Old 03-27-2015, 09:30 AM   #393
blown
Drives: ft86
Originally Posted by D K View Post
There is a much cheaper trans alternative on the horizon.
Just be patient guys.
which gearbox?
blown is offline   Reply With Quote
Old 03-27-2015, 11:10 AM   #394
sam69
Drives: GT 86
Maybe a Cryoed stock tranny as in my above post ??
I think this is what I'll be looking to do if I ever have the gearbox let go
http://www.cryogenicswest.com.au/auto.html
sam69 is offline   Reply With Quote
Old 03-27-2015, 11:46 AM   #395
D K
Stig's dark passenger
Ill write a post once its all done and dusted.
Its a dog box though.
D K is offline   Reply With Quote
The Following 3 Users Say Thank You to D K For This Useful Post:
BRZGM3 (03-27-2015), Budo (03-28-2015), Element Tuning (03-27-2015)
Old 03-27-2015, 11:47 AM   #396
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
I ran out of patience when I was born
Let us know what and how it shifts at 9k RPM
Element Tuning is offline   Reply With Quote
Old 03-27-2015, 11:48 AM   #397
Element Tuning
Some have tried that with no improvement. The consensus is that the gear material is very good, it's the size of the gear that's the problem.
Old 03-27-2015, 12:01 PM   #398
D K
It reportedly shits ok at 10,500, so...
The Following User Says Thank You to D K For This Useful Post:
BRZGM3 (03-27-2015)
Old 03-27-2015, 12:04 PM   #399
D K
Not only the shaft spacing but also the bearing placement.
Similar to the WRX 5speed.
Shaft flexes and with a helical gear arrangement, it doesnt take much..
Spur gear might survive a little longer, specially with a hardened shaft.
Keep in mind we are talking about transmissions here and not something else...
Old 03-27-2015, 01:12 PM   #400
Element Tuning
Originally Posted by cdrazic93 View Post
Other than the front of the car, where else would you put an oil cooler that size? I mean at this point do you need headlights because that could free you up some airflow... Off the top of my head I'm thinking under the car? But I dont think it would get enough air to pass over it, plus rocks and debris...
Well there are a number of options but they can be made part of the radiator and literally the same size. My front end is custom so I have enough space to go between the radiator and the intercooler on my car. I was also contemplating using a second cooler (Perrin Setrab) and stuffing it over by the passenger side of the intercooler (driver side houses my trans cooler).
Old 03-27-2015, 01:25 PM   #401
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Several companies make bigass radiators. I know at least one can combine transmission, coolant, and oil cooling in one. It's elegant but is it worth the money? I can't remember which company Robispec used, but I know they had a corrosion problem.
The Following User Says Thank You to EAGLE5 For This Useful Post:
cdrazic93 (03-27-2015)
Old 03-27-2015, 04:33 PM   #402
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
By increasing cooler size you advertantly increase oil capacity right?
Old 03-27-2015, 04:34 PM   #403
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I think it was bigass cooling & co. Lol
Old 03-27-2015, 05:38 PM   #404
EAGLE5
Dismember
EAGLE5's Avatar
Or Big Ass Fans? http://www.bigassfans.com
But they don't do automotive. A local gymnastics studio has one of those. They have to run it blowing upwards as blowing down made all the banners on the walls flip upwards.
cdrazic93 (03-28-2015)
Old 03-27-2015, 06:04 PM   #405
Element Tuning
Yeah but also your pump has to push more volume and a bigger core can mean more pressure drop. We are trying to do one bad thing in hopes a good thing comes out of it
Old 03-27-2015, 06:42 PM   #406
Yeah but also you pump has to push more volume and a bigger core can mean more pressure drop. We are trying to do one bad thing in hopes a good thing comes out of it
I'd agree with pressure drop due to long and/or narrow lines but all other things being equal, the increased cross-sectional area offered by a bigger core would result in it contributing less to pressure drop of the overall system, no?
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
