go_a_way1
Old 04-05-2015, 11:55 PM   #99
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Originally Posted by NotEric6 View Post
How many threads were still engaged at -4 deg camber? Most wheel studs call for 8 threads of engagement, but realistically 4 threads is game for the average hard-parked tuner.
What about thread tolerances? Wild guess is that's 3/4-16 UNF thread. You've got options to fiddle with (Class 1A, 2A, or 3A). If tolerances are loose (read 1A), the free play could be contributing here.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline
Old 04-06-2015, 12:49 AM   #100
PowderfaceTr.
PowderfaceTr.'s Avatar
Drives: stock
Is it possible that the your prototype has overheated? I would recommend you cnc a billet of 5083. It is most stable. You wont need to replace the LCA it after 100 hours of driving. Most areospace grades have time limits. Think of the long term loss of tempering from shock rebound stress and lateral forces.
Structurally, I would put the meat on the belly and curve that mass up to the ball joint and waffle the topside. A plastic cover would keep rocks from collecting.
Advice On Proper Fundamentals of Japanese Motor Vehicle Feel free to ask.
PowderfaceTr. is offline
Old 04-06-2015, 12:52 AM   #101
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Over an inch of thread engagement on the adjuster, which would be 18+ threads. I specified 2A on the print, but I think due to manufacturing techniques it came out closer to 3A. This is just a result of improper material selection in my opinion, which is my fault.
VerusEric is offline
Old 04-06-2015, 01:09 AM   #102
VerusEric
VerusEric's Avatar
Originally Posted by PowderfaceTr. View Post
Is it possible that the your prototype has overheated? I would recommend you cnc a billet of 5083. It is most stable. You wont need to replace the LCA it after 100 hours of driving like the super light weight stuff. Think of the long term loss of tempering from shock rebound stress and lateral forces.
Structurally, I would put the meat on the belly and curve that mass up to the ball joint and waffle the topside. A plastic cover to keep rocks from collecting.
We think it contributed to the failure, but we don't think it would have increased the longevity to the point of passing our tests.
5083 isn't strong enough to handle the loads we're asking of the LCA, adjuster, or rod end (as designed). Thanks for the thought though! Always like learning and researching new materials.
The Following User Says Thank You to VerusEric For This Useful Post:
PowderfaceTr. (04-06-2015)
Old 04-06-2015, 01:26 AM   #103
PowderfaceTr.
Drives: stock
5083 isn't strong enough to handle the loads we're asking of the LCA, adjuster, or rod end.
Meant to say H323
Most people use 6082-t6 with a 3 mm minimum gage
They both weld great. So you can add a bead to the weak areas for proto and then CAD the final.
Old 04-06-2015, 05:12 AM   #104
Calum
That Guy
Drives: 2013 asphalt FRS MT
Thanks for the words of encouragement. I was personally fairly upset as I'm the main person working on this project. When I put it in context though, it really didn't do that bad and would have lasted a few seasons under severe race conditions. We are dealing with a street car though and we want even more longevity built in.
I should also point out we are testing this at around 4 degrees of negative camber. This is to stress it in the absolute worst case we can.
Since we need to prove that it broke.
I wasn't asking for pics of the break, I was asking for pics of how the stock one fails. But thanks.
Calum is offline
Old 04-06-2015, 01:47 PM   #105
VerusEric
VerusEric's Avatar
Meant to say H323
Both materials are still too weak to handle the loads as currently designed.
Ahh, understood. I have a suspicion that the OEM may not break like most people think it will. It's designed well and probably costs next to nothing to make. I see it being weak in lateral acceleration (enough to withstand 2G turns though) but strong in bump. Time will tell.
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
Calum (04-06-2015), MINOCIN (04-06-2015)
Old 04-06-2015, 03:45 PM   #106
PowderfaceTr.
Drives: stock
My understanding is the stronger alloys are not able to keep their strength for long periods of stress. Given the conditions of use, one may not be able to get a lighter design. A stronger unit of the same weight is possible.
I read someplace that alloy has better lateral strength than a steel LCA.
Where are you calculating for the greatest loads and what are they?
Old 04-06-2015, 04:39 PM   #107
VerusEric
VerusEric's Avatar
The FEA analysis is listed earlier in this thread.
Largest loads are lateral load (1.7G lateral, which is actually very little in comparison to the bump load, which is 4.5G for our tests.
Old 04-06-2015, 09:18 PM   #108
PowderfaceTr.
Drives: stock
w=900&h=423
This seems like the weakest link. LOL
Old 04-06-2015, 09:23 PM   #109
VerusEric
VerusEric's Avatar
The place where you removed the most material is the place where strength was needed most.
1) We used to be Hancha, but separated as the owner was no longer active. As a result, the information is not updated as we find flaws.
2) Please refer to this FEA analysis and not that FEA analysis; we believe ours is more accurate than that model.
3) We aren't breaking the LCA, we're breaking the adjuster.
We believe we have the update to fix this issue under control .
Old 04-09-2015, 02:45 PM   #110
VerusEric
VerusEric's Avatar
Locked and loaded for a new round of cyclical loading events. We highly doubt we will see an issue from this barrage of tests but we should know after this weekend .
Captain Snooze (04-10-2015)
Old 04-11-2015, 02:21 PM   #111
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I've really enjoyed reading this thread and think you guys are doing a great job - between this product and the intake you're working on, I'm very impressed with your company and your attention to detail.
RJasonKlein is offline
The Following User Says Thank You to RJasonKlein For This Useful Post:
VerusEric (04-11-2015)
Old 04-11-2015, 05:54 PM   #112
VerusEric
VerusEric's Avatar
We enjoy positive feedback, so thank you! We are learning a lot and having some fun doing it. Hopefully someday it will be our full time job .
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus' Shop BRZ - Development Thread VerusEric Member's Car Journals 266 12-19-2019 04:12 PM
FT-86 SpeedFactory Diffuser by Verus - Complete Aero Solution FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 574 09-15-2019 10:10 AM
FT-86 SpeedFactory Turbo Kit - Development and Testing FT-86 SpeedFactory Forced Induction 271 09-19-2017 11:07 PM
Front Wheel Deflectors - FT-86 SpeedFactory by Verus Engineering VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 25 09-22-2016 01:41 AM
