Old 04-07-2015, 06:15 PM   #15
350matt
Drives: toyota mr2/ Toyota GT86
I'd agree that a new sensor is well worth a try as it does fit your symptoms very well
350matt is offline   Reply With Quote
Old 04-07-2015, 11:48 PM   #16
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by Kodename47 View Post
Tried a recalibration?
I was told some time ago that the NGK sensor AFX was the best wideband if you're not going professional lab quality. It's not too badly priced either.
A little bit late lol. Bought a new AEM UEGO sensor off Amazon and they only charged $10 for same day shipping!
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 04-08-2015, 10:28 PM   #17
Synack
Boosted
Synack's Avatar
Drives: Sideways
Not sure why I thought the problem would be fixed with just the wideband being replaced. There is a standard (looks to be) O2 sensor a few inches before the wideband on my manifold and I believe that's the real culprit. I hooked up the Torque app just for giggles and noticed that the O2 sensor thinks it's reading ~14.7 at idle and only barely fluctuates when I rev it, while the brand new wideband is reading mid 12's.
Pretty much a dead giveaway that the front O2 is crap. Not to mention performance has been lacking.
Old 04-09-2015, 10:55 AM   #18
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I should have mentioned it. I was doubting that your tuner was using your aftermarket wideband as the primary input for closed loop operation.
Old 04-09-2015, 11:50 AM   #19
Synack
Boosted
Synack's Avatar
Drives: Sideways
The real question is, WHY NOT?
I know the factory O2 is relatively capable itself but widebands are still better. Would there be any reason why they would use the factory O2 over wideband?
Old 04-09-2015, 11:55 AM   #20
buddy32
Drives: WRB Subaru BRZ Limited
Was the tuner aware? I have my wideband hooked up according to this:
http://www.ft86club.com/forums/showthread.php?t=57902
and the tuner had to turn the factory secondary O2 off in ECUtek. Maybe he just didn't know how you hooked it up and how he could use it?
buddy32 is offline   Reply With Quote
Old 04-09-2015, 12:26 PM   #21
Kodename47
Kodename47's Avatar
Drives: UK GT86
Because you can't, and why would you not use the stock item for closed loop. You're only closed loop at ~14.7-14.0 on the stock maps and at those AFR the stock sensor is actually pretty good. You would have to effectively switch off OEM closed loop operation and then create a custom map to run open loop with feedback from the WBO2. It's a lot of work for bugger all gain.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-09-2015, 12:42 PM   #22
Synack
Boosted
Synack's Avatar
Drives: Sideways
Thanks for the info, you learn something new every day.
I'm about to upload a couple pics of the factory O2 that I just took out. Tell me if it looks like it's in bad shape or not.
Old 04-09-2015, 12:51 PM   #23
Synack
Boosted
Synack's Avatar
Drives: Sideways
Old 04-09-2015, 02:17 PM   #24
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Did you crush it removing it? Looks pretty normal to me other than that. Throw a little anti-seize on the threads when you install the new one.
Old 04-09-2015, 05:16 PM   #25
aagun
Drives: 86
what is the sensor volts @ idle ?? it should 2.2v with 14.7 AFR ,
aagun is offline   Reply With Quote
Old 04-09-2015, 06:26 PM   #26
Synack
Boosted
Synack's Avatar
Drives: Sideways
That's why I bought a new one because the current one stopped reading correctly.
Old 04-09-2015, 06:28 PM   #27
Synack
Boosted
Synack's Avatar
Drives: Sideways
I don't know how I could've. Maybe I hit something on the highway that came up and smacked the sensor and ended up breaking it. I mean there isn't anything guarding it.
Old 04-10-2015, 11:50 PM   #28
Synack
Boosted
Synack's Avatar
Drives: Sideways
Well everything seems to have gotten much better and possibly fixed, just got the stock AFR O2 sensor in today and partial throttle is perfect, WOT is pretty good, and idle is decent. Probably will get better after the trims are relearned.
Hopefully time to install flex fuel E85 and the new turbo now.
Thanks for everyone's help if this truly is done.
The Following User Says Thank You to Synack For This Useful Post:
WORKS (04-13-2015)
Cel gas running to rich anthonyravenfrs Scion FR-S / Toyota 86 GT86 General Forum 3 07-15-2014 02:55 AM
So what would you say is too Lean? Too Rich ? Opinions Pls. BC-Boy Software Tuning 27 05-29-2014 11:05 PM
POST YOUR 1/4 MILE TIMES Quarter mile times NYCsubaruBRZ Tracking / Autocross / HPDE / Drifting 1 02-04-2014 07:59 AM
Running rich KslayFRZ Issues | Warranty | Recalls / TSB 15 10-26-2013 12:42 AM
Rich man's FR-S (WRB BRZ) Hamza7 Cleaning and Detailing 9 06-24-2012 12:36 PM
