Old 03-29-2015, 02:22 AM   #1
awhatzable
Drives: GTS86
what product will remove this stain on my bumper ?
I found this stain while cleaning my car yesterday. I've tried using wax,grease & tree sap remover spray cans and rubbing hard plus I tried using a plastic spoon to scrap it off. the thickness on the stain is about 1/10 of a mm, you can feel it but can't see the thickness.
On the bottom left a little above the grill you can see a horizontal line dent. If I was going to use a pen touch up paint, is sanding going to be required ? The dent is about 1/4 of a mm max.
awhatzable is offline   Reply With Quote
Old 03-29-2015, 02:47 AM   #2
bumppinKota
Drives: FRS!!!
Have you tried to clay it?
bumppinKota is offline   Reply With Quote
Old 03-29-2015, 03:13 AM   #3
Kaotic Lazagna
Drives: GR Corolla
A quality clay bar and detailer spray should be able to get that off. Not sure about the dent tho.
Old 03-29-2015, 04:00 AM   #4
donoman
donoman's Avatar
Drives: '13 FR-S
Try Goo Gone...
donoman is offline   Reply With Quote
Old 03-29-2015, 04:05 PM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Try clay or cleaner wax.
Last resort will be meguiars ultimate compound.
N1rve
Old 03-29-2015, 10:05 PM   #6
Davf24
Davf24's Avatar
Drives: 2013 FR-S, Hot Lava
Very hard with out seeing it in person.
I use several steps: (in this order)(I try the least avasive first)
1-try a bug/tar or Goo Gone remove (shake the bottle, apply and let it stay on the stain for a few minutes)
2-try a paint restorer/cleaner wax
3-try a polishing compound (if you have a buffing wheel, SLOW speed and keep it moving around don't just keep it spinning in the same spot)(the orbital unit is not the best, they will leave scratches)
4-try a rubbing compound (SLOW speed, same process as the polishing, keep it moving around)
5-If you have to use the rubbing compound, go back with the polishing compound to remove any scratches you may have added.
6-Apply a Glaze
7-Apply carnauba wax
8-high speed whole bonnet
Davf24 is offline   Reply With Quote
Old 03-29-2015, 10:14 PM   #7
stevesnj
stevesnj's Avatar
3m wax and grease remover. Most auto stores have it.
My 2016 Build thread
Old 03-29-2015, 10:36 PM   #8
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Laquor thinner will take that right off.
Jesse36m3 is offline   Reply With Quote
Old 03-29-2015, 11:38 PM   #9
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Try cleaner wax as mentioned, not sure if it's an indent or a raised bump.
Instagram: stimson
Old 03-30-2015, 03:05 PM   #10
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
+1 for clay bar and/or cleaner wax. If that doesn't work try a less aggressive polishing compound, if that doesn't work use a rubbing compound. Move from less to more aggressive.
V_86 is offline   Reply With Quote
Old 03-30-2015, 03:10 PM   #11
FRSNewb
FRSNewb's Avatar
Sulphuric Acid
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
The Following User Says Thank You to FRSNewb For This Useful Post:
bigred18 (03-30-2015)
Old 04-03-2015, 09:37 PM   #12
awhatzable
Drives: GTS86
It's a raised bump and its about 1/4 of a mm or even less.
Old 04-03-2015, 09:40 PM   #13
swarb
this because it is minimal touching/rubbing.
Old 04-04-2015, 02:11 AM   #14
HotLavaFRS
HotLavaFRS's Avatar
Drives: 2015 Scion FR-S / Base
Try this. R3 Racing Rubber Remover
http://www.mothers.com/02_products/0...tml#&slider1=9
2015 Scion FR-S Manual Base / Stock
1970 Mustang Fastback
HotLavaFRS is offline   Reply With Quote
safe way to remove bumper? Hyperian BRZ First-Gen (2012+) — General Topics 3 02-27-2014 02:11 PM
Way to remove the front grille without removing bumper? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 11-24-2013 10:15 PM
car stain; suggestions on how to remove. Janunez90 Issues | Warranty | Recalls / TSB 4 10-12-2013 02:59 AM
Best way to remove the Scion Rear Bumper Applique? Tim_Asphalt_FRS Cosmetic Modification (Interior/Exterior/Lighting) 28 12-25-2012 02:30 AM
What's a good product to remove swirl marks? Bmore_Raven86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 10-20-2012 07:30 PM
