Old 11-13-2014, 12:45 PM   #155
BRZ86_
BRZ86_'s Avatar
Drives: 2014 WR Blue Subaru BRZ Limited
Good review! Definitely getting these for my BRZ
BRZ86_ is offline   Reply With Quote
Old 03-09-2015, 11:19 PM   #156
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
The BRZ looks sweet man. quick question. someone prob already asked this and i either missed it or didnt look well enough but im assuming you had to use the stock top hats when you installed straight out the box.
EightSix93 is offline   Reply With Quote
Old 03-20-2015, 07:02 PM   #157
8R6
8R6's Avatar
Drives: FRS
yeap, reuse stock top hats.
8R6 is offline   Reply With Quote
Old 03-20-2015, 07:09 PM   #158
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Ny Brz is offline   Reply With Quote
Old 03-31-2015, 01:45 PM   #159
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
@Ny Brz , how are your st's holding up? I want these but living in NJ we see a ton of salt in the winter. Searching Google I saw a few rusty sets. Did you have any rust issues?
B-R-Z is offline   Reply With Quote
Old 03-31-2015, 05:11 PM   #160
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Did you do anything else? Like install LCA and end links and etc? Or still just coilovers?
Old 03-31-2015, 05:13 PM   #161
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
ST Coilovers *Review for the Begining*
Just the stock top hats is all that is needed. I had that setup and it worked perfectly. Had enough to dial in camber for the setup I wanted too...
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 03-31-2015, 05:15 PM   #162
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
That's cool. Will you eventually need all the other stuff? I heard long term it's gonna be needed
Old 03-31-2015, 05:16 PM   #163
*LongFella
*LongFella's Avatar
Think about what camber you want to run and for what application it will be for. That should help give you a sense of getting LCA's or not. After marketer front top hats or not...
Spend money on mods with a direction in mind so you don't waste money ;-)
Old 03-31-2015, 05:18 PM   #164
Ny Brz
Hella Flush
Ny Brz's Avatar
Depends on what you are looking to do with this setup, light track and maybe some auto x on the weekends supporting mods may not be needed. Doesn't hurt though to build up everything then switch out to a more aggressive setup once you get serious.
Old 03-31-2015, 05:23 PM   #165
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Yea I feel you. I don't want to stance it or slam it or whatever. Just want to lower it an inch or two. Negative cambers not my style. Don't mind looking at others with it. So I should be good with just coilovers for a while. I mean it's going on my DD so just keeping that in mind
Old 03-31-2015, 05:24 PM   #166
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Maybe track like once or twice a year. Would it be over kill if I got coilovers with links, LCA, and arms for my DD?
Old 03-31-2015, 05:37 PM   #167
Ny Brz
Hella Flush
Ny Brz's Avatar
I always say if you can afford to do it then do it, LCA and arms and any other braces wouldn't hurt. Just make sure to have your car aligned to your liking.
Old 03-31-2015, 05:39 PM   #168
EightSix93
EightSix93's Avatar
Drives: 2013 FR-S.
Thanks for the help man!
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 05:29 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-09-2015 11:42 PM
Mann Engineering Coilovers review l8apexr CANADA 10 03-11-2014 12:11 PM
FR-S Coilovers Review sraggs42 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-14-2013 12:16 PM
Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-27-2013 03:50 PM
