Old 05-27-2014, 04:16 PM   #1
dcaranci13
Drives: Blue 2013 Scion FR-S
LOC vs. High Level Input and Wiring
So I finally decided to put an amp and sub in my FR-S and noticed after I took the stock HU out that it had no RCA.
After looking through the forums, I think I found the solution but I wanted to ask once more to make sure I'm doing it right.
First of all, I bought a LOC for $20 but then realized my Boss M1100 Monoblock amp has stereo level inputs. So I'm wondering which would be better to tap into the speakers.
My other question is am I correct to tap into the Signal wires in the rear factory amp's harness (pins 3,9,4, and 10 if memory serves right). Or should I tap into the Speaker wires (pins 1,5,2,6 I think)?
I do plan on having a power line from the battery to the amp.
Thanks in advance!
dcaranci13 is offline   Reply With Quote
Old 05-29-2014, 01:03 AM   #2
brianhj
Drives: 2017 Camaro 1SS
Thanks in advance!
My FRS has stock RCA out for a sub... weird. At least I'm 99% sure it does.
Either way should be fine, you're not going to notice it with just a sub. If you had a super hi-fi front end setup you'd definitely want to tap signal wires and not speaker level wires. If you do speaker level, use your LOC. If you do line level, use a hacked RCA cable.
brianhj is offline   Reply With Quote
Old 05-29-2014, 04:21 PM   #3
mid_life_crisis
Drives: FR-S 10 #103 AT
Thanks in advance!
The speaker wires are after processing in the amp to be fed to the base drivers. You want to tap the signal wires, which are theoretically unprocessed at that point. They are also speaker level, but not much power behind them. An external loc is generally not as clean as the hi level input circuitry built into an amp or active crossover, but especially not a $20.00 one. Return the LOC and go directly into the high level input of the amp from the car's signal wires.
Old 05-29-2014, 05:31 PM   #4
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
This is what I did. Works fine.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 05-30-2014, 10:58 AM   #5
dcaranci13
Sweet. Thanks for the help.
I decided to just go through the speaker level inputs, however the harness that came with the amp for the speaker level input are 24 gauge wires which seem too small...plus there aren't any tap splices for wires that small.
Went ahead and ordered the Metra harness for the factory amp (both male and female) to make a sort of extension area so I don't have to splice into the factory amp harness.
Clutch Input dabocx Forced Induction 221 01-19-2016 07:20 PM
Level Up Garage BRZ lookchris Member's Car Journals 14 11-25-2013 07:47 PM
My oil level was low! FRSjeff Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 12-16-2012 12:22 AM
Another Level 86's SportInjected Great Lakes 4 07-30-2012 11:13 PM
