Old 04-05-2015, 08:49 PM   #141
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
Originally Posted by KslayFRZ View Post
I think it's must the fuel load if I read correctly,.and those are the smaller ones lol. It's loud af
mind posting a pic of your edited tables?
andrew5826 is offline   Reply With Quote
The Following User Says Thank You to andrew5826 For This Useful Post:
KslayFRZ (04-05-2015)
Old 04-05-2015, 09:02 PM   #142
KslayFRZ
KslayFRZ's Avatar
Drives: 2013 Frs asphalt
I copied your chart completely, but I'll double check in the morning
KslayFRZ is offline   Reply With Quote
Old 04-06-2015, 12:45 AM   #143
andrew5826
Señor Member
andrew5826's Avatar
Drives: BRZ SWP
cool, do you have a resonated front pipe? looks like it needs to be completely catless for flames as i had no flames running a stock front pipe with jdl uel and tomei type 80
Old 04-06-2015, 09:44 AM   #144
KslayFRZ
KslayFRZ's Avatar
No resonators no cats :o
The Following User Says Thank You to KslayFRZ For This Useful Post:
andrew5826 (04-06-2015)
Old 04-19-2015, 06:57 PM   #145
Flat_4_Life
Flat_4_Life's Avatar
Drives: 2015 SBD Turbo Halo FRS
Originally Posted by andrew5826 View Post
did some testing and changes to achieve a noisier exhaust. no damage to anything so far and barely any changes in gas mileage(.1 L/100km).
with just ignition base timing A modified, no pops produced. ignition base timing B produced some pops, but not as aggressive. i ended changing both ignition base timing maps A and B to -10* timing in the lowest load column(.15g/rev). with the lowest load at negative timing, it kind of made the throttle an on/off switch for the pops. you wouldn't reach that engine load when normally driving or when decelerating. but if you gave it the slightest bit of throttle to that sweet spot, it would spit pops and become obnoxious. but everyone loves it. changing the full decel engine load value to negative timing doesn't produce pops for some reason. but its better to not have pops at full decel because you don't want to constantly become a pack of firecrackers when coming to a stop.
after messing with the ignition maps, i started looking into fueling. with the overrun enrich rpm delta activation set to 6000, the pops were alot more aggressive and rally sounding, as opposed to before where it sounded like you were running over a bunch of pop cans.
trying to achieve flames but i think this is as far as im going. i don't want to break stuff
UPDATE 3/16/2015 wow hard to believe this was a year ago.. just an update
don't mess with fueling or overrun. it was probably more placebo effect than it actually doing anything. just do ignition map B. A is a limp map. read through the whole thread before you attempt this on your own car
will get some driving videos up. just need a exterior camera mounting solution
bored @ a railroad crossing under a roof
Could you help me do this with my 2015 FRS I've never used romraider before so I'm kinda unsure
Flat_4_Life is offline   Reply With Quote
Old 04-20-2015, 08:06 PM   #146
Flat_4_Life
how do you edit the table?
Old 04-20-2015, 08:42 PM   #147
Tenchi
Tenchi's Avatar
Drives: Silver Ignition 6MT 10 series FR-S
Read the thread from the beginning.
Tenchi is offline   Reply With Quote
Old 04-20-2015, 09:02 PM   #148
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
You think with catless headers, resonated front pipe and mid pipe and straight pipe axle back will it shoot flames? I can't drive with the car fully catless cause its so loud... I mean I would, but tickets and such aren't my goal. Trying to see if theres a sound difference between a catted vs a catless resonated front pipe and if it will shoot flames!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 04-20-2015, 09:03 PM   #149
Tenchi
Tenchi's Avatar
No.
Old 04-20-2015, 09:07 PM   #150
FRS Johnny
FRS Johnny's Avatar
Originally Posted by Tenchi View Post
No.
k.
The Following User Says Thank You to FRS Johnny For This Useful Post:
akahenry (05-01-2015)
Old 04-23-2015, 08:27 PM   #151
Flat_4_Life
Originally Posted by carlitosway6891 View Post
just did this to mine, i have the Borla UEL header, factory overpipe, factory front pipe, vibrant muffler, factory muffler delete.....
below 4500rpm, it sounds like intermittent popcorn popping in the microwave....above 5000rpm.....yea lol..... it sounds like someone shooting a gun at times....super loud! i will try to take a video one day and have someone following me recording cause it sounds like there would be fireball pops being how loud it pops at times above 5K rpm =)
Did you only change the ignition B?
Old 04-24-2015, 05:20 AM   #152
akahenry
akahenry's Avatar
Drives: '18 STi
I'm going to try this and will post a sound clip this weekend if all is good. If not, fuck me.
akahenry is offline   Reply With Quote
Old 04-24-2015, 07:25 AM   #153
Tenchi
Tenchi's Avatar
Kiss your muffler packing goodbye lol.
Old 04-24-2015, 07:28 AM   #154
KslayFRZ
KslayFRZ's Avatar
I set fire.... to The rain
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
