View Poll Results: which one is the best?
1 2 4.55%
2 4 9.09%
3 4 9.09%
4 9 20.45%
5 6 13.64%
6 2 4.55%
other: please list 17 38.64%
Voters: 44. You may not vote on this poll
Old 03-25-2015, 05:12 PM   #29
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
My d*ck is the best strut bar.
MokSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to MokSpeed For This Useful Post:
continuecrushing (03-25-2015), FR-S_ATL (03-26-2015)
Old 03-25-2015, 05:14 PM   #30
Koa
Originally Posted by ck-GT86 View Post
Sorry to bring back an old thread, but questioning the necessity to brace the rear suspension hit me as I changed out to coils over the weekend. The (2) nuts holding in the coils on each end seemed a bit flimsy. I understand the coils are also tightly supported down at the LCA, however wouldn't adding a support brace/bar strengthen the connection to the body?
.ck
no because the cross slop between the two shocks is so small that I doubt any performance is affected by even the most extreme tension and flexation. This is due to the shocks being tied together by the floor and chassis/rear subframe to a far greater extent than the front. This is my unempirical assertion though.. need some hard pact data to confirm or deny this
Originally Posted by Lateral G View Post
I too had a lot of plans to modify. Once I bought the car, realized there arent many ways to improve it for a canyon carver/daily driver setup. You may or may not find the same. I did add the grim speed front strut tower brace, it makes a difference but wasn't neccessary.
uhh there's a ton of worthwhile mods to help with a weekend warrior/dd setup that will crush the OEM if selecting (a) quality part(s)....
- Clutch & FW
- Bushings
- Shifter
- Shift Knob
- Oil Cooler
- Slave cylinder retrofit
- HIDs/LEDs
- tires
- struts
- springs
- sways (fine tuning)
- LCAs
- a good alignment
- audio/stereo stuff
- those sweet jdm clear sidemarkers
- A tune
- E85
- exhaust
- Upgraded brake pads
need I go on sir just ask
rear strut brace shouldn't be one of them
The Following 2 Users Say Thank You to Koa For This Useful Post:
ck-GT86 (03-25-2015), Tcoat (03-25-2015)
Old 03-25-2015, 05:17 PM   #31
Your duck?
Old 03-25-2015, 05:30 PM   #32
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
Your duck?
My deck
The Following User Says Thank You to MokSpeed For This Useful Post:
Tcoat (03-25-2015)
Old 03-25-2015, 05:38 PM   #33
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
- Clutch & FW
- Bushings
- Shifter
- Shift Knob
- Oil Cooler
- HIDs/LEDs
- tires
- struts
- springs
- LCAs
- a good alignment
- A tune
- E85
- exhaust
You never fail to impress me. Thanks once again.
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
Koa (03-25-2015)
Old 03-25-2015, 05:40 PM   #34
Koa
. ck
brother just learning & sharing as I go, reading some of the comments (I read after I post ha), a guy already hit the nail on the head.. floor and seams tie 'em
The Following User Says Thank You to Koa For This Useful Post:
Old 03-26-2015, 10:18 AM   #35
tennisfreak
Drives: 2018 BMW M240i
Rear sway bar seems like a better investment to me.
Old 03-26-2015, 03:43 PM   #36
ck-GT86
ck-GT86's Avatar
Are there any bars that aren't hollow? Im a proponent on all things solid, especially if its steel. Weight doesn't matter much to me
. ck
|| My Build Thread ||
Old 03-26-2015, 04:37 PM   #37
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
. ck
Lots. Perrin, Whiteline, in fact, I think most sway-bars available are solid.
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
ck-GT86 (03-26-2015), Tcoat (03-26-2015)
Old 03-26-2015, 05:11 PM   #38
ck-GT86
ck-GT86's Avatar
Awesome, thanks!
. ck
|| My Build Thread ||
Old 04-15-2015, 08:27 PM   #39
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
.ck
no.
the "strut" has a pivot point at the bottom. therefore, virtually zero lateral load is transmitted into the housing at all. a brace at the top does nothing.
Sammakko is offline   Reply With Quote
Old 04-16-2015, 09:49 AM   #40
reigle jake
Drives: drift cars
on my volvo station wagon i just used a rachet strap from side to side it made a difference but i also filled the sides with tuff stuff
reigle jake is offline   Reply With Quote
FS: Rear strut Bar 86design Brakes, Suspension, Chassis 9 07-27-2013 02:51 AM
FS: Rear strut bar! 86design Brakes, Suspension, Chassis 3 07-08-2013 03:57 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 07:44 PM
FS: front and rear strut bar!! 86design Engine, Exhaust, Bolt-Ons 7 05-21-2013 06:45 PM
Rear Strut Tower? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-26-2012 12:14 AM
