Drives: 2014 BRZ MT (Sold); 2006 V70R
TWM shifter problem
I was having trouble getting into reverse again... Open up the console and see this. =(
'14 BRZ LTD MT DGM
#2 |
Follow up:
So the screw holding on the two pieces on the left basically fell out. For better or worse, the screw made its way into the gap for the ball joint, causing a VERY dangerous condition called "getting stuck in gear." This reminds me of the 2 times I literally got stuck in 2nd gear merging onto a freeway. Good thing both times it was in little to no traffic. At first I though my gearbox had gone to shit, but now I realize that it was this little bolt's fault. I cleaned up everything, checked the threads, used some loctite, and put is all back together. However, I now have problems getting into reverse, again. The "I can't get into reverse" problem has appeared. This is really frustrating... to rehash the problem I had earlier... the shifter stop plate is adjusted as far right as it can go, allowing for smooth and proper 1st geat engagement. if I move it to the left, then it won't go into 1st properly, but rather, it'll seemingly hit the "shelf" between reverse and first, so I have to install the plate as far right as possible. However, when the lockout is lifted and moved to the left to get into reverse, it doesn't seem to move far enough to the left. It'll hit the "shelf" and refuse to go into reverse. I have to muscle the shifter further to the left, basically flexing the entire shift carriage to get it to move over enough to get it into reverse. Feels like the "bump" on the shifter itself is too small. Moving the lockout plate to the left and increasing the size of the "bump" would solve this problem. Any suggestions to get this thing to work correctly? @TWMPerformance
'14 BRZ LTD MT DGM
#3 |
Drives: 2013 Scion FR-S 10 Series
This is the best made unit on the market and I really hope that they shed some light on solving your problem. My experience with TWM Performance is that they can be slow to respond to e-mail, but really try to make you happy when you reach them on the phone. They also seem to value their reputation on this forum (I told them I was active on this forum when I purchased my short throw shifter from them, and they took notice), so I suggest calling them and telling them to publicly reply to this thread to put all of their customers' minds at ease.
It's a really well made unit and it's important that we all better understand the problem, and solution, to your issue. |
#4 |
Drives: Manual Transmission, All the Way!
Thanks for bringing this to our attention. I think your best bet is to completely take the shifter out and re-install it following our instructions as closely as possible. If you still encounter the same issue, please let us know. We want to ensure that this situation gets fixed so you can be plowing through those gears again!
Sincerely, Renato Team TWM Performance |
| The Following User Says Thank You to TWMPerformance For This Useful Post: | RJasonKlein (04-16-2015) |
#5 |
Cleaned and reinstalled it already. The only problem is the reverse engagement. Shifting the lockout plate to the left may solve this, but then I'm worried about proper first gear engagement.
'14 BRZ LTD MT DGM
#6 | |
#7 |
Drives: 2013 Scion FRS 6 Speed Raven Black
I went back to stock from my TWM shifter. I First, the shift unit itself, loosened on my way home from a 250 mile round trip drive. The shifter was literally splitting in two at the base and luckily didn't give all the way out until I turned onto my street at which point I was stuck in second gear. Pulled everything apart to find out the lock ring had loosened. Fixed everything up and about 50 miles later a god awful rattling. I was done with it and just put the stocker back in. Still have it sitting in the garage.
In TWMs defense, I bought it used from a guy who said he had it on his BRZ for approx. 4k miles and was selling it because he was trading the car in. Didn't attempt to contact because I bought it second hand. Still paid what I would have paid for the Kartboy and was a little disappointed. |
#8 | |
That's sad to hear. We really want you to enjoy going through the gears, the TWM Performance way. If there's anything we can do to make it right, we will. Try and get a hold of the person you bought it from so he/she can send it in for repair under our lifetime warranty.
Best regards, Renato Team TWM Performance Quote:
| Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? | soulstice | Cosmetic Modification (Interior/Exterior/Lighting) | 52 | 01-24-2016 08:20 PM |
| Shifter springs/bushings/shifter performance | Darnold | Engine, Exhaust, Transmission | 10 | 10-22-2014 11:49 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 01:41 AM |
| TWM short shifter alignment problem | aznatama | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 10-01-2014 10:01 AM |
| shifter problem highrev. | frsqc | Issues | Warranty | Recalls / TSB | 11 | 04-24-2014 09:45 AM |
