Old 04-07-2015, 01:17 PM   #1
jimmer1290
Amateur Car ***ifier
Drives: 2013 FR-S base
exhaust and headers....tunings required? PLEASE HELP
Hey so I have a 2013 fr-s manual. I am looking at installing borla equal length headers, a greddy evo cat back exhaust system and a greddy cold air intake.
Two questions:
This is my first mechanical project on the cat anyone do this set up or gave tips?
Secondly, will my car require tuning after these changes are made, I use the car about 3 times a week so decent daily driver and I am unsure if the mods will make it unstable.
jimmer1290 is offline   Reply With Quote
Old 04-07-2015, 01:40 PM   #2
jvincent
jvincent's Avatar
Advice: Check out the DIY section of the forum. All of the mods you are thinking of have examples there.
Tuning: The only mod that would really require a tune is the header change. I'm assuming you are going catless. The CAI might need the MAF scaled, but depending on where you get your tune done it might be included as part of that. Cat back does not benefit from tuning.
Old 04-07-2015, 01:43 PM   #3
jimmer1290
Well for now I'm just doing the headers and leaving the oem cat alone, ill deal with that later if I chose to. For now just the headers and the cat back everything in between is stock
Old 04-07-2015, 01:47 PM   #4
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
The stock header has a cat in it.
After a while 50+ miles you'll probably get a check engine light if you don't get a tune. Not to mention you'll run leaner than you probably should. Your car won't immediately explode or anything, but it will run better and safer with a tune.
Bobblehead is offline   Reply With Quote
Old 04-07-2015, 01:49 PM   #5
jimmer1290
Oh wow I did not realize the cat was directly in the headers I thought it was later on in the line.
Old 04-07-2015, 01:53 PM   #6
jvincent
jvincent's Avatar
We have a two cat system. There is a cat in the header and a second one downstream in the mid-pipe IIRC.
Old 04-07-2015, 01:59 PM   #7
jimmer1290
Wow ok might be better for me to just scrap the headers for now unless I find one with cat and just do the exhaust until I'm ready to get it tuned etc.
Old 04-07-2015, 02:24 PM   #8
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
if you aren't ready to get a tune with the header you'll be far better off replacing the catback and front pipe (which houses the second cat) and leaving the rest stock. no CEL and no tune needed.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following User Says Thank You to RobertPaulson For This Useful Post:
Teseo (04-07-2015)
Old 04-07-2015, 02:47 PM   #9
jimmer1290
if I replace the front pipe, can I get one without the second cat and not need tuning, or can you get an aftermarket one with cat system
Old 04-07-2015, 03:04 PM   #10
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Correct. If you buy a catless front pipe, a tune will not be needed. You can also buy one with a cat.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 04-07-2015, 03:17 PM   #11
Jonsey
Jonsey's Avatar
Not sure what your goals with the mods to the exhaust are, but note that almost all of the power comes from removing the cat in the header and getting it tuned. You will change the sound by replacing the rest of the exhaust but the power gains will be marginal.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
The Following User Says Thank You to Jonsey For This Useful Post:
RobertPaulson (04-07-2015)
Old 04-07-2015, 04:44 PM   #12
Teseo
Drives: frs
Welcome
Old 04-07-2015, 05:59 PM   #13
steve99
Drives: FT86
Two questions:
Read the Basic Bolt on Mods and Tuning link below
Old 04-07-2015, 09:09 PM   #14
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
+1 to this
If you don't care about performance and just sounding fast/nice, get an aftermarket Catback etc.
If you are interested in performance, look into getting a header/tune: such as the Open flash tablet // Open Flash Header combo. http://www.openflashtablet.com/Autom...OFH/index.html
One of the best upgrades you can do to this car for $1K, that alone will nearly remove the torque dip and you can further remove the dip by switching to E85 fuel.
Refer to Steve's many many helpful threads that he has in his signature
Aztec is offline   Reply With Quote
borla, exhaust, greddy, headers, tuning
Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers JonMotoring Engine, Exhaust, Bolt-Ons 314 01-22-2016 12:19 PM
UPDATED WITH INSTALL PIX: TRD rear bumper, NO cutting required, dual exhaust friendly VakaGT Cosmetic Modification (Interior/Exterior/Lighting) 28 04-10-2015 04:34 PM
Some assembly required for this exhaust... Vracer111 Engine, Exhaust, Transmission 1 01-13-2015 09:10 AM
Any srt exhaust owners here running headers to go with your exhaust? Astroboy Engine, Exhaust, Transmission 10 12-18-2013 09:33 PM
Are new gaskets required with new headers? IAmNotTheDriftKing Engine, Exhaust, Transmission 20 11-14-2013 10:18 PM
