Old 01-13-2015, 12:41 AM   #1
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Some assembly required for this exhaust...
The main part of my new custom center exit exhaust system has arrived...
What my plan is:
I realize the muffler is backwards in the diagram... it will be orientated the correct way and I'll use torca clamps to secure it to the pipe sections. A few changes were made when ordering the parts, went with 3 1/2" transition sections for the exhaust exit instead of 3" as I realized 3" is probably a little too small for the tip and they both cost the same. Spherical bearing ended tie rods are going to support the single exit section at the two factory heat shield bolt locations, keeping it firmly located laterally but allowing for forward and aft contraction/expansion.
Going to need to mock it up and figure everything exactly out before I proceed with the actual one. Not sure how long it will be until it's completed... but having the stock exhaust back on is really getting to me.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 01-13-2015, 09:10 AM   #2
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Looks good man, I did 3in custom work on my Camaro
nothing sounds better
goodluck
BlueSky is offline   Reply With Quote
custom exhaust
Maintenance Required? Dan86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 01-23-2013 01:58 PM
Some Assembly Required by blipshift - This week's shirt blipshift Miscellaneous 27 12-02-2012 07:25 PM
Get a JSC Speed "Some Assembly Required" BRZ Shirt Free! JSC Speed Announcements, Contests, Giveaways 0 11-08-2012 02:34 PM
JSC Speed & Blipshift Bring You "Some Assembly Required" JSC Speed Announcements, Contests, Giveaways 0 10-10-2012 09:21 AM
