Old 11-12-2010, 05:19 AM   #29
Abflug
Abflug's Avatar
Drives: MR2
so if itīs going to be a SCION and they want to introduce itīs brand with the FT-86 to the euro market (what I do not expect) I would rahter 3S-GTE up my 20 year old MR2 than buying a SCION or a Z (there are enough alternative choices for the Z e. g. BMW Z4 M Coupe) and even if there is still the SUBARU option!
Abflug is offline   Reply With Quote
Old 11-12-2010, 08:44 AM   #30
Dragonitti
Rationally, Scion branding serves a small Scion enthusiast market. Toyota branding has a chance to bring back Toyota enthusiasts that have moved over to other brands or hung on to old Toyota performance products, like myself. Especially ones that are actively turned off by the Scion enthusiast community. Also like myself. If the FT/R-86/S fails to impress (God forbid) I will be probably looking towards a 370Z, pending the payment difference.
With one car though? I would think they would have to follow up with several cars in the same category before they started to Reel in new people or the old.
And the Subaru Option....You think it's going to be the same price as the Scion/Toyota version? I highly doubt that.
Old 11-12-2010, 09:47 AM   #31
Dragonitti
No matter what brand it comes out under, I have only two fears.
1) They will redesign and actually mess it up.
2) They will incorporate to many electronic stability systems with no way of turning them off....thus killing my ideas of taking it to the drift track a few times a season.
I'm a little less worried about #2 as they were touting it as a drift car when they first started the buzz. But with the way the Auto Industry is turning into (Electric Green Cars, and cars that are uninspiring and just get you from A to B), anything can happen.
On the new tC2 they added traction control to the tC. You can disengage it via the button, but it will enable itself on it's own once you hit 30+mph. They also put in what my 350z had in that you can't press the brake while still on the accelerator, thus eliminating any chance of Brake Boosting, or left foot braking.
Old 11-12-2010, 05:45 PM   #32
djohnson
Drives: 1996 RAV4
Don't forget, there is almost always a way to turn off the often annoying electronics. Fuse boxes are your friend
djohnson is offline   Reply With Quote
Old 11-12-2010, 05:50 PM   #33
Dragonitti
The new 2011 tC comes with traction control now. You push the button to disable it....it re-enables when you get to 30mph...
They also implemented electronics that prevent you from braking and accelerating at the same time. This eliminates left foot braking as well as brake boosting.
It's to early to tell what will have to be done to bypass this stuff, but just simply hitting the button doesn't work.
My 350z had the "brake/gas" electronic thing as well, thus preventing you from being able to do a burnout (even if you disabled the Traction control). Only way around it on the Z was to remove the rear brake light fuse. Or buy this gadget this dude on the forums made to bypass it, and still be able to have brake lights.
Old 11-12-2010, 07:21 PM   #34
Allch Chcar
Drives: N/A
Not familiar with the function of the fuse box are we, Dragonitti?
I'll just explain it for everyone then. Removing a fuse cuts the power off for everything in the circuit. Headlights have a seperate fuse, the engine ECU has a fuse, etc. So long as the Traction control is on a separate circuit from anything important it could be shut down by this method but if it's on the same circuit as anything important then no go.
Someone want to verify/explain this better?
Allch Chcar is offline   Reply With Quote
Old 11-12-2010, 08:11 PM   #35
Dragonitti
I will quote myself since I think you missed part of my post.
Doing so disabled the use of brake lights period. Now try running at night with no brake lights, or on the race track with no brake lights.
Old 11-13-2010, 03:08 AM   #36
nate89
nate89's Avatar
Drives: MR2
Simply hitting the button will only disable it for speeds under 25-30mph. But pushing and holding will completely disable both VSC and trac Controll at all speeds. There is also a way to disable only the trac control and keep vsc, but it requires a "cheat code" done with the brake pedal, ebrake, and key.
nate89 is offline   Reply With Quote
Old 11-13-2010, 08:56 AM   #37
Dragonitti
Yeah we just found that out.
Old 11-13-2010, 06:04 PM   #38
djohnson
Drives: 1996 RAV4
Not that I'm recommending it at all, but most anyone who has a decent understanding of splicing and who knows exactly which wires go where in the circuit could splice a bypass around the target circuit and add in a separate fuse and switch to the dash. Likely would be a Saturday afternoon/weekend project. Obviously voiding warranties and the like in the process. But still doable without too much effort. Just a last resort for those who REALLY want to disable the safety features if the other cheats/tricks don't work.
Old 11-13-2010, 07:21 PM   #39
Dragonitti
^^I prefer for them to just not put that crap in there to begin with...LOL. But I don't see that happening.
Old 11-13-2010, 08:10 PM   #40
Siriusly.Andrew
Siriusly.Andrew's Avatar
Drives: 1995 Civic DX
I prefer for them to just not put that crap in there to begin with. But I don't see that happening.
Agreed. ABS and Traction Control ruined winter for me. ABS kills people this time of year, and TC just takes the fun out of everything.
Originally Posted by MatadorRacing_F1 View Post
Anyway, as i was saying, "speed is expensive, how fast are you willing to spend?"
Siriusly.Andrew is offline   Reply With Quote
Old 11-14-2010, 01:41 PM   #41
Dark
Elite Padawan
Dark's Avatar
It's not like everyone will drive the hell out of a car, so expecting disable buttons on safety features is more likely.
Dark is offline   Reply With Quote
Old 11-15-2010, 01:21 PM   #42
Allch Chcar
Drives: N/A
...Doing so disabled the use of brake lights period. Now try running at night with no brake lights, or on the race track with no brake lights.
What you that say you said.
And what you actually said.
Now do you see why I was confused?
<-I am easily confused.
And brake lights are unnecessary distractions on a race car IMHO.
Scion FT-86 FR-S NTODD Scion FR-S / Toyota 86 GT86 General Forum 418 11-24-2010 11:34 PM
Tell Toyota we don't need Scion FT-86 Dark Scion FR-S / Toyota 86 GT86 General Forum 28 10-15-2010 07:26 PM
FT86 as a Scion!?! With 2.5L?!?! Midship Runabout Scion FR-S / Toyota 86 GT86 General Forum 3 10-11-2010 12:03 AM
FT-86 as a Scion? jdmChip Scion FR-S / Toyota 86 GT86 General Forum 15 04-24-2010 09:33 AM
FT86 ... AS A SCION??? YourFearlessLeader Scion FR-S / Toyota 86 GT86 General Forum 228 02-10-2010 11:43 PM
