Old 03-24-2015, 07:58 AM   #43
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Damn people are lazy and I don't even do the pedal dance. This should be one of those "As Seen On TV" items with an infomercial and terrible actors.
2016 Camaro SS is offline
Old 03-24-2015, 11:45 AM   #44
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Originally Posted by Rickg87 View Post
Sounds Good. Could you give some more detail about the switch and setup
Thx
That'll be up to the company that makes it. I'm just some dude on the internet.
It could be a toggle switch on the device itself, it could be a wired switch that you could mount anywhere you desire in the cabin. The switch could be in the form of a button, a lever, or even a fingerprint scanner... the point is that the device could be 2 things. A Pedal Dance replicator and an OBDII port pass through.
PRO86 | WTCC | STL
rice_classic is offline
Old 03-24-2015, 12:00 PM   #45
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by simpleisbest View Post
You all know they have OBD2 splitters on the market, right?
Amazon.com: OBDII Splitter Y Cable, J1962M to 2-J1962F, 1ft (145802): Automotive
Funny enough, that's what I bought from Amazon.
It does not work with my AIM Solo DL + Pivot Dual gauge.
http://www.ft86club.com/forums/showp...8&postcount=80
-alex
mav1178 is offline
sb (03-31-2015)
Old 03-28-2015, 08:39 PM   #46
lx93
Drives: 2013 BRz Premium
would my P3 vent gauge work with this and a splitter?
lx93 is offline
Old 03-29-2015, 12:05 PM   #47
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
No offense to the Speed Factory, but if you own an OFT, update it.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline
Old 03-29-2015, 11:40 PM   #48
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by CSG David View Post
If that's one of the cases, I usually go 10% on warm-up lap to make sure everything gets up to temp and pull into the hot pit. Shut off, start up, do pedal dance, and go back out. It also allows some people to get out of the way for me so I can run some cleaner laps.
Most of the time I start up the car 5 minutes early and drive around the paddock to make sure everything else is warmed up. I have a LSD too.
Valid point, but doesn't always work. While I'm in the same boat as many here and would rather plug in a Solo DL, the car not being up to temperature is often a problem without a solution. Track days are busy for many of us, especially track veterans who instruct as well at events. Also hot pitting isn't always ideal if you're in a Time Trial session that's already too short. Normally in our region they arrange the grid in order of fastest time to minimize traffic and the chance you'll be stuck behind someone slower, hot pitting to do the pedal dance may get you stuck in traffic again, when otherwise they optimized your position.
raul is offline
Old 03-30-2015, 11:39 AM   #49
CSG Mike
CSG Mike's Avatar
If you're competing, you have no reason for not being able to let your car idle to get up to temp....
CSG Mike is offline
TrqlessWonder (03-30-2015)
Old 03-30-2015, 02:59 PM   #50
raul
Lap time enthusiast
raul's Avatar
Depends on outside temp. On cooler days idling doesn't do the job. I've let the car idle for 20 minutes only to find the temp gauge is at the 1/4 mark from cold in 60F weather. It usually has to be around 1/3 for the pedal dance to work. Maybe raising the idle engine speed might help.
raul is offline
Old 03-30-2015, 03:22 PM   #51
wparsons
wparsons's Avatar
Also depends if you're strictly competing, or helping volunteer at the event as well.
flickr
wparsons is offline
Old 03-30-2015, 03:55 PM   #52
qoncept
qoncept's Avatar
Or you can spend 2 seconds and do the pedal dance. Gawd...I hate moving after working out just my right leg and right arm.
Why would you want something to happen automatically when it only takes 5 minutes EVERY TIME YOU START YOUR CAR to do it yourself? Everyone knows what the peddle dance is, how long it takes, how strong their quads have to be. Beaten to death. Maybe there's a CSG thread you could contribute something useful to.
qoncept is offline
The Following User Says Thank You to qoncept For This Useful Post:
endless_pain (04-01-2015)
Old 03-30-2015, 04:34 PM   #53
ddeflyer
I think the point is that you shouldn't be taking your car on track when it isn't up to temp yet.
And regarding the OBDII Y cables, they don't work because they don't have a can bus hub in them on pins 6 and 14. There are actually several generations of OBDII ports with various signaling and data rates and such, some of which are compatible with a splitter cable and others which are not. The CAN bus protocol (which this device and Solo DL work on) is one of the ones that is not amenable to simple signal splitter cables. That said, you MIGHT be able to make it work if you were to program the Solo DL to read legacy OBDII (since it is a different set of pins), though you would loose the best data channels and have slow data rates (think 1hz or 0.5Hz refresh instead of 5Hz or 10Hz).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline
The Following User Says Thank You to ddeflyer For This Useful Post:
CSG Mike (03-30-2015)
Old 03-30-2015, 04:45 PM   #54
qoncept
qoncept's Avatar
The point is that there are 2 guys from a competing vendor that are 1) arguing with people about personal preference so they can 2) badmouth another vendor's product.
It's $80 for a device that occupies your OBD-II port and automatically disables annoyances. It doesn't take 3 pages of "expert" comments to decide whether or not you want that.
qoncept is offline
NickTC (03-30-2015)
Old 03-30-2015, 07:19 PM   #55
CSG Mike
CSG Mike's Avatar
Park the car facing away from the wind rather than into it
Ask someone to do it for you
CSG Mike is offline
sb (03-31-2015)
Old 03-30-2015, 08:36 PM   #56
CSG David
CSG David's Avatar
Application wise, it makes sense for certain individuals.
CSG David is offline
The "Pedal Dance" testing CSG Mike Tracking / Autocross / HPDE / Drifting 419 08-01-2023 10:46 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 04:05 PM
Where to buy "heel/toe" shaped gas pedal? dookie11 Scion FR-S / Toyota 86 GT86 General Forum 56 01-22-2019 11:24 AM
Pedal Dance Device robot Tracking / Autocross / HPDE / Drifting 3 01-10-2014 09:26 AM
Additional "pedal dance" testing. CSG Mike Tracking / Autocross / HPDE / Drifting 55 08-27-2013 03:02 AM
