#2367 | ||
Drives: SWP BRZ Limited MT
Definitely wouldn't do the staggered if I was to do it over again, but at the moment I'll be sticking with these wheels. I'd much prefer some 17" square setup in the future though. |
#2368 |
Drives: GT86
@CSG Mike, @Racecomp Engineering
I'm based in the UK and hoping you could help me out with a couple of questions? I use my car for 90% daily and 10% track (sprints). I have a set of coilovers to be fitted (Meister R / Black Art Designs GT1's). No one in the UK has tried these on a GT86 yet so I'm a bit of a guinea pig but the involvement of Black Art Designs has made me take the risk. They come with a 6kg front and rear spring and are aimed to compete with ohlins. They are camber adjustable tops at front and I have whiteline rear camber bushes to be fitted at the same time. I'm looking at an alignment something like 0 toe at the front, -1.5 deg rear and camber -2 deg front, -1.75 rear. I also have a whiteline adjustable 16mm rear sway bar I was intending to get fitted and set at the softest. So a few questions:- 1. What do you think to these alignments for my intended use? 2. Would you fit the rear sway bar and if so what setting on? 3. Would I be better fitting the front 20mm adjustable whiteline sway at the same time and again what fitting? 4. Or would I be better coilovers only and no sways? I am running 17x7" et40 6.5kg wheels with 215/45/17 federal 595rs-r tyres. I have found on track that body roll has been an issue which I'd why I was thinking of the sway bars as well as the coilovers so that I could run the coilovers a bit softer for our rubbish uk roads and also get away with slightly less camber (as the alignment I mentioned) so as to not wear the tyre edges too much. Any thoughts gratefully received and sorry about the essay! |
#2369 |
Drives: '13 Firestorm FRS
Hi guys, I recently bought a set of Tein MonoSports (couldn't pass it up after I found out CSG helped design them). These are my entry-level coils that I'm gonna practice on before I eventually move to CSG spec Super Circuit coils. Anyway, I need some help setting up the ride height. Moto Miwa stated that the FRS rear and front arms work best when lowered 20mm +-15mm. I lowered my car down to 35mm all around. However, I wanted to verify this with you. 1) When measured from the center of the wheel directly up to the fender, should the fronts and the rear be the same height, or should the rear by slightly slightly higher? Basically, how should I lower the front vs. rear? I know there are a few variables to this, the biggest one how much gas is in the tank, so let's just assume I'm talking about with a full gas tank. |
#2370 |
Drives: 2015 Series.Blue
Lowering springs on stock shocks
Are the RS*R super downs too low for stock struts? Will it cause premature damage or failure of the shocks?
#2371 | |
i'm sorry, what?
Drives: Canada
spring rates determine the rate of weight transfer, resistance to body roll, and wheel frequency over bumps higher rates mean faster weight transfer. So if you have stiff springs on one end and soft springs on another, one end will get loaded up faster. body roll generally affects your hand eye coordination (easier to drive a flat car) but also the change in camber. A car that rolls a lot has a lot of dynamic changes going on with its alignment, minimizing it helps add predictability and stability. also aerodynamics, but that's a different thing. with regards to tuning with dampers, that's an advanced topic. And it would best to google how dampers work to understand the basics before asking on how to tune them. (generally if you learn how they work and what they're responsible for then turning strategies will present themselves).
#2372 | |
An even drop front vs. rear is a safe way to go. You can actually adjust the balance of the car slightly with rake, but that's a bit more advanced. Generally, a higher rear will result in a shift towards oversteer. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | sittinSideways (04-01-2015) |
#2373 | |
2. Try the car without bigger swaybars first. They're easy to add later. 3. Yes, if you're going to add swaybars, add front and rear. 20mm front and 16mm rear is a fine combo. 4. Start there. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | DeaconRoc (03-31-2015) |
#2374 | |
Drives: GT86
When you say go a bit higher on the camber do you mean front and rear and what would you suggest? Thanks again! |
#2376 |
Off Topic
Question: I am currently at -1.7 front on RCE Yellows and camber bolts in the top hole. Is there any reason I couldn't put camber bolts in the bottom hole as well to get me up to -2.3-2.5? Or is that a safety hazard and it's time to look at top hats for that extra bit of camber?
Rears are at -2.0 purely from the Yellows, no LCA. I daily drive this car, no autox or track at the moment. I do occasionally drive like an asshat on empty roads. |
#2377 | |
- Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | gramicci101 (03-31-2015) |
#2378 |
Drives: GT86
#2379 | |
Drives: 2012 Toyota 86
| The Following 2 Users Say Thank You to troek For This Useful Post: | gramicci101 (03-31-2015), Racecomp Engineering (04-01-2015) |
#2380 |
Drives: GT86 Cosworth
Since my last post was lost I will try again.
How do the Bilstein Dampers compare to the Ohlin DFV? I cant seem to find a dyno for the Bilsteins, but what I really want to know is: 1) what percentage of critical damping the Bilstein B8 have with the 5kg RCE tarmacs at 1inch second and 2inch/second... 2) how digressive characteristics of the Bilstein B8 compare to the Ohlins in general. Thanks |
| Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
| RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| 2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
