Old 03-16-2015, 08:18 PM   #1
Teknian_Culprate13
Teknian_Culprate13's Avatar
Drives: Scion FR-S
oil level too high?
where should it be on the dipstick exactly? is this correct?
Teknian_Culprate13 is offline   Reply With Quote
Old 03-16-2015, 09:53 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Negatory. Should be at that top dot..you're at least a quart overfilled. Make sure you're on a perfectly level surface.
JB86'd is offline   Reply With Quote
Old 03-16-2015, 10:16 PM   #3
Teknian_Culprate13
Drives: Scion FR-S
thanks for the reply ill drain about a qt and see where its at! so second dot is the max fill mark.
Old 03-16-2015, 10:19 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
should be between the 2 dots
Old 03-16-2015, 10:56 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I've corrected that for you.
Per the owner's manual:
Originally Posted by chaoskaze View Post
should be at the top dot
Originally Posted by humfrz
I'm old and lazy
Old 03-17-2015, 12:33 AM   #6
pantdino
Drives: Firestorm 2013 FR-S
Note it says the LOWER of the levels you see is the actual level
I have noticed that on my car one side must rub against the insertion tube because it seems to be completely coated way up high while the other side is where it should be.
Make sure you're actually seeing the lower level.
New oil is basically colorless so it can be really hard to see where the level is.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
The Following 3 Users Say Thank You to pantdino For This Useful Post:
Clipdat (03-17-2015), jcw99 (03-18-2015), Tcoat (03-23-2015)
Old 03-17-2015, 01:33 AM   #7
Do NOT run overfilled. Crankshaft whips it up into a nice foamy mess which is then pumped throughout. Circulating bubbles is a quick way to destroy an engine.
brandonblt2 (03-26-2015), Tcoat (03-23-2015)
Old 03-23-2015, 06:42 AM   #8
Itzed
Drives: 2014 BRZ Limited
You really need to look at that dipstick carefully. I'm only looking at it on an old ipad, so I might not be seeing it correctly, but looks like there are breaks in the oil and dry spots on the dipstick. If so, then your oil is NOT at that higher level. When it dips into the oil pan, it's going to be wet from the true level all the down until the end of the dipstick.
Itzed is offline   Reply With Quote
The Following User Says Thank You to Itzed For This Useful Post:
Tcoat (03-26-2015)
Old 03-23-2015, 07:07 AM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
Struth, that oil level is way over !
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Tcoat (03-26-2015)
Old 03-23-2015, 11:52 AM   #10
Koa
1. Did you drain out everything?
2. How many quarts did you put in?
3. Are you on a level surface?
The Following User Says Thank You to Koa For This Useful Post:
Tcoat (03-26-2015)
Old 03-26-2015, 11:10 AM   #11
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Did he check it with the engine running?
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
The Following User Says Thank You to SpeedWi For This Useful Post:
Tcoat (03-26-2015)
Old 03-26-2015, 11:43 AM   #12
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
The only separation is near the top hole and thats from oil going through it. OP definitely overfilled it by alot even when the oil is on the sides when dipping the stick it wouldn't be that much oil present.
brandonblt2 is offline   Reply With Quote
The Following User Says Thank You to brandonblt2 For This Useful Post:
Tcoat (03-26-2015)
Old 03-26-2015, 07:09 PM   #13
tyrantcf
Drives: '16 WRX, CBR1000RR
if you're on flat ground, and the oil is warm (not hot) then you are quite overfilled.
If you did the change yourself, lesson learned. If a shop did it for you, go make heads roll.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
LOC vs. High Level Input and Wiring dcaranci13 Electronics | Audio | NAV | Infotainment 4 05-30-2014 10:58 AM
My oil level was low! FRSjeff Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 12-16-2012 12:22 AM
Another Level 86's SportInjected Great Lakes 4 07-30-2012 11:13 PM
