#3207 | |
BoostedBRZ
Drives: Turbo BRZ
#3208 | |
Drives: 2013 Subaru BRZ
Videos?
English is my 2. language. Typos might occur.
![]() 2013 BRZ, kraftwerks supercharged. Skunk2 Ultra radiator with oilcooler KW v3 - enkei 17x9 with PSS |
#3209 | |
Drives: The silvertrooper 10 series
My car is an Automatic. To be 10000% honest, im not always at or above the stock redline, my normal driving hardly see's me in boost maybe a pound or two during normal driving and even when im having a bit of fun maybe around 14 psi. I never needed or really wanted this much, it just kinda happened and then it was like a why not. I dont think the engine or transmission would hold at a track day the way it is setup now. its alot of boost and its a stock engine and trans. after the TC upgrade and valvebody, clutch packs then maybe the trans would be up to the task, the engine on the otherhand would need to be built to handle the abuse.. But for daily driving and having fun with other cars, so far its held up. Also the only small thing i noticed, is that after about 12k, the oil tank for the SC was about half way on the dip stick. My fault for not checking regularly, i would assume it should be ok anywhere from the min to max line, but i wasnt really expecting to see any loss of fluid. I was expecting this bottle to last the whole 30k service interval. I still havent used a full bottle and still have a filter and bottle for its fluid swap when time. I have checked all fittings and do not see any noticeable leaks or seeps.. -Thomas |
| The Following User Says Thank You to 86SPEED For This Useful Post: | pgranberg11 (04-08-2015) |
#3211 | |
BoostedBRZ
Drives: Turbo BRZ
or did you actually mean 85mm? |
#3212 | |
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
| The Following User Says Thank You to Gixxersixxerman For This Useful Post: | pgranberg11 (04-08-2015) |
#3213 | |
BoostedBRZ
Drives: Turbo BRZ
#3214 |
#3215 | |
BoostedBRZ
Drives: Turbo BRZ
I do plan on tracking the car and a few auto cross sessions. I'm thinking I do either e85 OR higher boost pulley with my c38 kit. and again hope to the car gods i don't blow up. or just leave it the way it is now. c38 using 93 octane. |
#3216 |
I would not recommend the higher boost pulley without using E85. im at 18.9 psi depending on the weather and thats at our elevation. sea level would be even more. When im on pump gas i dont go over 6k, 6.5k at the most.
-Thomas |
#3217 |
Drives: 2013 Scion FRS in white out
Sorry to post this, maybe its obvious and I just don't understand it but here goes. I am running the c38 blower on a stock engine and fuel system, no e85 around here. I have read this thread end to end and still see so many variations when it comes to tuning this car with the c38. I won't name tuners but how does one tuner have the ability to tune a stock frs like mine with a c38 to 300whp safely on pump gas and safe afr's while others struggle to hit 280whp because of overloading the pump and injectors? Sorry if this is silly....I just don't get it.
#3218 | |
It's not silly. I would say the biggest difference in the HP output is the dyno and the conditions during the dyno runs. Put em all on the same dyno on the same day with like conditions the variance would probably come way down. |
#3219 | |
Drives: 2013 Ultramarine FR-S
#3220 |
Drives: GT86
Oil Cooler Problem
![]() Hi fellow frs/brz Kraftwerks owners, I'm a new KW owner who got 354hp using Ethanol. Because i track my car i feel i'm oblige to install an oil cooler. I found a shop who can install the oil cooler i bought. The oil cooler is not branded but pretty much solid. The problem is it won't fit on the KW kit because the oil filter host hit the bracket, so the shop who installed myt kw kit relocate the oil filter position near the rotrex. (It is circle in the photo) Brothers do you think it will affect on how the oil filter works? Considering it has more distance from the engine. Do you think it will affect the pressure pushing the oil in the engine? How about the position of my Greddy oil catch can? I think KW guys should answer this, considering their kit might be accuse of the cause, if i will have engine failure in the future. Thanks in advance, and more power KW |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
