Old 04-03-2015, 03:02 PM   #1
srizzors25
Daedalus Moto
srizzors25's Avatar
Lug Nut Issues!
I've been dealing with a frustrating problem that seems pretty stupid...
Bought some ESM wheels a couple weeks ago and some Muteki SR48 lugs to accompany those, assumed that would be a good choice as everyone seems to have them
Now the wheels are dual drilled of course (ccw replicas etc knockoff wheels fun times) for 5x100/5x112. Naturally the 5x112 pattern gets the normal size lug bore in the wheel that fits any tool.
However the 5x100 bolt pattern has a super narrow bore for where the lug nuts go. I measured it and it sits pretty much right at .880" The mutekis are 17mm hex external for which pretty much all sockets sit between .9 - .92" so there is no way to fit the tool in the hole.
I had the key that came with the sockets machined down at work, but we didn't go down enough so I ground it some more after hours. Looks like shit, but it works. However the wall thickness is very thin in the thinnest of locations and I don't trust it long term
Any suggestions for lug nuts? Maybe something with an internal hex for an allen key or something? Do I just grind a new one down and hope for the best that it doesn't crack at 89 ft lbs?
The wheels are on the car now but you know its not an ideal situation
Old 04-03-2015, 03:21 PM   #2
swarb
Spline type. Don't risk modifying the socket, once it goes out you'll be assed out. Maybe someone here can measure the outside diameter of the spline socket.
Old 04-03-2015, 03:37 PM   #3
srizzors25
Daedalus Moto
srizzors25's Avatar
That would be fantastic if it fit. I emailed one supplier of muteki spline lugs they told me their socket for that sat at .90", maybe there's another company with a narrower setup?
Old 04-03-2015, 04:22 PM   #4
swarb
Not many sockets are much smaller than 23mm or .9"
Only other solution I can think of is where the lug nut is tightened from the inside with a hex key. Something like this-
I had a set before and they worked fine, just be careful with the key or get an extra as the edges can be rounded off pretty easily.
check gorilla or a local parts store.
Old 04-03-2015, 05:56 PM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
was going to suggest these... had them before as well and my experience was similar with regards to the edges. not a big fan
asdf is offline   Reply With Quote
Old 04-03-2015, 06:10 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your wheels are forcing you to use "tuner" lug nuts.
Solutions:
1) get tuner lugs
2) get rid of wheels and get wheels that have friendlier lug holes
3) get rid of wheels and keep it stock
-alex
8R6 (04-03-2015)
Old 04-03-2015, 09:36 PM   #7
StRacngtC06
StRacngtC06's Avatar
Drives: 2013 Whiteout FR-S
Extended lug nuts?
StRacngtC06 is offline   Reply With Quote
Old 04-04-2015, 09:15 AM   #8
tlim
Drives: Scion FR-S
I had the same issue with my Enkei Performance KLAMP wheels. I even bought the Muteki nuts thinking they would fit since they are tuner nuts, but they didn't. Anyway, the Gorilla spline nuts work for me. The outside diameter of the socket is 0.802 as seen in the photo. I originally had their closed nuts (came with the wheels), then once I put in ARP studs, I got the open ones.
tlim is offline   Reply With Quote
The Following User Says Thank You to tlim For This Useful Post:
srizzors25 (04-06-2015)
Old 04-04-2015, 09:36 AM   #9
wparsons
wparsons's Avatar
Solutions:
1) get tuner lugs
Originally Posted by StRacngtC06 View Post
Extended lug nuts?
Muteki SR48's are extended tuner lugs already...
flickr
RobertPaulson (04-07-2015)
Old 04-04-2015, 03:06 PM   #10
mav1178
mav1178's Avatar
No, they are 17mm lugs and will still fall into the same category
The "tuner" lugs I speak of is old nomenclature... it's basically a lug that uses a hex key (or similar) and is not removed by a standard socket.
For OP's wheels, he needs internal drive lug nuts that has a key. I call it "tuner" lugs because that's what I was selling for certain types of wheels on the market.
-alex
8R6 (04-07-2015)
Old 04-06-2015, 11:17 AM   #11
srizzors25
Daedalus Moto
srizzors25's Avatar
Thanks guys, the wheels are going to stick around of course but that is kind of what I figured. @tlim, thanks for the suggestion .80" would fit without any issues I'll look into those.
So "tuner" lugs or small diameter spline it is. I talked to a shop that sold the Muteki spline lugs but they won't work as the OD is about .90" even with those which is a shame.
Thanks a bunch guys appreciate the help
These are the guys? (they come in 12 x 1.25)
[ame="http://www.amazon.com/Gorilla-Automotive-21133BC-Diameter-Thread/dp/B001O0AMZS/ref=sr_1_1?ie=UTF8&qid=1428333508&sr=8-1&keywords=gorilla+lug+nuts"]Amazon.com: Gorilla Automotive 21133BC Small Diameter Acorn Black 5 Lug Kit (12mm x 1.50 Thread Size) - Pack of 20: Automotive[/ame]
Old 04-06-2015, 05:55 PM   #12
tlim
Drives: Scion FR-S
They look right (12mm x 1.25 version), this is what I got:
[ame="http://www.amazon.com/gp/product/B001O0CCJW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1"]Amazon.com: Gorilla Automotive 20023SD Acorn Open End Chrome Small Diameter Lugs (12mm x 1.25 Thread Size) - Pack of 20: Automotive[/ame]
Good luck!
Old 04-06-2015, 06:16 PM   #13
adamg
Drives: brz
cheap wheels are cheap
adamg is offline   Reply With Quote
Old 04-06-2015, 06:47 PM   #14
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Your point?
Oil issues with my avo brz...help!!!!! brz2013 Forced Induction 22 10-19-2016 11:03 AM
So more issues. bdanisi Issues | Warranty | Recalls / TSB 40 12-03-2014 03:30 PM
Oft e85 issues sosick Software Tuning 14 05-22-2014 05:40 PM
Anybody Have Zero Issues? Don Ivey Scion FR-S / Toyota 86 GT86 General Forum 129 03-25-2013 01:14 PM
Anybody with no issues? tdoggy57 Scion FR-S / Toyota 86 GT86 General Forum 49 08-04-2012 03:41 PM
