#3179 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I had the same issue of leaking at the top banjo for a bit. Problem was that I had created some grooves on the banjo with a set of pliers pulling them off of the hose at some point. Replaced the banjo and washer and problem was fixed. Sent from my iPhone using Tapatalk |
#3180 | |
Boosted Noob
Where is the check valve being used on this kit. My kit didn't come with one originally but I just recently bought one for use with my catch can. Sent from my iPhone using Tapatalk |
#3181 |
Drives: 2013 Scion FRS in white out
I'm using mine between the intake manifold and the crank breather. Crank should be vented but not able to see boost
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
#3182 |
Drives: 2013 Toyota 86
I thought the crank breather hose was plumbed back in before the supercharger?
#3183 |
Sorry maybe I'm calling it the wrong thing but I'm talking about the pcv hose
#3184 |
Yeah pcv sounds right!
#3185 |
Drives: frs
When car is cold use gates carbon drive to set the frequency to I think (check the specs) 60-61hz (pinch the belt as close to the center as you can get and try to get consistent readings on the app). Keep in mind that when you tighten the pulleys bolt it will also increase tension a bit, so it's pita to set it exactly to 60hz.
#3186 |
Drives: 2014 BRZ
I'm looking at buying this kit and trying to decide between the C30 and C38.
What's the risk with the C38 - pushing the stock motor to the limit? What's needed (recommended) to run it? I assume upgraded injectors, a tune, possibly a fuel pump. I would prefer not to pop my motor and/or run the system in an inefficient way. I have 93 octane here and that's what I would be running. Sorry If this has already been discussed to death in the thread. |
#3187 | |
Drives: Fast
The C38 on the other hand goes 400+ and most would tell you to build your engine. I'm not sure how well it runs at a lower level to keep you from getting too much power/torque in comparison to the C30. The C38 just has that upper expandibility so unless you plan on building your engine and going nuts, I would stick with the C30 and have some fun with E85. |
#3188 | |
Drives: 2013 Ultramarine FR-S
Just keep in mind all the power will be up at the top and there isnt much down low with centrifugal superchargers. |
#3189 |
Drives: '13 FRS
I just installed my Kraftwerks supercharger kit over the weekend. Only issue not covered in the install was the evap lines. They really need to be secured better.
Now that my evap is figured out I only have one issue. My maf when plugged in kills the motor. I cannot start the motor when it's plugged in. I need ideas on wether it just needs replaced or if it's part of the base tune sent with the tuning kit. Love the car ten times more now! |
#3190 |
Anyone else running catch-cans? Here is my drivers side can after 1 track day at Chuckwalla (~120 minutes of track time) and ~2,000 miles after that.
Mostly fuel-smelling liquid with some sludge floating and covering the bottom. The scary part is that this is max fill once screwed on...eeks.
Complete Part Out: http://www.ft86club.com/forums/showthread.php?t=125688
#3191 |
I'm running the c38 on the stock motor and stock fuel injectors and pump. I am running a 91 Octane tune and a I also have a 93 tune. I will be doing some logging this week but so far everything feels great. Yes it's way under utilized but it runs fine.
#3192 | |
I believe all supplied tunes are now SD and not hybrid like they were. But call them just to double check. |
| Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
| All SUPERCHARGER kits compilation thread | subatoy | Forced Induction | 76 | 03-10-2016 12:38 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
