Old 04-08-2015, 06:33 PM   #1
Skorov
Skorov's Avatar
Drives: 86 GTS White
Radium Dual Catch Cans with AVO kit & RHD
Since the catch can that comes with AVO kit is a bit questionable, I was looking at upgrading to the Radium Dual Can setup.
Has anyone done this? Could you confirm the routing of the hoses? Do I still use the PCV valve that came with the AVO kit?
On top of this I have a RHD 86, which means the brake booster and battery are on opposite ends. I fear that the passenger (left) side can will not fit due to the battery positioning.
Radium haven't been very helpful basically saying they have never tested on a RHD car even though they market it as if they have.
Please post pictures if you have done this on a RHD. Thanks!
Skorov is offline   Reply With Quote
Old 04-08-2015, 06:57 PM   #2
scarfo
Drives: gts 86
Hey mate I had one on order but swapped it over for the full blown Catch can, it will fir but you will need to bend a brake line and it's very hard to open it once it's in place, I didn't want to risk kinking the brake line.
scarfo is offline   Reply With Quote
Old 04-08-2015, 07:41 PM   #3
Skorov
Skorov's Avatar
Thanks mate. What about the battery side?
Old 04-08-2015, 07:49 PM   #4
scarfo
Drives: gts 86
Battery side should fit, I never fitted the kit just going off a performance shop in Sydney who told me about the issue, As the had gotten a few in and installed one, saw the issues with the kit and have not recommended them to clients
Old 04-08-2015, 08:31 PM   #5
Skorov
Skorov's Avatar
I could probably refab the driver's side bracket so that I don't have to bend the brake lines.
Thanks for the info!
Old 04-08-2015, 10:12 PM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm currently running the AVO catch can (black one) and it's been great so far. But I was also looking at the radium previously and came across this pretty neat DIY idea and was thinking of doing something similar to mount on the battery side: http://www.ft86club.com/forums/showp...2&postcount=87
But if you mount it this way on the battery side, you'll need to watch out for the A/C hard lines as it may get in the way.
Fizz is offline   Reply With Quote
Old 04-08-2015, 11:22 PM   #7
Skorov
Skorov's Avatar
Very neat! I'll definitely keep this in mind. Thanks!
Radium Engineering Catch Cans FRS2000 Engine, Exhaust, Transmission 111 03-02-2016 12:49 AM
Saikou Michi dual catch cans FearBoy Engine, Exhaust, Bolt-Ons 0 11-18-2014 08:19 PM
Kraftwerks / Jackson Racing SC kits with Radium Dual Catch cans setup? OICU812 Forced Induction 7 10-14-2014 12:36 AM
Catch cans: what are you running? Apex Chase Engine, Exhaust, Transmission 144 08-14-2014 07:17 AM
Radium or Crawford catch cans/AOS diss7 Forced Induction 16 02-18-2014 07:50 AM
