Old 03-24-2015, 11:18 AM   #15
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by BRGT86 View Post
my iphone seems to have magical powers to trigger the airbag sensor when i place it on the passenger seat. so annoying.
Mine did too!
0351USMC is offline   Reply With Quote
Old 03-24-2015, 11:36 AM   #16
Koa
Known issue. It's because it is NOT weight sensitive but uses a current flow to detect. Most likely it is not your iPhone but you are charging your iPhone and the connector is in the seat. Several threads on this on here.
I can make my Droid Maxx do it at will. Insert the charging plug, lay on seat, I have a phantom passenger. Unplug, no passenger. Plug back in, lay the phone so that the charging plug is lifted off the seat and on the bolster, no passenger.
Things that are wet, or liquid can also set it off. Its similar to a touchscreen or biometric reader that uses a very low current charge to make a connection.
nope, Iphone has an electrostatic aura and at least the iphone 5 and 6 unplugged will trigger the sensor if it's placed around 75% of the area.. certain spots will not trigger it (sensor shown above in the thread)
Old 03-24-2015, 11:42 AM   #17
Good to know, but same cause. A lot of folks think that its a weight sensor and it isn't, which is the real point in the end.
Koa (03-24-2015), Tcoat (03-24-2015)
Old 03-26-2015, 03:48 PM   #18
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Just to add some closure to this..
I picked up a spare FR-S passenger seat base from a wrecker and removed the occupant sensor from it. Being much more careful with the ribbon cables and also when separating the grey foam off of the seat foam, i was able successfully transfer it over to my Edirb 023 without issue.
I must have damaged something during the removal of my original one, so if anyone else attempts this, be very careful.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-24-2016, 09:17 AM   #19
S84kam
S84kam's Avatar
Drives: FBRZS
Just wanted to revive the thread to ask these questions
Questions to follow:
1 - In order to swap my FRS to BRZ heated leather seats, I only need to swap the occupancy module from my stock seats to remove the chime?
2 - will the BRZ seats still deploy without the occupancy module swap? (Leaving in BRZ Occ module and living with the annoying chime.
3 - Leaving the occupancy seat alone and living with he chime could I use techstream to disable the chime or simply add a seatbelt on? Will the airbag still deploy?
4 - with the occupancy module stock FRS or BRZ - will either scenarios cause an airbag light?
S84kam is offline   Reply With Quote
Old 06-24-2016, 02:19 PM   #20
redlined600
redlined600's Avatar
Drives: Fr-s
Emulators exist for other markets, surely it can't be rocket surgery to make one.
Maybe @Beastronix could produce something?
Hell, if someone sends me a sensor I'll figure it out, if I get stuck I have an EE on staff that I could lean on.
redlined600 is offline   Reply With Quote
Old 06-30-2016, 12:18 PM   #21
Beastronix
Beastronix's Avatar
I've added this to my potential project list. I'm stretched thin with free time at the moment, so not sure how soon I can look into it.
I can currently disable the airbag lamps, but I only do this for race prepped cars. I have no data at the moment that proves certain steps in this process actually switch the airbag deployment sensors.
Also note this is all over CAN. Defeating everything over the network is my go to, but I'm not opposed to alternatives if they are needed.
Beastronix is offline   Reply With Quote
Old 09-23-2018, 03:10 AM   #22
demariners
demariners
Drives: 2015 Blue Subaru BRZ
Did anyone get anything working here. I am having the same exact issue. I have taken the occupancy sensor out and I can not for the life of my get the airbag light off and the Passenger Airbag enabled. Any suggestions would be greatly appreciated. I can not place these inside the seats I have so I need some way to bypass this or somewhere to "wrap it up" and make it work and think someone is sitting there.
demariners is offline   Reply With Quote
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Defeating Occupant Detection Sensor TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 0 11-16-2012 01:48 AM
Understanding the BRZ/FR-S/86 Occupant Detection Sensor Turbowned Issues | Warranty | Recalls / TSB 13 08-27-2012 11:58 PM
