Old 03-24-2015, 08:17 PM   #2493
TrqlessWonder
Drives: 2014 FR-S
Originally Posted by simpleisbest View Post
Just needed to get to a computer.
Please find attached the pdf copy of an official publication from Toyota's accessories group. Big thanks to Jason I. and Steve M. to help clarify this situation for all.
This letter hereby confirms that the TRD Spring and Sway bar packages have been available as port options for all year FR-Ss to date.
Enjoy!
That looks like it should get the job done for surviving a protest. Nice work.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
The Following User Says Thank You to TrqlessWonder For This Useful Post:
simpleisbest (03-24-2015)
Old 03-24-2015, 08:26 PM   #2494
toeout
What will be the end game now for the FR-S in CS? What is the earliest they could re-class the car or is it more complicated than that? Really thinking about STX->CS
toeout is offline   Reply With Quote
Old 03-24-2015, 08:28 PM   #2495
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I'm curious to see how an FRS does with those springs and swaybars now.
G_Ride is offline   Reply With Quote
Old 03-24-2015, 08:30 PM   #2496
G_Ride
G_Ride's Avatar
The earliest we would see re-classing is next year. I doubt the FRS will get re-classed.
Old 03-24-2015, 08:38 PM   #2497
simpleisbest
Senior Citizen
Drives: Scion FR-S
Hard to say. My money would be a combination of either:
1) Classify as "best of breed" of the twins for Street. Bring the RS 1.0 back into CS.
2) Move the BRZ down to D or E Street
3) Bump the FR-S entirely up to B-Street (unlikely but possible)
Either way, it is what it is. I'm interested to see how this plays out.
simpleisbest is offline   Reply With Quote
Old 03-24-2015, 09:08 PM   #2498
renfield90
The Stig's German cousin
Unless we are somehow not faster than the RX-8 or the MX-5, we're off to BS. Hell, I would expect some ringers to build out an FRS a month before nats to try and vulture the class.
Let's be real here: yes, as competitors we need to max out the rules, but this sort of disruption isn't good for the sport. Everyone with a BRZ is gonna get a shaft here.
The sane thing to do, if you're the SEB and you're seeking stability in the category after one of the most disruptive rules transitions ever, is to limit this disruption to one year. That lets the BRZ/MX-5/RX-8 crowd stay in the game for next year. Otherwise CS becomes spec FRS.
Old 03-24-2015, 09:19 PM   #2499
simpleisbest
Senior Citizen
Drives: Scion FR-S
Don't forget about the ND! It's supposed to land in C-Street and is looking like the car to have...
Old 03-24-2015, 09:45 PM   #2500
chucky12012
Drives: 2013 Asphalt Scion FR-S
I think another possibility is that the SEB simply rolls out in the end of year Fasttrack a specific rule disallowing the TRD parts for the FR-S. This would even it back out and we all know that at the end of the day, they can make exceptions to a rule if they feel so inclined. That being said, thank you for doing the leg work to dig into this. I'm not sure how my revalved Bilsteins will play with the lowering springs anyways, so Ill watch from the sideline to see how it all works out.
chucky12012 is offline   Reply With Quote
Old 03-25-2015, 12:15 AM   #2501
Wepeel
Drives: '13 BRZ Ltd
Well, this is awkward.
Wepeel is offline   Reply With Quote
Old 03-25-2015, 12:40 AM   #2502
SVLTE
Just bought my '13 FR-S about a month ago, and have jumped headfirst into figuring out how I want to set up my car for CS. This spring and sway business is definitely good news, but throws a minor curveball into my decision with regard to dampers. I was leaning toward bilstein B6's given their build quality, their serviceability, and my lack of experience with suspension tuning on cars (I understand it on my mountain bike, but that's a whole different ball game). Given that these shorter, stiffer springs are now legal, are bilstein b8's also legal? I only found one mention in this thread that stated their shorter length excluded them, but would the overall length of stock dampers with TRD springs put the B8's within the limits of SCCA's stated 1" limit with regard to stock length?
SVLTE is offline   Reply With Quote
Old 03-25-2015, 01:07 AM   #2503
Jawnathin
Drives: Toyobaru FRZ
The spring doesn't change the length of the stock dampers. The same damper appears to be used whether you have the 'regular' springs or these new TRD springs. If the shocks were illegal before, they're still illegal now.
Jawnathin is offline   Reply With Quote
Old 03-25-2015, 01:13 AM   #2504
Jawnathin
Went to the Scion webpage and 'built' my FRS. On the swaybar package, it says the rear bar is...
15.8mm 4130 solid rear sway bar with polyurethane bushings
Yet the TRD document attached earlier says its 17.5mm.
Which one is correct and/or legal?
Old 03-25-2015, 02:30 AM   #2505
simpleisbest
Senior Citizen
Drives: Scion FR-S
Probably a typo. I expect it could happen with internal publications. The PN is correct and the PN is actually on the bars themselves. PNs are also on each spring. Easy match there.
Also FYI, it seems the bars are hollow. So expect lower stiffness vs a solid bar.
Still no idea on the spring rates or sway bar wall thickness.
Also, keep in mind the springs are meant to be paired with the stock dampers and still keep them within OEM estimated life expectancy. No idea on how much firmer than stock they calculate out to be.
Old 03-25-2015, 02:41 AM   #2506
SVLTE
I searched around a bit and THINK I answered my own question. B8's are less than 1" shorter in extended length than the B6, which I believe are OEM length. I'm hoping to get some confirmation from the earlybirds on here before I order tomorrow. I'm way too lazy to pop the OE dampers off and measure them.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
