Old 03-23-2015, 04:28 PM   #15
JarredH
JarredH's Avatar
Drives: Scion frs
245/40 will 100% not fit, rear or front. I have 18x9.5 squared with a +35 offset. having a lower offset, ie. +30 means your wheels will stick out even farther. 225/40s is what i run now and its perfect for my wheels being functionally low. Unless you run mad camber and have LCA's and Endlinks, you wont fit 245/40s on a 9.5 with offset smaller than +35. How do I know? Last season I ran my 18x9.5 +35 wheels with 245/40 falken 453 summer performance tires. I installed bc racing coils and maxed the camber out on the rear and the fender still sat on the tire. The fronts pulled my fenders and rubbed the inner paint fully off. All I can say is that its the only functional way to be slammed in a safe manner is to run a safe mild stretched tire. 225/40/18x9.5 isn't that extreme and is completely safe for daily driving. I know this first hand and I'm not speaking theoretically.
JarredH is offline   Reply With Quote
Old 03-23-2015, 04:34 PM   #16
JarredH
JarredH's Avatar
Drives: Scion frs
Even 235/40s rubbed so I just ended up going with 225/40s. Good luck with the build!
The Following User Says Thank You to JarredH For This Useful Post:
8six_frs (03-23-2015)
Old 03-23-2015, 06:42 PM   #17
xwd
Yeah +30 is a pretty low offset, +38/+40 is more ideal on a 9.5" rim.
Old 03-23-2015, 09:57 PM   #18
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
How was it running 225/40? I think maybe if I ran 245/35 I'll have more clearance and won't run as much? There's more room to play around in the back and I don't like the sunken look in the back of that makes sense. I've seen a few builds with 225/40 and 245/35 on 18 x 9.5 but I don't remember if they ran 8.5 in the front. Either way 225/40 would be fine for the front and with minimum stretch. Still debating on the rear tho
8six_frs is offline   Reply With Quote
Old 03-23-2015, 09:59 PM   #19
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
It's like .31" difference from +38 offset I think. Would that really make it stick out a lot more?
Old 03-23-2015, 10:05 PM   #20
swarb
Originally Posted by adamg View Post
depends how low you want to go, if you want to tuck the wheels and be really low do a 215. if you want to be low but not slammed don't go bigger than 225. if you want low but a little wheel gap go with a 235. if you don't want to go low and want a time attack "racecar" stance 245-255
also don't run staggered tires on non staggered wheels. it just looks weird, really weird
Exactly what he said, all of it. Definition of functional low is different for everyone. More low, less tire.
The Following User Says Thank You to swarb For This Useful Post:
Old 03-23-2015, 10:13 PM   #21
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
Does anyone have any pictures of their setups? That would be great lol.
Old 03-23-2015, 11:36 PM   #22
thien
Drives: Scion FRS
Originally Posted by AlexWood View Post
I think 225 front and 245 rear would work. This is about 2-2.5in drop with 18x9.5 +34 with 235/40 tires square Attachment 105293Attachment 105294
They fit with no fender mods and very little rubbing.
Will 235/40 rub if it's only 1 inch drop versus your 2 inch?
thien is offline   Reply With Quote
Old 03-23-2015, 11:47 PM   #23
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
On 18 x 9.5 and what offset?
Old 03-23-2015, 11:50 PM   #24
thien
Drives: Scion FRS
+35
Old 03-24-2015, 01:19 AM   #25
8six_frs
8six_frs's Avatar
Drives: Raven FR-S
+35
With a 1" drop u should be fine with that size.
The Following User Says Thank You to 8six_frs For This Useful Post:
thien (03-26-2015)
Old 03-24-2015, 01:22 AM   #26
thien
Drives: Scion FRS
I played with the calculator but I can't tell how much stretch there is on that set up. Any experience with ride comfort? This is my dd. Don't want it too rough lol
Old 03-24-2015, 01:27 AM   #27
Sugi
Sugi's Avatar
Drives: 2015 FR-S - Halo
This link is 18x9.5 35offset, but will give you an idea.
http://www.ft86club.com/forums/showthread.php?t=15097
Sugi is offline   Reply With Quote
The Following 2 Users Say Thank You to Sugi For This Useful Post:
8six_frs (03-24-2015), thien (03-26-2015)
Old 03-24-2015, 01:33 AM   #28
Sugi
Sugi's Avatar
Here is a video of 18x9.5 +30
coilovers, fitment, lowered, wheels
Tire Brand & Size Question ExxelDistributions Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-23-2014 05:03 PM
tire size question Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-22-2014 12:04 AM
Tire size question..? Yamajee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2013 05:21 PM
Tire Size and Ecutek Tune - Stupid question Pokeguyjai Software Tuning 5 10-04-2013 11:43 AM
QUESTION: Rim & Tire Size at NJ & NY Figo NY / NJ / CT / PA 6 07-17-2013 02:21 PM
