#29 |
Off Topic
| The Following 3 Users Say Thank You to gramicci101 For This Useful Post: |
#30 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
I installed the SPC 81305 14mm bolt in the lower hole along with the OEM crash bolt in the upper hole and got -2.6 max up front (lowered on RCE Yellows).
You rarely get the advertised range but you should get at least a degree out of it. Sounds like user error imo. |
#31 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
What's your after RCE rear at for camber? I still need to book an alignment with Can Alignment but wondering if I even need LCAs if I'm close to 1.75-2.
#32 |
I can't remember off the top of my head and I misplaced my alignment sheet while I was moving. I want to say it was close to 1.7
#33 |
I was -1.6 and -2.4 L/R. If you are even you shouldn't need correction in the rear with the small drop
#34 |
Off Topic
#35 |
I got -1.4L / -1.5R using just whiteline bolts on stock suspension.
2022 BRZ Build 2013 FR-S Build |
#36 | |
From first hand experience, the range from full positive to full negative is very noticeable to the naked eye if you're rotating the washer. If you're not, the adjustment range is very small.
| The Following User Says Thank You to wparsons For This Useful Post: | D_Thissen (04-04-2015) |
#37 | |
Only users lose drugs.
Drives: All the time
If you have first hand experience, then you'll also know that room under an alignment rack is tight, and not exactly suited to having company. From where I was, I could see he was rotating the bolt around; I did not have a clear view of the washer itself. I suppose it's possible he wasn't orienting it correctly. But that also doesn't explain away similar experiences of others with the bolt in the bottom, and success with it at the top. |
| Camber bolts: Max camber tricks | bfrank1972 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-03-2014 10:01 AM |
| WTB Camber Bolts | JS + BRZ | Want-To-Buy Requests | 6 | 03-07-2014 07:18 PM |
| *FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
| Question about adjustable LCA's vs Camber Plates vs Camber Bolts | djdnz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 03-27-2013 11:38 PM |
