Old 03-30-2015, 12:57 PM   #15
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by D_Thissen View Post
Yup pretty sure they are just rebranded SPC. They are in the top hole. I think I might end up swapping them to the bottom one to get a bit more camber in the front. We shall see.
Well, when I installed them in the bottom hole per the instructions, the most my alignment guy could get was .4 neg each side. Nowhere near the 1.75 claimed on the packaging. Based on this, I'd recommend keeping them in the top hole.
Old 03-30-2015, 03:21 PM   #16
D_Thissen
D_Thissen's Avatar
This may sounds dumb, but did he turn the bolt? Or did he just pop it in and tighten it?
Old 03-30-2015, 03:51 PM   #17
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
this. And, did he know that you wanted negative camber? 9/10 places freak/try and tell you negative camber is horrible and evil.
Old 03-30-2015, 04:01 PM   #18
D_Thissen
D_Thissen's Avatar
What?! You mean camber doesn't eat my tires or cause accidents?! He might have been trying to put the camber back to factory (ish) specs.
The Following User Says Thank You to D_Thissen For This Useful Post:
continuecrushing (03-30-2015)
Old 03-30-2015, 04:18 PM   #19
continuecrushing
There was a time when I didn't live near a "performance alignment" place and I would have to go to about 4 places before I found somewhere that would set alignment to what I wanted.
Most of the time I got the, "OH NO! You don't want negative camber!!! It'll eat your tires up! The specs in the computer are the best, and thats what we set the car to."
SMH...on to the next shop haha.
The Following 2 Users Say Thank You to continuecrushing For This Useful Post:
D_Thissen (03-30-2015), Racecomp Engineering (03-30-2015)
Old 03-30-2015, 05:02 PM   #20
D_Thissen
D_Thissen's Avatar
Haha yeah I had that issue too. 'Nope we cant do that', the OEM specs are so broad also. A friend of mine works at an Acura dealership and gave me a half decent alignment. Not perfect (need LCA in the rear), but better than it was before lol
Old 03-30-2015, 05:07 PM   #21
continuecrushing
oh come on, whats wrong with +/- a degree or two? lol
As long as its in the "green" right?
Its pretty bad how, uh, bad an alignment can be while still "passing". I get for most people it doesnt matter all that much, but still...
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 03-30-2015, 06:01 PM   #22
D_Thissen
D_Thissen's Avatar
Agreed, I'm upset that my rear camber is off by 0.34* between either side
Old 03-30-2015, 09:57 PM   #23
wparsons
wparsons's Avatar
Easy way to find a good alignment shop... ask if you can sit in the car while they do the alignment. If they refuse, or suggest against it, you want no part of that.
Go with half a tank of gas, and sit in the drivers seat.
flickr
D_Thissen (03-31-2015)
Old 03-31-2015, 10:41 AM   #24
oaroyale
Drives: Black BRZ
I installed mine about a year ago. when I was switching back to summer tires this weekend, I realized the camber bolts were all rusted. anyone else have that issue? (is that an issue at all)
oaroyale is offline   Reply With Quote
Old 03-31-2015, 07:57 PM   #25
venturaII
venturaII's Avatar
I've used this shop before for other vehicles with custom alignment settings, and they've always been willing to accommodate. I watched as he rotated the bolts completely around, and the camber hardly moved. He got the toe in front and back better than it was, so the alignment wasn't a total loss, but certainly not what I'd hoped for. I might swap the bolts around this weekend and give it another shot.
Old 03-31-2015, 11:53 PM   #26
D_Thissen
D_Thissen's Avatar
Shouldn't be. Just take a wire brush and give them a once over. It should clear most of it off, then if you like hit them up with some rust inhibitor.
HotRodPA (11-23-2015)
Old 04-01-2015, 11:05 AM   #27
wparsons
wparsons's Avatar
Did he also move the tabbed washer as he rotated the bolt? If not, he failed. The tab needs to be facing 180* from the lobe of the bolt. The instructions are really clear on this...
http://www.whiteline.com.au/docs/ins...ides/Z201A.pdf
flickr
Old 04-03-2015, 01:50 PM   #28
venturaII
venturaII's Avatar
Well I wasn't under the car with him, but he's not some dopey UTI dropout, and has been doing alignments at this place for close to 10 years that I know of (and likely more), so I'm going to take a wild guess and assume he knows how eccentric bolts operate. And it also sounds like I'm not the only one whose experience with them in the bottom hole has been poor.
Camber bolts: Max camber tricks bfrank1972 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 06-03-2014 10:01 AM
WTB Camber Bolts JS + BRZ Want-To-Buy Requests 6 03-07-2014 07:18 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
