#43 |
Drives: Fast
Damn people are lazy and I don't even do the pedal dance. This should be one of those "As Seen On TV" items with an infomercial and terrible actors.
#44 | |
Drives: Nevermorange FRS
It could be a toggle switch on the device itself, it could be a wired switch that you could mount anywhere you desire in the cabin. The switch could be in the form of a button, a lever, or even a fingerprint scanner... the point is that the device could be 2 things. A Pedal Dance replicator and an OBDII port pass through.
SCCA T4 - FRS
#45 | |
Drives: 2005 Toyota Camry
It does not work with my AIM Solo DL + Pivot Dual gauge. http://www.ft86club.com/forums/showp...8&postcount=80 -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | sb (03-31-2015) |
#46 |
Drives: 2013 BRz Premium
would my P3 vent gauge work with this and a splitter?
#47 |
Some Dumb Guy
Drives: wanting an Acabian
No offense to the Speed Factory, but if you own an OFT, update it.
She said it was her or the car. Longest
she had ever seen. |
#48 | |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
#49 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | TrqlessWonder (03-30-2015) |
#50 |
Lap time enthusiast
Depends on outside temp. On cooler days idling doesn't do the job. I've let the car idle for 20 minutes only to find the temp gauge is at the 1/4 mark from cold in 60F weather. It usually has to be around 1/3 for the pedal dance to work. Maybe raising the idle engine speed might help.
#51 |
Also depends if you're strictly competing, or helping volunteer at the event as well.
#52 | |
| The Following User Says Thank You to qoncept For This Useful Post: | endless_pain (04-01-2015) |
#53 | |
And regarding the OBDII Y cables, they don't work because they don't have a can bus hub in them on pins 6 and 14. There are actually several generations of OBDII ports with various signaling and data rates and such, some of which are compatible with a splitter cable and others which are not. The CAN bus protocol (which this device and Solo DL work on) is one of the ones that is not amenable to simple signal splitter cables. That said, you MIGHT be able to make it work if you were to program the Solo DL to read legacy OBDII (since it is a different set of pins), though you would loose the best data channels and have slow data rates (think 1hz or 0.5Hz refresh instead of 5Hz or 10Hz).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
| The Following User Says Thank You to ddeflyer For This Useful Post: | CSG Mike (03-30-2015) |
#54 | |
It's $80 for a device that occupies your OBD-II port and automatically disables annoyances. It doesn't take 3 pages of "expert" comments to decide whether or not you want that.
| The Following User Says Thank You to qoncept For This Useful Post: | NickTC (03-30-2015) |
#55 | ||
![]() Quote:
| The Following User Says Thank You to CSG Mike For This Useful Post: | sb (03-31-2015) |
#56 | |
| The "Pedal Dance" testing | CSG Mike | Tracking / Autocross / HPDE / Drifting | 419 | 08-01-2023 11:46 PM |
| CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | romin | Engine, Exhaust, Transmission | 468 | 11-26-2021 05:05 PM |
| Where to buy "heel/toe" shaped gas pedal? | dookie11 | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 01-22-2019 12:24 PM |
| Pedal Dance Device | robot | Tracking / Autocross / HPDE / Drifting | 3 | 01-10-2014 10:26 AM |
| Additional "pedal dance" testing. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 55 | 08-27-2013 04:02 AM |
