Old 03-21-2015, 05:34 PM   #113
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by Draco-REX View Post
Is anyone making stronger gearsets for the 6sp? I only see the Cusco close-ratio, which only changes 1st and 2nd.
I have a set being built. Along with a bunch of other fixes for weak spots and poor high rpm shifting. I'd like to think I'll be testing it by summer, but there is really no timeframe on when it'll be ready for me to install
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Darryljr11 (03-22-2015), Draco-REX (03-22-2015)
Old 03-21-2015, 08:21 PM   #114
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
So no real availability then. Ah well. I have an extra transmission laying around and thought I'd look into having it built. Ah well. It's no rush for me. I'm only on a Sprintex 210.
Old 03-21-2015, 09:20 PM   #115
spitfire481
Drives: 2JZ FRS
Once I get to beat on it for a little and we make sure it's all good it will be marketed. I'll be testing it at 600whp with mickey Thompson et street radials
MoTeC
Build Thread
@spitfire481
The Following 4 Users Say Thank You to spitfire481 For This Useful Post:
Darryljr11 (03-23-2015), Draco-REX (03-22-2015), Koa (03-25-2015), raven1231 (03-21-2015)
Old 03-21-2015, 09:56 PM   #116
Dipstik-sportech
Dipstik-sportech's Avatar
Originally Posted by Mikeez View Post
The maximum the FA20 can go it 400.83 whp
I hope that's a joke
Old 03-22-2015, 07:48 AM   #117
AJPG
Drives: 22RE, FA20, 4G63
Whoops. I thought you fragged 4th in all 3 of your transmissions.
Are you rebuilding them yourself?
And that's brings me so many unpleasant memories of my 4G63 (talon AWD). Apparently that gear box(es) we're made out of cheese...
Ufff it's all coming back! The heat soak, the timing belt, fry clutch and the easy fading brakes.
Man that was mechanic 101 to 3560.
Now I'm trying to avoid that rout with the FA20, so ALL fluid should be cool at all times (peace of mind) and AT (no easy clutch upgrade) (BTW that was the fuse that was remove and after that trany start to fall like flys) in the AWD Talon... A good combination was a heavy duty pressure plate with the OEM disc (good because last longer than stoke and didn't break trany as easy)...
Outstanding setup? Didn't find it
Just move on.
AJPG is offline   Reply With Quote
The Following User Says Thank You to AJPG For This Useful Post:
Ultramaroon (03-22-2015)
Old 03-22-2015, 08:32 AM   #118
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Of course it is. everyone knows it's 400.84 whp. C'mon
The Following 3 Users Say Thank You to cdrazic93 For This Useful Post:
Dipstik-sportech (03-22-2015), Koa (03-25-2015), Ultramaroon (03-22-2015)
Old 03-22-2015, 08:35 AM   #119
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
@Reaper, have you buy chance fitted an STi 6 spd yet? Assuming that'd be more cost effective than a TKO or T56 or super magnum and definitely a V160.
Yes you'd need a rwd converted one, but would that tack on a lot of cost? Iat just popped into my head, didn't really think about it lol
Old 03-22-2015, 01:45 PM   #120
Mikeez
Engineering Student
Drives: Scion FR-S 2015
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 03-22-2015, 03:08 PM   #121
gramicci101
Off Topic
@Reaper, would it be worthwhile to have a custom 4th gear made that can hold the torque that you and others are putting out? I've found a fair number of racing transmission manufacturers that could cut a stronger gear for you. Although that would move the failure point to somewhere else, I'm sure.
Old 03-22-2015, 04:05 PM   #122
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
It would be the synchros then. The carbon synchros would be expensive as well.
Old 03-22-2015, 04:12 PM   #123
gramicci101
Off Topic
I found a company that builds dog boxes and sequential manuals (for STi's, at least,) rated up to 590 lb-ft. I imagine that would be cost prohibitive as well, unfortunately.
Old 03-22-2015, 04:13 PM   #124
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Thats why I asked about a rwd converted STi trans.
Old 03-22-2015, 04:29 PM   #125
gramicci101
Off Topic
You'll have a bump hanging down where the front diff is, but I suppose you could use that to hold more transmission fluid and run cooler.
I'd have to wonder where the shifter would fall. The STI engine is mounted in front of the front axle, and the shifter's right on top of the transmission. Our engine is on top of/behind the front axle, but our shifter is extended backwards from the transmission. It would be perfect if pushing the STI transmission back to mate with our engine lined it up with the shifter hole in the tunnel. Swaps don't usually go perfectly, though.
Old 03-22-2015, 04:32 PM   #126
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
that's the nature of a swap lol
WTB FA20 Stock Cross Want-To-Buy Requests 22 08-19-2014 03:59 PM
WTB FA20 Stock Cross Want-To-Buy Requests 1 08-01-2014 07:47 PM
Stock FA20/trans, never modified 9k miles ATM - April/May slicktop Engine, Exhaust, Bolt-Ons 2 02-24-2014 08:44 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 07:39 PM
Stock AISSIN Transmission Power Capacity Don@Accelerated Forced Induction 37 07-03-2013 11:15 PM
