Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
View Poll Results: Have you had crankshaft bearing issues from LWFW + LWCP? | |||
I have had a LWFW + LWCP for at least 5,000 miles with no issues. | 12 | 92.31% | |
I have a LWFW + LWCP and I definitely have crankshaft bearing issues. | 0 | 0% | |
I have a LWFW + LWCP and I may have an issue. (Undiagnosed) | 1 | 7.69% | |
Voters: 13. You may not vote on this poll |
12-16-2014, 01:34 PM | #1 |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Lightweight Flywheel + Crank Pulley: Bearing Failures?
There has been discussion in various places around the internet, usually as a tangent from the original topic, about the possible hazards of running a lightweight flywheel and a lightweight crank pulley. The apparent issue is that running both will upset the balance of your crankshaft to the point where it will cause bearing failure.
I'm not a veteran Subaru guy, but according to the ones I've talked to, it's common knowledge that this is certainly the case on EJ motors. I've seen some eyebrows raise at the idea that this is the same on the FA20 as well. So I would like to gather some raw data on the subject. Here is the thread that originally drew my attention to this potential issue: Cons to a lowered weight pulley set? The topic comes up on post #15.
The Following User Says Thank You to Anthony For This Useful Post: | Fred E (12-16-2014) |
12-16-2014, 01:56 PM | #2 |
Drives: WRB BRZ
I am very much interested in this discussion; thank you for bringing it up. I'm looking forward to seeing some real information!
The Following User Says Thank You to Fred E For This Useful Post: | Anthony (12-16-2014) |
12-16-2014, 02:02 PM | #3 |
Weight Nazi
Yes, I'm tired of the speculations and opinions. I've already put my stock crank pulley back on, just to be safe, so I'd really like to know if that was necessary or not.
12-16-2014, 05:44 PM | #4 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I'm all ears to this considering I'm gonna do a lightweight pulley set soon...
12-16-2014, 05:48 PM | #5 |
Drives: 2013 Firestorm FRS
Sub'd for info.
I've heard the lightweight crank+flywheel "possible rumor" as well In for some facts. |
12-16-2014, 06:53 PM | #6 |
Drives: Asphalt Scion FR-S
I'm in for facts, have lightweight pulleys installed and am having a lightweight flywheel installed as we speak.
12-16-2014, 07:19 PM | #7 |
Drives: '13 BRZ Limited, '95 BMW M3
I've heard this is a no no on other platforms also. The light weight accessorie pullies are fine to use with a light weight flywheel but not a crank pully
12-16-2014, 07:30 PM | #8 |
The EJ series motors eat themselves apart just for fun. Not really a good comparison to ours.
We run all available lightweight pulleys, lightest weight flywheel, carbon drive shaft and wheels that are lighter than stock as well and have so since day one in our race car. It now has over 30K miles and shows no signs of slowing down. Car is boosted for most that time as well. Lightweight rotating components are absolutely fine as long as balanced. |
12-16-2014, 09:33 PM | #9 |
Pulley with stock flywheel is fine as well. The flywheel is really the cats meow to me being as light as possible with this car. It revs so much faster, love it!
12-16-2014, 09:34 PM | #10 |
Senior Addict
Drives: 86 GT
Thanks. I actually removed my post because I found the answer already....lol. But thanks for the quick response nonetheless.
12-17-2014, 12:17 AM | #11 |
Drives: Hydra EMS Powered FRS Raven Black
Pretty much false it has anything to do with bearing failures on these flat 4s. There's not any evidence to support the theory than there is evidence to support those same cars with bearing failures probably also used spark plugs
The EJ motors have bearings because there are so many terrible engine builders so the resulting drop in oil pressure causes bottom end failures. FA20s fail also because they have inadequate oil pressure to support higher power and RPM. I have had more failures without than with and we've built probably over 700 EJ motors and the majority of those engine failures did not have a light weight pulley. My FA20 had failed twice without lightweight pulleys and never with but neither the failure nor the success had anything to do with the pulleys. It was 100% a result of fixing the actual issue which is the lack of adequate oil pressure to support the HP. Run pulleys and lightweight flywheels without fear of bearing issues but you might have some idle issues Last edited by Element Tuning; 12-17-2014 at 09:34 AM. |
The Following 8 Users Say Thank You to Element Tuning For This Useful Post: | Amaya (04-07-2015), Anthony (12-17-2014), craigpitts7 (01-13-2015), FT-86 SpeedFactory (12-17-2014), hmong337 (12-17-2014), JDKane527 (12-17-2014), JohnJuan (12-17-2014), Sypher (12-17-2014) |
12-17-2014, 02:14 AM | #12 |
Drives: 2013 Raven FR-S
I have a lightweight crank pulley, and it's fine but I've been hearing some clacking noise. I don't know if I need to put the stock crank pulley back on and take it in....
12-17-2014, 04:14 PM | #13 |
Add lightness!
Drives: 17' WRX
I have had a lwcp, act prolite flywheel and aluminum driveshaft for 15,000+ miles now. I did have some idle dip issues which were fixed by raising idle to 900rpm. I tried out an ATI harmonic balancer and had more issues with that.
12-17-2014, 05:01 PM | #14 |
Drives: '14 Midnight Purple FR-S
Flywheel chatter is normal with lightened flywheels.
Similar Threads | ||||
Light weight flywheel and crank pulley? | wootwoot | Engine, Exhaust, Transmission | 133 | 06-23-2015 01:04 PM |
[SOLD] FS: Perrin Lightweight Crank Pulley | wdninja | Engine, Exhaust, Bolt-Ons | 2 | 07-11-2014 11:27 PM |
Lightweight crank pulley | Vlady | Engine, Exhaust, Transmission | 112 | 01-09-2014 09:28 PM |
Lightweight Crank Pulley | Vlady | Want-To-Buy Requests | 3 | 01-02-2014 11:31 AM |
FS: AgencyPower Lightweight Crank Pulley | Firestorm_86 | Engine, Exhaust, Bolt-Ons | 0 | 11-22-2013 04:13 PM |
