#253 | |
Drives: Neptune GR86
That's why you wait to flash the E85 tune. |
#254 | |
Poor College Kid
Drives: ~.~
Does it matter if you fill up the whole tank with E85 for the first time when flashing or is filling half way ok
#255 | |
Drives: FT86
remember your running a dedicated E85 tune or a dedicated petrol tune. reverse proceedure to go back to petrol. |
#256 |
Drives: GT86
Just a reminder not necessarily directed at the above posters:
If E85 availability is a problem and/or you: - Have to switch over emptying and brimming tanks and reflashing if doing long or unpredictable trips. - Make detours every time you need to fill up, which will be quite often, to get the % you need. - Use E85 fuel of varying quality from different pumps and drive about for hours worrying about ltft and staring at your oft display wondering if it's safe to give it some. - Do give it some but worry if varying quality will do damage. If one or several apply, do know that there are flexifuel kits available that read ethanol content in the fuel lines before they reach the injectors and give freedom to use any mix of E85 and gas... Just stating the obvious, seems some people are messing around with OFT when the fitting performance upgrade would be to spend a little more on a proper flexifuel kit and then enjoy driving where you want... Detours every time you need to fuel up or reflash also costs time and money and I'm betting that the station isn't at the end of a twisty mountain road that you don't mind driving... |
#257 |
Meh, just a change of habit.
Good reason to take the car out for a spin anyways.
#258 |
Drives: GT86
If it works for you it's all good! It's just easy to fall into the short term thinking trap, been there done that and such... Very pleased with my OFT here too
#259 | |
I plan my trip to get the fuel I want even on my other cars, people should never put in whatever come up at the first gas station for cars such as ours.
#260 |
Drives: Toyota 86 GTS
I'm now running these values (based on stock tables)
<= 10C/50F values multiplied x 1.5 20C/68F values multiplied x 1.4 30C/86F values multiplied x 1.3 40C/104F values multiplied x 1.2 50C/122F values multiplied x 1.1 60C/140F values multiplied x 1.05 And Shiv's Cranking IPW Comp A in addition to that. |
#261 | |
Drives: '13 SSM BRZ Limited 6MT
If I want to stick with E85 @ 85%, do I just need to rescale the MAF or do I need to adjust timing and knock as well? Mixing the fuel is pretty tedious so if I can adjust the ECU to handle E85 @ 85% and just straight fill up that would be easier. |
#262 | |
Drives: FT86
| The Following User Says Thank You to steve99 For This Useful Post: | tracerit (03-29-2015) |
#263 |
Drives: 2013 FR-S Whiteout MT
So I've ran e85 before. I recently only drive the car on the weekends. I searched around and couldn't find the answer I was looking for. I know someone talked about it before. How long can you keep e85 in your tank? are there any negatives if you keep it in the tank for over a week?
When in doubt, throttle out!
#264 | |
| The Following User Says Thank You to Wayno For This Useful Post: | FRS Johnny (04-17-2015) |
#265 | |
#266 |
Great except change 50 and 68 columns to be 200% of stock now, closer to mkivsupra's values.
| Stock FR-S Tune Just Done | Zach3794 | Engine, Exhaust, Transmission | 67 | 11-05-2017 03:01 PM |
| stock BR-Z, much detonation during shifts: tune? | elefunkd | Engine, Exhaust, Transmission | 69 | 07-26-2013 05:20 PM |
| Anyone have a stock tune from Visconti? | Bleevin | CANADA | 3 | 07-03-2013 02:01 AM |
| My Initial (all stock) BRZedit tune | mad_sb | Engine, Exhaust, Transmission | 6 | 02-16-2013 01:20 PM |
| Save stock tune with ecutek? | gdrider77 | Engine, Exhaust, Transmission | 7 | 01-06-2013 01:50 AM |
