Old 04-07-2015, 05:03 PM   #659
TWMPerformance
Drives: Manual Transmission, All the Way!
Always in love with this build <3
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
The Following User Says Thank You to TWMPerformance For This Useful Post:
Anthony (04-07-2015)
Old 04-07-2015, 05:15 PM   #660
MicheleAbbate
MicheleAbbate's Avatar
Drives: Grr Racing FRS & BRZ
Send a message via AIM to MicheleAbbate
Originally Posted by Anthony View Post
I know for sure I've removed 367 pounds. So... assuming the car weighs 2,750 from the factory, I should be at 2,383. "Should be"...
But yes, I guess you're winning by default right now, since I don't even have an actual weight.
haha right on. I'm assuming that's with an empty tank?? Our cage weighs around 80 lbs. and when our car was 100% stock with a 1/4 tank of gas it weighed the following:
It's got about half tank of gas right now (before we corner balanced it) and our scale reads:
so, you should get your ride on a scale so you can officially be lighter than me... but until now I want to feel like I am winning!
www.GrrRacing.com - Won Scion's first Road Racing Championship in 2011. Raced the Grr Racing Scion FRS from 2014-2018. Have lots of OEM Part FS. lol Check my thread. Now I race in Trans Am TA2.
MicheleAbbate is offline   Reply With Quote
The Following 2 Users Say Thank You to MicheleAbbate For This Useful Post:
Anthony (04-07-2015), Flasher (04-13-2015)
Old 04-07-2015, 05:28 PM   #661
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Yes. As for rotating weight, I've got:
Raceseng pulleys, SPEC aluminum flywheel, DSS carbon fiber driveshaft, and Volk TE37's.
Do you know if having both LWCP and LWFW will cause your bearings to fail? There is a thread with a vendor claiming running both is a bad idea on these engines. Wanted to know your thoughts. Thanks
.RYAN is offline   Reply With Quote
Old 04-07-2015, 05:35 PM   #662
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I have read the same. one of the two but not both is recommended.... though if anthony is running both and its working great, who knows
2much is offline   Reply With Quote
Old 04-07-2015, 05:37 PM   #663
MicheleAbbate
FWIW I'm running every lightweight pulley including the Raceseng AC delete bracket and pulley and the only time the car is ever running is when its racing on the track....
Old 04-07-2015, 05:38 PM   #664
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Nope, those are my full-tank estimates.
Ha! After taking my pulley off for fear of destroying my engine, I actually started a thread about this same thing:
http://www.ft86club.com/forums/showthread.php?t=79308
I have since put my pulley back on. I think I've got over 3,000 miles on the combo, and no explosions yet.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 04-07-2015, 05:40 PM   #665
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Way more weight reduction then I can do since it's my dd and I have a 1 year old but u did inspire me to do the basics like cf drive shaft, shorai battery and Berk trackpipe. That alone made a world of difference! Definitely one of my fav builds.
FRSfan111 is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSfan111 For This Useful Post:
Anthony (04-07-2015), phobos512 (04-07-2015)
Old 04-07-2015, 05:59 PM   #666
.RYAN
AWOLBRZ
Drives: 2017 BRZ
Okay good to know.
Old 04-13-2015, 10:52 AM   #667
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
Have you changed your brake discs? There is some (rotating) mass to loose. I've switched from the OEM discs to Tarox F2000 discs and found out, that those are 0.9 kg (~2 lb) lighter per disc. So overall you could save about 8 lb of rotating mass.
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 04-13-2015, 12:23 PM   #668
Anthony
Weight Nazi
Anthony's Avatar
I'm still undecided on brakes. I'll be doing more than rotors when the time comes.
The Following 2 Users Say Thank You to Anthony For This Useful Post:
MicheleAbbate (04-13-2015), RobertPaulson (04-13-2015)
Old 04-13-2015, 05:09 PM   #669
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
This is the way to do it since BBKs are lighter than the stock brakes.
Luckrider is offline   Reply With Quote
Old 04-14-2015, 10:21 AM   #670
Flasher
Smartass
Flasher's Avatar
As long as you're not going FI, I don't see a reason why you would need to move to a bbk. With the weight reduction you will have enough breaking performance with other rotors, brake pads and braided lines - imho.
Old 04-14-2015, 10:41 AM   #671
Luckrider
Luckrider's Avatar
BBKs provide more than just better braking. They offer cheaper maintenance and they are lighter weight.
Old 04-14-2015, 04:13 PM   #672
Anthony
Weight Nazi
Anthony's Avatar
Must have lightest 86.
...besides Griffon.
The Following User Says Thank You to Anthony For This Useful Post:
chaoskaze (06-22-2015)
mother fu(king winning!
