what fits without spacers first.
Thanks
Old 04-09-2015, 06:50 PM   #301
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Thanks
I have 2004 STI (Gold) Brembos on OEM 17" wheels using 25mm spacers.
There is about a 5mm of gap between the front caliper and the wheel.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 04-09-2015, 06:51 PM   #302
protpibe
protpibe's Avatar
I appreciate the info, but I'm looking to find what fits without spacers.
Old 04-09-2015, 06:56 PM   #303
azian_advanced
*****istrator
have you decided what wheel width or offset you plan to go with?
Old 04-09-2015, 06:57 PM   #304
protpibe
protpibe's Avatar
STi Brembos
That's then info I'm trying to gather. I've had a few different sets of wheels for my car, but I want to confirm fit before I get the next set. Ideally I want RPf1s in 17x9 +35, but I don't know if they'll clear or not
Old 04-09-2015, 07:01 PM   #305
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
Thanks
I have a search saved on TireRack.com titled "Brembo Fitment". It's a 2004 STI just titled according to my needs. Anyway, I will occasionally use that search result to see if anything is being sold that tickles my fancy that is confirmed to be 5x100 and fit over Brembos. They currently sell 44 wheels that are 17", 5x100 and clear 2004 STI Brembos.
Then what I do, if I'm curious what it might look like, is go to my "BRZ" saved search and go to the wheel I saw under "Brembo Fitment" to see what they look like on the BRZ.
Let me know how that works out for ya or not. You can also ask a TireRack person if they're online. They're super helpful.
The Following User Says Thank You to chanomatik For This Useful Post:
protpibe (04-09-2015)
Old 04-09-2015, 08:54 PM   #306
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks
Yes i'm running Wedsport TC105N 17x8 +42 and it clears without spacers. Weighs in at only 15lbs each.
Old 04-10-2015, 12:09 AM   #307
Vten
Drives: Too heavy
Thanks
My wedsport 17x9 et35 should be here Monday , They should clear the brembo ,I'll take pics once I put them on .
Vten is offline   Reply With Quote
Old 07-27-2015, 04:29 PM   #308
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
17x8 RPF1's fit. I forget which offset, 42 I believe... but yeah the 17" with the curve spokes will fit. 17x9 will not
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
