Old 04-07-2015, 05:55 AM   #1
RMP
Drives: 1992 Isuzu PuP, 2014 FR-S
Center of Gravity Location
Was wondering where the CoG is located i.e. optimal spot to place an accelerometer?
RMP is offline   Reply With Quote
Old 04-07-2015, 07:42 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
*raises hand*
Why does it have to be "optimal spot"? What are you trying to achieve?
Old 04-07-2015, 08:42 AM   #3
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Don't know the answer, but it's pretty straightforward experiment, if you've got access to scales.
http://www.longacreracing.com/techni...spx?item=42586
Weight, lift the car, put blocks under 2 scales, lower the car, then weigh again.
If you only need an approximation, you can probably do some redneck engineering... by measuring the wheel gaps (or fender height) instead of weight and get in the ballpark.
@ Captain Snooze - It's "optimal" if you've matched your static roll centers to the CofG. Theoretically, it minimizes roll for the vehicle. It's a nice goal, but rarely achievable.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
The Following 2 Users Say Thank You to Shankenstein For This Useful Post:
fika84 (04-07-2015), RMP (04-07-2015)
Old 04-07-2015, 09:14 AM   #4
DarkSunrise
DarkSunrise's Avatar
Here's a visual representation from the side profile.
http://media.caranddriver.com/files/...fr-s-specs.pdf
2022 BRZ Build
2013 FR-S Build
The Following 9 Users Say Thank You to DarkSunrise For This Useful Post:
8R6 (04-10-2015), brandonblt2 (04-07-2015), DAEMANO (04-10-2015), fika84 (04-07-2015), hmong337 (04-09-2015), Jetbill (04-10-2015), RMP (04-07-2015), Shankenstein (04-07-2015), Wepeel (04-07-2015)
Old 04-07-2015, 10:38 AM   #5
fika84
fika84's Avatar
Why would you want to achieve that? Seems to me that you wouldn't be using your suspension to it's full potential if you're just reducing elastic weight transfer and increasing geometric weight transfer. You are minimizing roll, but not minimizing weight transfer, right?
fika84 is offline   Reply With Quote
Old 04-07-2015, 11:43 AM   #6
Shankenstein
Frosty Carrot
I'm probably taking a too simplistic approach to this (not an expert).
My understanding was that you want to maximize the grip available from all tires. Disregarding camber gain, you do this by keeping an even weight distribution. You can do this through sway bars or through the geometry (as you said elastic vs inelastic force management).
This is why double wishbone suspensions are the balls... they send alot of the lateral force through the arms (rather than the spring). That allows the spring to manage bumps and road inputs. Another perk is that wishbone length can be used to control camber gain in near isolation if there's not much KPI.
Roll angle is just the difference ride height between two wheels. Sway bars suck the inside wheel down to keep the car flat. By using inelastic weight transfer, you resolve the forces without involving the spring or resorting to sway bars. If the car's chassis and bushings are stiff enough, there's really not much penalty (as long as you don't mind the car riding like a go-kart).
Old 04-07-2015, 12:32 PM   #7
fika84
fika84's Avatar
I do agree with you. You do want to maximize grip through all 4 tires, but doing that like a go-kart I think is a bit on the simplistic side (as you said). The issue you would run into is having the weight transfer happen to quickly and breaking traction loose. Which is why go-karts are so much fun!! The elastic weight transfer portion allows you to tune the vehicle suspension to handle both small and large radius corners.
Old 04-07-2015, 01:20 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I like this description
Old 04-07-2015, 02:05 PM   #9
Shankenstein
Frosty Carrot
I mean... they typically have atleast 2:
The Following 3 Users Say Thank You to Shankenstein For This Useful Post:
cdrazic93 (04-07-2015), fika84 (04-09-2015), wparsons (04-07-2015)
Old 04-07-2015, 06:56 PM   #10
RMP
*raises hand*
I'm building a data acquisition system and the accelerometer is able to measure g forces most accurately when placed at or near the COG.
Old 04-07-2015, 06:56 PM   #11
RMP
Exactly what I was looking for
Old 04-09-2015, 02:55 PM   #12
fika84
fika84's Avatar
Please tell me you're building this with an Arduino?!?? I started collecting parts to do this... accelerometers as cheap as shit these days!! 6 axis w gyro and temp built in
You should let us know how this progresses!
Old 04-09-2015, 03:01 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ive been in a few tesla P85's with accelerometers on the headrests...
My assumption would be putting the car in the center of mass reference frame so you can find the point to place the sensor.
If i only had the computing power to model this whole car into some fun programs...
Old 04-09-2015, 04:02 PM   #14
Racecomp Engineering
Ummm...I was about to post the same thing.
I have an arduino sitting next to me right now. I have all sorts of ideas, not enough time!
- Andy
Roll center location? :iono: BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 09-05-2014 10:20 AM
Anyone doing brake bleeding with the "Gravity Method"? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 11 03-03-2013 03:53 PM
BRZ Low Centre of Gravity from the experts. Subactive BRZ First-Gen (2012+) — General Topics 1 09-23-2012 11:32 PM
