Old 04-23-2014, 08:47 PM   #1
frsqc
Drives: raven FRS
shifter problem highrev.
So, last night, i decided to rev my car out in neutral which i actually had never done, and my whole shifter was shaking violently like i mean knocking left and right.
Just curious what could be causing this????
on my old audi it wouldnt even budge, something just seems broken under there
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 04-23-2014, 09:02 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
Were you bouncing off the rev limiter?
2013 FRS
Vortech V3 11psi
Old 04-23-2014, 09:09 PM   #3
frsqc
Drives: raven FRS
steady rev between 5-6k
Old 04-23-2014, 09:44 PM   #4
iniguez310
Cool Guy
Auto or manual??
iniguez310 is offline   Reply With Quote
Old 04-23-2014, 09:47 PM   #5
yaguphire
Drives: white-out FR-S
Originally Posted by iniguez310 View Post
Auto or manual??
He's probably talking about a manual shifter. Ive never seen an auto shifter shake. *shrugs*
yaguphire is offline   Reply With Quote
Old 04-23-2014, 10:22 PM   #6
strat61caster
strat61caster's Avatar
Your shifter is directly connected to the transmission which is directly bolted to the engine. When it's in neutral it has free play side to side compared to when it's in gear.
If it wasn't making funny noises I wouldn't worry about it, you're not the first to say the shifter vibrates too much. If it was making noise as it bounced around the gates I would take it to the dealer.
ineedyourdiddly
Old 04-23-2014, 11:26 PM   #7
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
It must be the boxer engine boxing itself.
I feel this too in my automatic. When I start it up, sometimes I can feel the car jolt quickly left and right.
When I rev my car in N, i can feel a slight jolting of left and right as well.
N1rve
Old 04-23-2014, 11:32 PM   #8
frsqc
Drives: raven FRS
Auto or manual??
manual.
and no it doesn't make any weird noise at all, but the intensity of the vibration is pretty bad. wish it just did it a little less
Old 04-24-2014, 01:34 AM   #9
iniguez310
Cool Guy
Originally Posted by frsqc View Post
manual.
Might want to check the shift springs. I installed mtech shift springs on mine and that little shake i used to get when doing a burnout was reduced. It never shaked as much as you are describing but might be something you wanna look into.
Old 04-24-2014, 03:02 AM   #10
strat61caster
Video might do the trick communicating to us how severe it is.
ineedyourdiddly
Old 04-24-2014, 08:28 AM   #11
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Also, there was a tsb regarding shifter vibration (scion tsb 03-71-13). Might be worth asking your dealer about that.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 04-24-2014, 09:45 AM   #12
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
So, last night, i decided to rev my car out in neutral...
Why???
billwot is offline   Reply With Quote
Manual MT Shifter Boot Swap Onto Automatic AT Shifter Assembly? soulstice Cosmetic Modification (Interior/Exterior/Lighting) 52 01-24-2016 08:20 PM
kartboy short shifter and rear shifter bushing install and review. FR-S UMB FR-S DIY (Do-It-Yourself) Guides 21 10-18-2014 01:41 AM
TRD Short Shifter Quick Shifter Scion FRS hirollaz Transmission and Driveline 3 04-15-2014 01:24 AM
wtb: short shifter natesparxxx Transmission and Driveline 2 03-20-2014 09:03 AM
Shifter TSB 03-71-13 v. Perrin Rear Shifter Bushing swansons Issues | Warranty | Recalls / TSB 4 02-02-2014 02:27 PM
